Former Member | 09/12/2018 09:45:49 |
1329 forum posts | [This posting has been removed] |
JasonB | 09/12/2018 10:15:04 |
![]() 25215 forum posts 3105 photos 1 articles | Wasn't there a design for a straightener in a recent MEW? |
Neil Wyatt | 09/12/2018 10:51:34 |
![]() 19226 forum posts 749 photos 86 articles | Try annealing and rolling again, it's always worked for me up to about 8" length. |
Former Member | 09/12/2018 12:34:40 |
Dalboy | 09/12/2018 12:58:21 |
![]() 1009 forum posts 305 photos | Not yet started any engineering work but understand some of the things as I was a plant mechanic for well over 25years and had to work with metal in that field. Could you as suggested anneal it and use some of the woodworking clamps that can be reversed, make two pipe holding clamps to fit to it and then put the pipe under strain to straighten it. Just thinking out aloud and probably on the wrong track |
Former Member | 09/12/2018 13:42:14 |
Dalboy | 09/12/2018 14:10:53 |
![]() 1009 forum posts 305 photos | Posted by Bill Chugg on 09/12/2018 13:42:14:
Thanks for the suggestion Derek, I will give it a goas always willing to try and learn. I have tried Neil's suggestion and that works fine. My lengths were 12 inches long so too long. Bill It is me that is on the learning curve |
vintage engineer | 09/12/2018 15:09:04 |
![]() 293 forum posts 1 photos | Could try hanging it up with a large weight on the end. |
Martin Connelly | 09/12/2018 18:49:16 |
![]() 2549 forum posts 235 photos | Torsion can straighten wire and soft tube. Plug the ends, solder may work, grip in lathe chuck at one end and tailstock chuck at the other. Use the chuck key to rotate the main chuck manually, should not take much rotation to straighten it. Martin C |
Rod Renshaw | 09/12/2018 21:55:17 |
438 forum posts 2 photos | In his book "Tools for the Clockmaker and Repairer, Volume 2" John Wilding suggests a method of straightening wire which I have used with sucess on small diameter tube. Briefly, find a 2" length of tubing which is a loose fit over the wire or tubing to be straightened and bend this short length slightly so that it becomes a tightish fit on the tube to be straightened (the longer tube). First straighten the longer tube by hand as straight as you can.Then hold the longer tube in the lathe chuck and spin at moderate speed while holding the short length in a gloved hand and move it up and down the length of the longer tube. I don't know quite how it works but the bent rotating tube just straightens out - like magic! Rod |
john swift 1 | 09/12/2018 22:18:28 |
![]() 318 forum posts 183 photos | Have a look at how coil feed Escomatic lathes straighten the stock see page 3 https://www.escomatic.ch/media/gallery/machines/d2-d5-flexspeed-e.pdf John |
Weary | 09/12/2018 22:18:41 |
421 forum posts 1 photos | Bill, Blackgates can supply 1/8" x 22 gauge copper tube in 12" lengths. Maybe give them a call. Likewise GLR. I have a feeling that Polly can also supply. + off-topic - I bought those Vulcan drawings that you pointed me in the direction of. Thanks. Regards, Phil Edited By Weary on 09/12/2018 22:20:48 |
blowlamp | 09/12/2018 22:20:07 |
![]() 1885 forum posts 111 photos | Grip one end in the vise and rig up some kind of slide-hammer arrangement to stretch it slightly.
Martin. |
Hopper | 09/12/2018 23:13:05 |
![]() 7881 forum posts 397 photos | Or even simpler, hold one end of the copper tube in the bench vice and the other in a pair of vice grips and yank on it a few times to stretch it out straight. Works best with longer lengths. That's how we did it when installing instrument pipework in power stations etc back when gauges were really gauges and operated on actual pressure. |
Emgee | 09/12/2018 23:32:12 |
2610 forum posts 312 photos |
The tool used for straightening MICC (Mineral insulated copper covered) electrical cable would most likely do the job, it is a tool with 5 semi circular grooved edge rollers mounted 3 top 2 bottom being sprung loaded and adjustable to suit diameter of the cable to be straightened. Searching BICC Tooling may bring up some pictures. Emgee Edited By Emgee on 09/12/2018 23:37:05 Edited By Emgee on 09/12/2018 23:39:50 |
I.M. OUTAHERE | 10/12/2018 03:49:41 |
1468 forum posts 3 photos | One of these will do it but the cost 😭 https://youtu.be/4OVREFfoAAA Mogens Kilde described a wire straightener in MEW 271-272 that could be adapted to do the same thing if you don't mind making one . I wonder how you would go running the tube through a block of wood say 2 or 3 inches long with the appropriate hole drilled through it then feed the tube through the hole and clamp the end of the tube in a vise and drag the block along the tube - might need a bit of soap for lube , never tried it - just a thought ! Edited By XD 351 on 10/12/2018 03:59:28 |
Hopper | 10/12/2018 03:58:31 |
![]() 7881 forum posts 397 photos | And you might try re-annealing it now it's almost straight, then roll it between your two plates again. Can't hurt. |
Former Member | 10/12/2018 08:50:30 |
Former Member | 10/12/2018 08:51:19 |
