Jim Dalton 1 | 02/09/2019 22:54:42 |
22 forum posts 3 photos | Hello all
The aluminum pieces in the link below look reasonably straightforward to make. Question is, would a pair of these be a realistic diy weekend project and if so, would it be achievable with hand tools? If a mini mill is called for, would a Sieg x1 or x2 be up to the job?
https://tsoproducts.com/accessories/tds-10-dog-stops-for-20mm-worktops/
Paul Lousick | 02/09/2019 23:05:34 |
2276 forum posts 801 photos | Easily made with hand tools if a mill is not available. Any mill would do Paul |
Jim Dalton 1 | 02/09/2019 23:07:33 |
22 forum posts 3 photos | Thanks Paul. How would I go about doing this? Sorry this may be a really basic question. |
Michael Gilligan | 02/09/2019 23:24:16 |
![]() 23121 forum posts 1360 photos | Posted by Paul Lousick on 02/09/2019 23:05:34:
Easily made with hand tools ... .
https://tsoproducts.com/accessories/tds-10-dog-stops-for-20mm-worktops/ MichaelG. |
MadMike | 03/09/2019 00:08:31 |
265 forum posts 4 photos | Jim if you have access to a Sieg mill then I would use it. It will give you a much better finish, repeated accuracy and in a fraction of the time you would take with hand tools. Although I have not made any of these I have recently made some aluminium adjustable brackets of similar proportions and with similar slots. They took minutes on my Sieg.
Paul Lousick | 03/09/2019 03:32:30 |
2276 forum posts 801 photos | Jim, A mill would be the quickest and easiest method but not too hard to do it with hand tools.. Drill a series of holes (smaller than the width of the slot) and use a round file to cut between them. Then use a flat file to finish the slot to width. Or just a hole at either end of the slot, use a round file to make it big enough to insert a hack saw blade and saw down each side of the slot. Finish with a flat file. Paul. |
Michael Gilligan | 03/09/2019 06:31:57 |
![]() 23121 forum posts 1360 photos | Posted by Paul Lousick on 03/09/2019 03:32:30:
Jim, A mill would be the quickest and easiest method but not too hard to do it with hand tools.. Drill a series of holes (smaller than the width of the slot) and use a round file to cut between them. Then use a flat file to finish the slot to width. Or just a hole at either end of the slot, use a round file to make it big enough to insert a hack saw blade and saw down each side of the slot. Finish with a flat file. Paul. . Did you look at the fourth picture in the sequence, Paul ? MichaelG. |
Robert Atkinson 2 | 03/09/2019 07:18:32 |
![]() 1891 forum posts 37 photos | The slots are undercut so actually quite a challenge to make with hand tools. You would have make a lot to justify buying a mill. Robert G8RPI. |
Michael Gilligan | 03/09/2019 07:25:35 |
![]() 23121 forum posts 1360 photos | Posted by Robert Atkinson 2 on 03/09/2019 07:18:32:
The slots are undercut so actually quite a challenge to make with hand tools. You would have make a lot to justify buying a mill. Robert G8RPI. .
I was hoping that people might be encouraged to look for themselves. MichaelG. |
JasonB | 03/09/2019 07:26:43 |
![]() 25215 forum posts 3105 photos 1 articles | And with the larger slot being in the region of 25mm quite a large cutter for a small machine unless you opt for a smaller one and don't have rounded ends to the larger slot. |
Robert Atkinson 2 | 03/09/2019 07:28:38 |
![]() 1891 forum posts 37 photos | Just a thought as these in light alloy and are for woodworking use you could just about use a router on lowest speed. Make up a jig in MDF rough out blanks with a hacksaw, chain drill the through slot first..... Robert G8RPI |
Michael Gilligan | 03/09/2019 07:33:10 |
![]() 23121 forum posts 1360 photos | Frankly ... Given the positive review of this product, and noting that these are really 'setting pieces' not 'clamps' ... I would say they are very good value at the price. MichaelG. |
Diogenes | 03/09/2019 07:51:52 |
61 forum posts 6 photos | I don't see why they couldn't be fabricated from two "L" shaped "sides" bridged with stepped ends to keep them rigid. This would open up far more possibilities, as the steps could be cut with an end mill on any a small mill, or as Robert suggested, a router ( -table?), or you might even find that a suitable extrusion is already available.. |
not done it yet | 03/09/2019 08:16:27 |
7517 forum posts 20 photos | It could be more easily fabricated in two parts with hand tools if only personal use is contemplated. Depends on why the poster might wish to make rather than buy. |
Nick Wheeler | 03/09/2019 09:17:08 |
1227 forum posts 101 photos | They're fairly simple to make, but on such a small mill will take ages compared to the cost of buying them. Time better spent on actually using them. |
Dalboy | 03/09/2019 10:21:07 |
![]() 1009 forum posts 305 photos | If as you say they will be made from Aluminum and you have a woodworking router you can buy router bit for that purpose but it will take several passes as most of them are designed for thinner material |
Paul Lousick | 03/09/2019 10:25:57 |
2276 forum posts 801 photos | They are not precision machining jigs so why make them so complex ? They are used on a router/saw table and are located in drilled holes on a wooden top. The stepped slot is not necessary. A simple slot in a piece of flat bar would be just as good and would not require the stepped location dowel/nut. It could be made from a piece of round bar with a tapped hole. The hand wheel could even be replaced with a standard bolt. Paul.
Neil Wyatt | 03/09/2019 10:39:55 |
![]() 19226 forum posts 749 photos 86 articles | In your position, I'd use hand tools. But I would make the slot the right width to fit the studs and get rid of the awkward step and use washers under the clamp knobs instead. Alternatively use a wider slot and make stepped washers, if you have a lathe. <edit> it seems the studs are 'loose' in which case, Paul's alternative will work fine. Neil Edited By Neil Wyatt on 03/09/2019 10:41:16 |
JasonB | 03/09/2019 10:46:32 |
![]() 25215 forum posts 3105 photos 1 articles | If you already have their dogs( or just about any other make) then you need the recess particularly for thin work as the top of the dogs is larger than the spigot that fits in the euro standard 20mm hole of the MFT. If I were making some I would consider a hard plastic as the bare aluminium will mark work without anodizing to stop it. Also kinder on cutting edges if you have a mishap. I'd also make the dogs with flats to fit into the wider groove so they don't rotate when the knob is tightened.
Edited By JasonB on 03/09/2019 10:52:35 |
John Haine | 03/09/2019 10:58:26 |
5563 forum posts 322 photos | Corian. Cut with router. |
