Fire bricks
Dalboy22/05/2019 18:52:38
1009 forum posts
305 photos
Can anyone tell me if bricks from an storage heater are any good to make a silver soldering station.
fizzy22/05/2019 18:55:59
1860 forum posts
121 photos
Hi - worst possible use for them. They are made to absorb heat. You need to reflect heat. Ive got a few and its very difficult to solder anything which is in contact with them.
JasonB22/05/2019 18:59:19
Some of these are what you need, they will reflect heat back at the job
Dalboy22/05/2019 19:04:51
1009 forum posts
305 photos
Thank you both. I will lokat those Jason thank you
martin perman22/05/2019 19:11:31
2095 forum posts
75 photos
I've been using storage heater bricks for years and until I read this I've never had problems, I suppose its all down hill from here now sad
Martin P
not done it yet22/05/2019 19:51:06
7517 forum posts
20 photos
Posted by martin perman on 22/05/2019 19:11:31:
Martin P
When they get up to temperature, they will work OK. But they will have made any metal heating rather less efficient than using the right materials for the job. A larger torch will overcome any heat loss to the bricks. Likely cost you more in gas, than buying the right material, over those (many?) years.smiley
Mike Poole22/05/2019 19:57:51
3676 forum posts
82 photos
Vermiculite and Skamolex are a couple of brands that are easy to find from internet sellers.
Buffer22/05/2019 20:11:45
430 forum posts
171 photos
Well I use firebricks. Cheap (about £6) easy to get (buildabase etc) heat proof, low thermal conductivity. Stack nicely into a hearth can be left outside. Never had any problem silver soldering with them.  I have seen these vermiculite slabs break easily and break down with bits under the job breaking of and sticking to jobs when the flux and work get hot.
Rich
Edited By Richard brown 1 on 22/05/2019 20:20:10
martin perman22/05/2019 20:14:14
2095 forum posts
75 photos
Posted by not done it yet on 22/05/2019 19:51:06:
Martin P
I'm pleased to see you find it funny.
Bazyle22/05/2019 23:44:38
6956 forum posts
229 photos
It is better to find or buy a Thermalite block which can be carved with a chisel or drilled to help hold things. Just make sure tehy are thoroughly dry if they have been in the rain, Also the ceramic elements from old gas fires work well as supports and are designed to reflect and re-radiate heat.
Mike Poole23/05/2019 00:10:42
3676 forum posts
82 photos
I think the performance of vermiculite blocks is excellent but they are quite fragile, if you are silver soldering all day every day then a more durable solution may be desirable.
fizzy23/05/2019 00:13:03
1860 forum posts
121 photos
low thermal conductivity.....the exact opposite of what they are?
bricky23/05/2019 00:22:22
627 forum posts
72 photos
I use thermalite blocks from the builders merchant and you can form pockets in them easily to hold odd items.Works for me.
Frank
JasonB23/05/2019 07:46:01
I think any non combustable material will work, just that some work better than others and may mean you need to use less gas and are able to get the work upto temperature faster which is a good thing.
Beware searching the net for generic Vermiculite or Skamolex as there are many versions available some being denser than other so may not do as good a job as the lower density blocks, also watch the sizes for example you can find blocks for a fiver on the bay but they are a third the size of the ones I linked to that sell for about £12
Yes they are a bit more fragile and the surface can get pulled off when flux sticks to it but I'm still using the ones I bought 10 odd years ago and I do a lot of silver soldered fabrications on my models. Maybe treat them a disposable cost saved in gas will more than likely pay for any replacements or simply raise the work just clear of the bottom sheet/block.
As mentioned in passing by bazyle make sure any hearth material is completely dry especially if stored outside. Once heated any internal moisture will turn to steam and could cause the surface to spall and the last think you want in the middle of that critical final heat is brick in your eye.
J
Buffer23/05/2019 08:00:44
430 forum posts
171 photos
Posted by fizzy on 23/05/2019 00:13:03:
fire bricks are low thermal conductivity on the Vitcas website and others.
Point taken about making sure they are dry but I have never had one spall, they are under an old metal box.
Keith Hale23/05/2019 11:01:57
334 forum posts
With due respect to Jason and fizzy, they have both overlooked the big advantage that firebricks and storage bricks have is that they will keep the workshop warm long after you have finished brazing. All that heat put into the bricks and not the work has to be dissipated eventually.
You have burnt the gas, shame not to get any benefit from it.
Stick to light, low thermal capacity bricks and/or kaolin clay blanket folks.
Let's do things properly
Keith.
PS Jason and Fizzy otherwise are spot on!
Dalboy23/05/2019 12:11:44
1009 forum posts
305 photos
Posted by JasonB on 22/05/2019 18:59:19:
On a little bit of a side track from my first post is the company that you linked to. Are they also a good place to buy silver solder from or do you get it from somewhere else.
Buffer23/05/2019 12:31:10
430 forum posts
171 photos
JasonB23/05/2019 15:41:38
CuP are a good supplier to use and will happily answer any specific queries, also have a read of their "Best Brazing practice" along the top of the black bar on their website.
R Johns23/05/2019 16:09:23
42 forum posts
I use the storage heater bricks for silver soldering. Whilst they absorb heat they also radiate heat when hot. You can look at this in the same manner as using a charcoal pit for brazing. I start by heating up the bricks then move the flame to the work piece.The ambient heat from the bricks keeps the work hot whilst you concentrate the flame onto the joint being soldered.
The only thing that I have been warned of but not seen for real is to ensure the bricks do not get wet. I am informed that a damp brick having a torch applied to it may explode.
Elmo
