Chris TickTock | 05/09/2019 14:23:02 |
622 forum posts 46 photos | Hi just thought it time to make sure I can read a micrometer well. So first things first why the ratchet....answer to stop over tightening and ensure even force on jaws. So why have the second knurled segment which is tempting to use...would it not be better not to have this/ |
Clive Hartland | 05/09/2019 14:28:20 |
![]() 2929 forum posts 41 photos | Chris. the small ratchet thumbwheel is to give a uniform pressure when measuring close tolerances, Thumb pressure on the large thimble can vary so much as to give odd readings. Edited By Clive Hartland on 05/09/2019 14:28:36 |
colin hawes | 05/09/2019 14:29:35 |
570 forum posts 18 photos | When you have acquired the skill after frequent use you will find the "second" knurled knob gives a better feel on precision work and also that feel lets you know if a bit of debris is causing a false reading. Colin |
Martin Hamilton 1 | 05/09/2019 14:35:13 |
188 forum posts | Because when you hold the mic with 1 hand & use it you have 1 finger which is normally little finger holding the curved body you would not be able to reach the ratchet knob at the end. The large knurled part is also handy when you want to open or close the mic down some distance you run the barrel up or down your arm. |
MadMike | 05/09/2019 14:42:44 |
265 forum posts 4 photos | Not wishing to be controversial, but is this a serious question? |
Chris TickTock | 05/09/2019 16:01:44 |
622 forum posts 46 photos | Thanks Guys 3 helpful answers all helpful especially Martin's point of holding the mic in one hand which being a greenhorn I overlooked. Chris |
Neil Wyatt | 05/09/2019 17:19:34 |
![]() 19226 forum posts 749 photos 86 articles | The knurl on the main barrel is for spinning it quickly, as the ratchet can slip if you turn it too vigorously. I read a test that showed even experienced users get more consistent results with the ratchet. I have also seen equally convincing claims that the opposite is true. Certainly, the makers insist you should use the ratchet. Neil |
Howard Lewis | 05/09/2019 17:26:57 |
7227 forum posts 21 photos | A lot of people say that the Ratchet should be turned until it has clicked three times, to give a consistent pressure.
The narrow knurled ring set into the frame of the micrometer, is used to lock a reading. In this way, then reading can be retained when the mic is removed; or it can be used a Go/No Go gauge. Howard |
Chris TickTock | 05/09/2019 17:37:02 |
622 forum posts 46 photos | Posted by Howard Lewis on 05/09/2019 17:26:57:
The narrow knurled ring set into the frame of the micrometer, is used to lock a reading. In this way, then reading can be retained when the mic is removed; or it can be used a Go/No Go gauge. Howard Thanks howard I forgot to ask what the narrow ring was for..thanks mate. Chris |
David Standing 1 | 05/09/2019 17:39:07 |
1297 forum posts 50 photos | Posted by MadMike on 05/09/2019 14:42:44:
I have suggested useful reading material to Chris on more than one occasion, he has not responded. Book 6 in the Workshop Practice series, Measuring and Marking Materials, by Ivan Law, would answer this question too. The preferred option appears to be to bombard the forum with questions instead. |
Former Member | 05/09/2019 17:47:35 |
1329 forum posts | [This posting has been removed] |
Howard Lewis | 05/09/2019 18:18:43 |
7227 forum posts 21 photos | Chris, Although quite a bit of money can spent on building up a library of books, it will be money well spent. None of us know everything, so we need books as a source of information to which we can refer. Some books will be opened more often than others. That will depend on: the state of your knowledge what you want to do how often you wish or need to perform that task. As an instance, if you bash on regardless, you could spend more on replacing broken Taps, and spoiled workpieces, than if you had bought a book on Taps and Dies, and how to use them. Which just happens to be No 12 in the Workshop Practice series of books. Other than for interest, there is not much point in buying books on the vertical milling machine, if you don't have one. Some of the info MAY be useful if you use a vertical slide to do a little milling in the lathe. L H Sparey's "The Amateur's Lathe" is often cited as a good starting point, (Although this heavily features the 7 Series Myford, because this was almost the standard machine, when the book was written ) just as is Ian Bradley's "The Amateur's Workshop" and Tubal Cain's "Model Engineer's Handbook". This latter sees a lot use by me, and I've been in Engineering since 1958! When you find a need for a book, buy it. You will refer to it more than once, although some less than others, but it will be there when you need info on that subject. Find your local Model Engineering Society, and join it. There will be folk there prepared to guide you on your machine, or show you how on theirs. You ask questions, in the hope of gaining knowledge, not to be laughed at. If I need information about my eyes, I ask an Opthalmist. I am an Engineer, not a medic. Should I wreck the control board on the mini lathe, I shall consult someone with good knowledge of electronics. Keep climbing the learning curve. Howard |
Chris TickTock | 05/09/2019 21:30:41 |
622 forum posts 46 photos | Posted by David Standing 1 on 05/09/2019 17:39:07:
Thanks MadMike, May I in return to your reading recommendation suggest you read the bible and turn the other cheek the next time I post not to your obviously elevated taste. Chris Edited By Chris TickTock on 05/09/2019 21:45:57 Edited By Chris TickTock on 05/09/2019 21:49:40 |
Paul Kemp | 05/09/2019 21:57:45 |
798 forum posts 27 photos | Posted by Chris TickTock on 05/09/2019 21:30:41:
Thanks MadMike, I will endeavor to make all future posts at your elevated level. Chris Chris, With the greatest respect I have followed many of your question posts and the answers which seem to be perfectly valid. However the way your responses read to me seem to dispute most suggestions as not appropriate according to your answers already gained from your valued advisor. I am sure you do not really intend to come across as I interpret your responses and there is nothing wrong with questioning to properly evaluate a method or process but the way you do this perhaps does not encourage people to respond? Paul. |
Alan Waddington 2 | 05/09/2019 22:13:53 |
537 forum posts 88 photos | The second knurled grip is designed to afford the user better purchase when using the micrometer as a hammer during squaring operations and such like. |
Michael Briggs | 05/09/2019 22:55:25 |
221 forum posts 12 photos | That’s a new one to me Alan, I thought the second knurled grip was to provide additional functionality as a G clamp. |
paul rayner | 05/09/2019 22:56:25 |
187 forum posts 46 photos | Posted by Alan Waddington 2 on 05/09/2019 22:13:53:
The second knurled grip is designed to afford the user better purchase when using the micrometer as a hammer during squaring operations and such like. well you learn something new every day, I didn't know you could use them as a hammer as well. I just use mine as a G cramp! |
Michael Briggs | 05/09/2019 22:58:47 |
221 forum posts 12 photos | Photo finish Paul, let’s call it a draw |
paul rayner | 05/09/2019 23:15:33 |
187 forum posts 46 photos | Posted by Michael Briggs on 05/09/2019 22:58:47:
Photo finish Paul, let’s call it a draw nah you win by exactly 60 seconds |
paul rayner | 05/09/2019 23:18:03 |
187 forum posts 46 photos | or a C spanner |
