Phillips vs Pozidrive and portable drills
Russell Eberhardt05/07/2019 10:08:48
2785 forum posts
87 photos
Why do portable drills always come with Phillips screwdriver bits when all screws on sale seem to be Pozidrive? I've just been repairing a wooden terrace and been mangling half of the screws in the process as a result.
Russell
KWIL05/07/2019 10:10:31
3681 forum posts
70 photos
Solve your "problem" by using the correct cross insert?
JasonB05/07/2019 10:15:51
Never bough any drywall screws, self tappers, etc all generally come with Phillips rather than Posi.
I just carry a range of bits as it's hard to tell what you may find on site be that slotted, pozi, prodrive, Phillips, Torx, square, allen and the odd tec screw
Edited By JasonB on 05/07/2019 10:19:06
RMA05/07/2019 10:17:08
332 forum posts
4 photos
Typical example of non standardization! Having put thousands of these things in, I always find Posidrive to be the best.....and then comes along a Philips head!! Have to search and change the bit, and they never seem to bite as well.
Single slot still around, and what a pain they are. Torx head Brilliant but not that common although I have put a few thousand of those in.
Russell Eberhardt05/07/2019 10:28:40
2785 forum posts
87 photos
Posted by KWIL on 05/07/2019 10:10:31:
That's all very well but I had to visit three different DIY stores before I found the correct Pozi bit in Leroy Merlin. Perhaps it's just a problem in France.
Russell
Vic05/07/2019 10:41:22
3453 forum posts
23 photos
Sadly I’ve still got stock of lots of Philips and Pozidrive screws. I try not to use them though and haven’t actually bought any for many years. My preferred drive is Robertson (Square) drive. If I can’t get those then I use a Torx. I got at least one Terminal screwdriver and they work pretty well but of course you can’t buy screws with combined heads!
Mike Poole05/07/2019 11:32:47
3676 forum posts
82 photos
Just brum em insmiley
KWIL05/07/2019 12:32:45
3681 forum posts
70 photos
That's all very well but some may not appreciate what the expression meansdevil
Mike Poole05/07/2019 12:55:42
3676 forum posts
82 photos
As Kwil points out maybe not everyone is familiar with the expression ‘brum em in’. Brum is the city of Birmingham in the UK and a Brumaggem screwdriver is a hammer. The suggestion is that time is wasted using a screwdriver when a hammer will sink the screw, probably sharp practice from the days of piecework. Obviously a hammer will not be fussy about the head of the screw. These days with many screws being hard brumming them in could be quite dangerous and is not to be recommended.
roy entwistle05/07/2019 13:03:47
1716 forum posts
My dad used to say " a hammer is for putting screws in, a screw driver is for removing them " One old chap I worked with as an apprentice used to call a screw driver a turn screw, and a spanner a nut key
Roy
Nick Clarke 305/07/2019 13:04:59
1607 forum posts
69 photos
Posted by Mike Poole on 05/07/2019 12:55:42:
As an adopted Brummie, living here for more than 30 years, I would like just like to point out that this reference to inserting screws is not correct - I am not fussy about anything and everything!
Mick Henshall05/07/2019 13:24:55
562 forum posts
34 photos
I only use slot headed screws, can't abide posi headed anything
Mick 🇬🇧
Bazyle05/07/2019 13:28:32
6956 forum posts
229 photos
Boxes of better screws eg Reisser come with a new bit in every box so the professionals will have the fight one. I think Robertson is mostly just in Canada.
You can get hammer screws designed to be hammered in but have more holding power than a nail and can be unscrewed if needed. Their thread is shallow long lead and they are actually quite difficult to get to screw in.
JasonB05/07/2019 13:38:05
Ah a hammer, I remember those from the days before I put nails and pin in with gunswink
Hammer just gets used to "adjust" the position of the bit of timber these days, can usually get it good to the nearest nano or two.
Talking of knocking timber into position I'm part way through redoing a lot of work on a gym and changing room extension to a swimming pool where the previous work left a lot to be desired and resulted in chronic condensation within the roof voids. Now that the finished building has been stripped back to bare studwork, joists and rafters and allowed to dry out several of the ceiling joists have dropped out where they were hammered in tight when the wood was fresh and moist from the yard and the cowboys forgot to nail them in.
Jeff Dayman05/07/2019 13:38:32
2356 forum posts
47 photos
"I think Robertson is mostly just in Canada"
Uh, no. Very widely used in USA (sometimes under the Scrulox imitator brand) and south America also. THE best head and driver design in the world, bar none, for wood screws. Try them and you will never go back to other kinds.
They were invented in Milton Ontario Canada by Mr P L Robertson. He had a plant for making them in UK as well, in the 1920's-1930's.
John Reese05/07/2019 13:45:20
1071 forum posts
Robertson heads are quite common in the US also. We see some screws with a combination head: Robertson and Phillips. They seem to strip out more frequently than either the Robertson or the Phillips. The higher grade fasteners are mostly Torx drive now.
Georgineer05/07/2019 13:51:38
652 forum posts
33 photos
Posted by Jeff Dayman on 05/07/2019 13:38:32:
That makes sense. The only time I have encountered them in the UK was on a wooden step-ladder I inherited from my grandfather. I estimated that it dated from the 1920s or 30s, and it took me a long time to identify the screw heads. Sadly, the step-ladder succumbed to the combined effects of damp and woodworm some years ago.
George B.
Michael Gilligan05/07/2019 13:59:02
23121 forum posts
1360 photos
Posted by Nick Clarke 3 on 05/07/2019 13:04:59:
In my 'O level' Woodwork exam ... one of the written questions was:
A hammer is for putting-in screws, a screwdriver is for removing them: Discuss
Note: I may have paraphrased the question, but that was certainly the essence of it.
JasonB05/07/2019 14:15:30
The most common use of square drive screws in the UK is for pocket hole joinery where "kreg" are the common brand made popular by Norm on NYWS. That's about the only thing I use them for, driver does tend to stay in the hole well.
Vic05/07/2019 14:27:26
3453 forum posts
23 photos
I first saw them when I went to Canada on holiday 20 years ago. The salesman in a DIY store (an Australian!) was surprised I hadn't seen them before. I came back with several boxes of screws, screwdrivers and bits. Beware of Makita brand bits though, they don’t fit! I sent them back to Makita with some screws and a complaint but they never replied. You can get the screws and drivers etc from:
Square Screws UK
For fittings where the screw is on display, like coat hooks for example Square drive look so much nicer than Pozidrive screws.
