Roger Hulett | 11/04/2019 13:32:57 |
131 forum posts 9 photos | I have a 70mm x 5mm brass rod. I need to turn this down to 3mm. At one end there needs to be a 45degree angle to take the rod from the turned 3mm to the original 5mm. I have a 1939 South Bend 9" a small Pools horizontal mill. Rotary Table, Vertical slide. Pillar drill Advice on the correct procedure to carry this out will be very much appreciated. |
Former Member | 11/04/2019 13:47:57 |
1329 forum posts | [This posting has been removed] |
mechman48 | 11/04/2019 14:39:15 |
![]() 2947 forum posts 468 photos | +1 for drilling, solder then bend, easiest way as Bills method above. George. |
JasonB | 11/04/2019 14:43:55 |
![]() 25215 forum posts 3105 photos 1 articles | How long is the 3mm section? If it is long do you have spare material for tailstock support? |
Roger Hulett | 11/04/2019 14:57:42 |
131 forum posts 9 photos | Sorry, did not explain myself correctly. I should have said the 3mm diameter will TAPER out to the 5mm diameter. |
Former Member | 11/04/2019 16:09:27 |
Samsaranda | 11/04/2019 17:23:24 |
![]() 1688 forum posts 16 photos | Sharp tool and required angular offset on the tool holder, with 5mm brass rod you wouldn’t need any support or steady, I have made fuel control needles in smaller diameter brass without problems, you need a sharp tool and shallow cuts. Dave W |
JasonB | 11/04/2019 18:17:41 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Samsaranda on 11/04/2019 17:23:24:
Sharp tool and required angular offset on the tool holder, with 5mm brass rod you wouldn’t need any support or steady, I would if the taper is over the full 70mm length, a question that has not yet been answered. Edited By JasonB on 11/04/2019 18:17:57 |
Emgee | 11/04/2019 18:18:10 |
2610 forum posts 312 photos | Roger, if you only need a short length of 3mm diameter use a facing & turning tool which is ground to 45 deg angle to the lathe axis, either take 1 x 1mm DOC or a series of cuts to achieve the 3mm diameter, at the 1mm DOC you will have your 45 deg transition from 3-5mm. Emgee |
Former Member | 12/04/2019 17:44:29 |
Neil Wyatt | 12/04/2019 17:51:55 |
![]() 19226 forum posts 749 photos 86 articles | If the tape angle is 45 degrees as stated, then an angled tool will do the job. Mount 5mm rod in the mill, set up a tool in the vertical slide attached to the table and do the job with a single cut.
duncan webster | 12/04/2019 18:01:06 |
5307 forum posts 83 photos | Posted by Neil Wyatt on 12/04/2019 17:51:55:
why use a milling machine when the OP has a lathe? |
Roger Hulett | 13/04/2019 11:28:57 |
131 forum posts 9 photos | OK everyone,Thanks very much. Job done. 45degree tool did the job.
Former Member | 13/04/2019 11:52:53 |
Ian S C | 13/04/2019 13:01:17 |
![]() 7468 forum posts 230 photos | A rough sketch on a bit of paper with a pencil can be useful. Ian S C |
Roger Hulett | 24/04/2019 12:23:44 |
131 forum posts 9 photos | It's all I can do to work a lathe and type letters on a computer Asking me to take pictures or draw sketches and post them.......well. ..............Now ............... If my great grandson was here........ no prob. |
