In need of a steel ring 132mm dia
Steel ring
terry callaghan07/07/2019 09:20:02
237 forum posts
10 photos
hi, the time as long gone when I could find most of the material I needed in the scrap skips outside most manufacturing companies. I now find myself needing a 132mm Dia by 15mm steel ring. But how no idea where to look. I know it will need to be rolled out, but it’s far too much for my slip rollers to deal with as the ring needs to take a thread so needs to be 5mm thick or more. The companies my way are not interested or are asking silly money. Anyone have any ideas. Thanks
Alan Waddington 207/07/2019 09:45:20
537 forum posts
88 photos
Rather than rolling some flat it might be easier to cut off a section of tube, somewhere like metalsupermarket might be able to help. Or ask at your local pipe fitting stockist, they usually hold stock up to 6” dia, you might find a straight coupler that fits the bill, 5” schedule 40 is around the size you need, wall will be around 6mm
terry callaghan07/07/2019 10:19:41
237 forum posts
10 photos
Thanks, but the problem is that I can’t find anyone who sells tube the dia I want with a good wall thickness. And they all have a min length I need to buy if they did.
Hopper07/07/2019 10:26:54
7881 forum posts
397 photos
You might be able to buy a steel pipe flange and turn the OD to 132mm then bore out the middle to size. Lot of swarf though.
Or pay the money to get a piece of 15mm plate cut in a circle laser cut or waterjetted to rough size.
Edited By Hopper on 07/07/2019 10:29:44
Edited By Hopper on 07/07/2019 10:57:33
Chris Evans 607/07/2019 10:29:58
2156 forum posts
I would look at laser or flame cutting a blank. Where are you ? plenty of places here in the Midlands at good prices.
paul rushmer07/07/2019 10:43:31
104 forum posts
17 photos
Terry This is a classic case of where are you, my slip rolls will handle 6 by 20 strip. All so a good reason to belong to a club we have several sets of rolls a large scrap box plus many members willing to help. The club is Cambridge.
Food for thought Paul
FatWelshBoy07/07/2019 10:54:23
32 forum posts
10 photos
The seller of ebay item no. 264266744373 may be able to help, some of his listings have a mobile number if you want something custom.
old mart07/07/2019 11:10:47
4655 forum posts
304 photos
There are several suppliers of discs and rings for sale on ebay, just like F W B's example. If you look at the picture, you will notice that the cut is started inboard of the diameter, which may be a problem. The example shown would probably clean up to your required diameter. The thickness might not be enough if you want 15mm finished. I have bought several rings which saved a lot of machining, you just have to look through the whole lot for the sizes required.
Andrew Johnston07/07/2019 11:17:56
7061 forum posts
719 photos
Posted by paul rushmer on 07/07/2019 10:43:31:
The way I read the OP is that the strip would need rolling edge on, so you end up with a ring 132mm OD, ~5mm thick and with a 102mm hole.
not done it yet07/07/2019 12:16:28
7517 forum posts
20 photos
Posted by Andrew Johnston on 07/07/2019 11:17:56:
As in a 5mm washer? I think a piece of 6mm plate, as a starting point, would suffice for that.
Andrew Johnston07/07/2019 12:34:53
7061 forum posts
719 photos
Posted by not done it yet on 07/07/2019 12:16:28:
That's the way I read it, and I'd also start with 6mm plate, but I already have some in stock, left over from the traction engine hornplates. A sketch, or confirmation that I haven't gone off at a tangent, from the OP would be good.
Edited By Andrew Johnston on 07/07/2019 12:35:18
AdrianR07/07/2019 12:38:37
613 forum posts
39 photos
m-machine sell tube 135mm OD x 120mm ID and 5 3/4" OD x 5" ID by the inch.
Edited By AdrianR on 07/07/2019 12:39:43
terry callaghan07/07/2019 12:44:00
237 forum posts
10 photos
Thanks chaps, sorted now.
not done it yet07/07/2019 13:43:35
7517 forum posts
20 photos
Posted by Andrew Johnston on 07/07/2019 12:34:53:
I think you were on the right lines, Andrew.smiley
Ian P07/07/2019 17:10:04
2747 forum posts
123 photos
Posted by not done it yet on 07/07/2019 13:43:35:
I think it would have been nice if the OP (who says its all sorted now) had pressed a few more keys on his keyboard and explained what he wanted in the first place.
Ian P
Former Member07/07/2019 17:18:37
1329 forum posts
terry callaghan07/07/2019 17:23:01
237 forum posts
10 photos
I stated right on my first post what I was looking for, that’s why people could help me instead of making underhand comments.
ega07/07/2019 17:24:40
2805 forum posts
219 photos
Posted by Ian P on 07/07/2019 17:10:04:
Ian P
and, respectfully, told us how he solved his problem so that others might benefit.
Former Member07/07/2019 17:39:08
1329 forum posts
Ian P07/07/2019 18:31:11
2747 forum posts
123 photos
Posted by terry callaghan on 07/07/2019 17:23:01:
I beg to differ. If you had explained you were looking for why were so many of the people that tried to help having to make assumptions and guesses.
My comment, which was only slightly sarcastic and hardly underhand, could have been worded better. It was not your original post I was referring to, but to the fact that when you said it was sorted, did not explain then.
Ian P
