Ian Parkin | 27/08/2019 22:03:19 |
![]() 1174 forum posts 303 photos | I noticed this the other day stuck in my tyre driven about 50 miles on it...still held air over the bank holiday weekend what was revealed when the fitter removed the tyre ? Answer tommorow |
David Davies 8 | 27/08/2019 22:10:33 |
![]() 202 forum posts 1 photos | 'Sparklet' CO2 cartridge? Blunt end of course! |
Harry Wilkes | 27/08/2019 22:16:51 |
![]() 1613 forum posts 72 photos | Mini grinding stone |
Jeff Dayman | 27/08/2019 22:20:55 |
2356 forum posts 47 photos | Looks like a Smith and Wesson .44 round. Is Clint Eastwood filming anywhere nearby? |
Neil Wyatt | 27/08/2019 22:40:39 |
![]() 19226 forum posts 749 photos 86 articles | Dinosaur tooth Neil |
Phil P | 27/08/2019 23:05:04 |
851 forum posts 206 photos | Dunno what that is, but I had a bizzare puncture the other day that cost me a new tyre. It had 4" nail through it. Now that may not sound all that strange, until I tell you the head was inside the tyre with the pointy bit on the outside. work that one out ? Phil |
ken king, King Design | 27/08/2019 23:52:11 |
![]() 144 forum posts 239 photos | I would guess a golf tee. |
vintage engineer | 27/08/2019 23:55:37 |
![]() 293 forum posts 1 photos | Ragbolt |
I.M. OUTAHERE | 28/08/2019 00:43:48 |
1468 forum posts 3 photos | Cap screw or torx screw . I once had a 6mm hex driver punch a hole a tyre - it was the long type you use in a drill/driver , the front tyre must have flicked it up when it ran over it and it landed at just tue right angle for it to puncture the back tyre . The other one was when i got a new car i took the entry to my drive a fraction wider than usual and as my water meter is buried in a cut out in the concrete driveway i ran over it and the shaft for the shut off valve went straight through a brand new tyre - i have now fabricated a cover for the meter ! |
Enough! | 28/08/2019 00:58:43 |
1719 forum posts 1 photos | It's the tip of Clint Eastwood's finger which got sheared off when you drove into him in his wheelchair. |
Jeff Dayman | 28/08/2019 03:31:54 |
2356 forum posts 47 photos | |
Brian G | 28/08/2019 08:19:14 |
912 forum posts 40 photos | This was annoying as with a Smart I had no spare tyre. Brian |
Nicholas Farr | 28/08/2019 08:32:18 |
![]() 3988 forum posts 1799 photos | Hi, I recon a socket head bolt. Regards Nick. |
Mick B1 | 28/08/2019 08:43:25 |
2444 forum posts 139 photos | Posted by Neil Wyatt on 27/08/2019 22:40:39:
Dinosaur tooth Neil Triassic belemnite? |
Ian Parkin | 28/08/2019 09:23:55 |
![]() 1174 forum posts 303 photos | David Davies was right straight away a NO cylinder |
David Standing 1 | 28/08/2019 09:58:10 |
1297 forum posts 50 photos | Ah, 'hippy crack', N2O - you have no doubt parked in a quiet corner of a public car park, where the sniffers gather. I suspect some smart Alec deliberately wedged it under your tyre at an angle, so it did what it did and penetrated the tyre. |
Ian Parkin | 28/08/2019 10:18:07 |
![]() 1174 forum posts 303 photos | David i did wonder if someone had done that but up here in the north the streets are littered with the little blighters |
David Standing 1 | 28/08/2019 10:30:57 |
1297 forum posts 50 photos | Ian Plenty down here too! My guess it was wedged deliberately - their shape means it is unlikely one will flip up if driven over. Did you park in a multi storey car park prior to discovering it? |
KWIL | 28/08/2019 12:26:01 |
3681 forum posts 70 photos | Pointy end just right for wedging in the tread gap, my guess deliberate. |
David Davies 8 | 28/08/2019 12:27:30 |
![]() 202 forum posts 1 photos | Ian Can I claim my prize? Someone said it is a Hardinge HLV-H lathe? Seriously, the gutters are littered with these cartridges around the Cardiff/Newport area. I see them lying there as I cycle in to work. Is your Comet back in one piece now? Cheers Dave |
