electric paint sprayers
Manny lambert10/08/2019 21:17:40
31 forum posts
15 photos
Hi,
are electric paint sprayers any good and will they spray enamel paints such as machine paints.
I need to also spray clear laquer .
Thanks for any help.
Samsaranda10/08/2019 21:56:34
1688 forum posts
16 photos
Manny, I used an electric paint sprayer quite a few years ago and the results were awful, they don’t use air to atomise the liquid they just force it through a small orifice, the result is that the paint splatters everywhere and it just runs as it’s difficult to control how much paint goes on. If using a normal air driven spray gun is not an option then I would recommend using aerosol cans, they can give an excellent finish with a little practice. There are many different suppliers of aerosols with a multitude of different paints I am sure there are some that will suit your needs. I have a compressor and spray gun but by choice I use aerosols.
Dave W
Emgee10/08/2019 22:04:59
2610 forum posts
312 photos
Like Dave W I didn't find an electric paint sprayer did a very good job, exceedingly wasteful of paint and made a mess everywhere, but that was spraying emulsion paint 45 years ago, no doubt they are improved these days.
Emgee
Paul Lousick10/08/2019 22:58:39
2276 forum posts
801 photos
It depends on what you want to do.
10 years ago I used an Oldfields electric sprayer to paint the outside of my house with water based (acrylic) paint which did an excelent job. This was their best model (not cheap) and uses a small, built in piston pump to atomise the paint. Much quicker than using a brush or roller. Recently I had to paint a wooden fence and the old sprayer did not work so bought one of the new cheaper sprayers. This one used a built in fan to atomise the paint (like the sprayers that used to come with a vacuum cleaner). It did not produce a fine mist but did an excelent job of painting a rough sawn timber fence with acrylic paint.
I would not use an electric sprayer for applying car quality paint and lacquers and use an air compressor spray gun instead.
Paul.
Edited By Paul Lousick on 10/08/2019 22:59:30
Gordon A10/08/2019 23:06:43
157 forum posts
4 photos
My experience of this type of spray gun is that they are adequate, bordering on suitable for coating sheds and fences with preservative, but you will be very very lucky to get even a reasonable paint finish. Some years ago a friend of mine attempted to spray a white car with a gun of this type. The result was a car that looked like it had been coated in rice pudding !!
Gordon.
JohnF10/08/2019 23:54:53
1243 forum posts
202 photos
Depends on the spray gun, I have used one with good success, still have it and it was made by Wagner has a carbide pump and the pressure is high with very good atomisation. Mine is around 50 years old and the others available the time were Burgess which were by comparison pretty hopeless !
I have sprayed bike tanks, frame's, cars [cellulose] & walls [emulsion paint] all successful but how the modern units are by comparison I have no idea. The one big difference was the spray pattern is round only unlike air powered guns which can be either round or fan pattern.
Former Member10/08/2019 23:55:58
Nathan Sharpe11/08/2019 00:08:35
175 forum posts
Manny, like JohnF I've had good/excellent results with quality electric spray systems. You need to look at HVLP units. I started with an Apollo 400 many years ago and now use a Fuji machine for every finish, including cellulose on cars and two pack with "disposable" sprayguns. Just find a cheap gun that fits your system if spraying two pack. Last job was an MGB GT in mid blue, no problems, no "spatter" no runs. Just take your time to learn before using in anger!! Avoid,at all costs, the solenoid operated guns like the " Burgess" and it's modern equivalents. N.
Manny lambert11/08/2019 11:25:50
31 forum posts
15 photos
Hi,
thanks for the input.
Answer to question; Barrie Lever.
I would like to spray Enamel paint on home made machine accessories such as Ball turner, custom made brackets for mill, etc
I would also like to lacquer brass Gyroscopes .
Thanks Nathan and John, I will look out for the HVLP unit.
Ron Laden11/08/2019 11:36:26
2320 forum posts
452 photos
Many moons ago I sprayed a Morris Minor with a spray gun connected to a vacuum cleaner, it did a half reasonable job, a bit orange peel here and there but stand back 10 feet and it looked quite presentable.
Brian G11/08/2019 11:57:08
912 forum posts
40 photos
Posted by Manny lambert on 11/08/2019 11:25:50:
For small items a desktop compressor and airbrush might be a practical option. We paid just over £70 for one with a tank and a pair of cheap (but perfectly usable) airbrushes which has worked well for painting a 16mm scale loco.
Emgee11/08/2019 11:57:34
2610 forum posts
312 photos
Hi,
Manny, I believe a small air brush kit would be capable of spraying the parts mentioned.
Emgee
Clive India11/08/2019 11:57:37
277 forum posts
Dare I say it - use an airbrush on a "silent" compressor but buy a Badger.
Former Member11/08/2019 12:36:40
