Wooden display base
Former Member20/11/2018 16:58:24
1329 forum posts
Rod Ashton20/11/2018 17:49:47
344 forum posts
12 photos
Buy an old laboratory balance!!
Bazyle20/11/2018 18:01:09
6956 forum posts
229 photos
Google your town for woodwork / turning /carving club /society. Likely that someone will be happy to make one for you and possibly in exchange for a metal bit for one of his projects.
Graham Wintersgill20/11/2018 18:16:23
2 forum posts
Bill
Unless you are set on Oak I can supply a piece of American White Ash or strips of Western Red Cedar left over from my kayak and canoe build.
Graham
Bazyle20/11/2018 18:19:03
6956 forum posts
229 photos
Just had another thought. Try looking for a local sign maker as house signs and nameplates are about that size. If in Devon try Notice-it in Topsham. Only thing is the lead up to Christmas is busy for them as a people think of easy presents.
Former Member20/11/2018 18:23:13
1329 forum posts
Ian Parkin20/11/2018 18:45:08
1174 forum posts
303 photos
If you just want a piece of English or European oak the size that you quoted let me have your address and i’ll Drop a piece in the post for you
i can do it rough cut ,planed, or planed sanded and finished
bricky20/11/2018 19:02:32
627 forum posts
72 photos
Try a kitchen fitter who often rip outdated oak units and the doors are ideal pieces of timber.
Frank
fizzy20/11/2018 19:36:47
1860 forum posts
121 photos
theres a chap on ebay sells them cheap - type in plinth - I use them to display my boilers and they are well made solid wood
Stuart Bridger20/11/2018 20:14:56
566 forum posts
31 photos
Cheap chopping board from a supermarket, cut to size and finish
Dalboy20/11/2018 23:36:02
1009 forum posts
305 photos
If you get stuck give me a shout as I have some Oak/ Roughly where about are you
Former Member21/11/2018 08:24:22
1329 forum posts
Martin Kyte21/11/2018 08:54:39
3445 forum posts
62 photos
Oak is quite acidic to the extent of tending to rust steel screws used as fixings so be aware if you do use that. If the engine base is directly in contact then a good sealing of shellac and wax or varnish should protect your engine.
regards Martin
Enough!22/11/2018 01:30:06
1719 forum posts
In Canada/US you can get finished bases from a decent handicraft store such as ' Michaels. Surely there are similar such stores in the UK which might supply one?
Dalboy22/11/2018 09:46:35
1009 forum posts
305 photos
Posted by Bill Chugg on 21/11/2018 08:24:22:
Thanks for the offer Derek
I said oak as I needed a light colour but any light / yellow colour would do as engine is black.
I have no woodworking skills or equipment so was looking to buy a finished base.
Would have happily paid up to £20 for a bespoke one..
Bill
Edited By Bill Chugg on 21/11/2018 08:24:56
Bill I will have a look to see what other wood I have. I definitely have Oak if you want that just for postage. I can cut to size and finish.
But as stated above Oak can play effect metal if both are left bare due to the Tannin in it. I turned some wet Oak once and had to clean the lathe straight afterwards and even then the metal started turning black.
Samsaranda22/11/2018 10:26:57
1688 forum posts
16 photos
Check Ebay there are numerous sizes of finished plinths suitable for mounting models.
Dave W
Former Member22/11/2018 10:52:12
1329 forum posts
Weary22/11/2018 11:08:00
421 forum posts
Bill,
Brass tube, 1" diameter x swg 22 (0.028", 0.75mm) is listed by M-Machine metals. He also stocks 20, 18,16, & 10 swg.
Phil
Former Member22/11/2018 11:16:09
1329 forum posts
