ground silver steel round bar
sean logie18/11/2018 08:37:19
608 forum posts
7 photos
How accurate would this be or would it depend on supplier . I'm planing on making some dowel pins for locating two parts  .
Thanks
Sean
Edited By sean logie on 18/11/2018 08:38:01
Emgee18/11/2018 08:50:09
2610 forum posts
312 photos
Hi Sean, dowel pins are normally dead to size so probably the best route.
Emgee
Tony Pratt 118/11/2018 08:54:40
2319 forum posts
13 photos
Sean,
Yes seems to depend on supplier, quick Google search of 2 suppliers quote different size tolerancefrown I would use dowel pins.
Tony
Michael Gilligan18/11/2018 08:56:40
23121 forum posts
1360 photos
This is probably as good as it gets: **LINK**
http://www.silver-steel.co.uk/aboutsilversteel.php
sean logie18/11/2018 09:07:56
608 forum posts
7 photos
Thanks guys
Sean
ega18/11/2018 09:26:57
2805 forum posts
219 photos
Posted by Michael Gilligan on 18/11/2018 08:56:40:
Good link.
One gotcha used to be that the SS was "tri-lobate" so that out of roundness could not be detected with a mic.
Michael Gilligan18/11/2018 09:37:43
23121 forum posts
1360 photos
Posted by ega on 18/11/2018 09:26:57:
... as mentioned here: **LINK**
https://www.model-engineer.co.uk/forums/postings.asp?th=57958
angel
JasonB18/11/2018 10:08:22
Don't forget the size of your hole will affect the "fit" just as much as the pin, most off the self reamers are H7 or H8 so your SS will be a sliding fit, you really want it a bit tighter for a dowel pin.
I did have a feeling that proper dowel pins were slightly plus on size.
EDIT, seems I remembered correctly they are plus size as per this maker
Edited By JasonB on 18/11/2018 10:19:11
ega18/11/2018 11:19:44
2805 forum posts
219 photos
Posted by Michael Gilligan on 18/11/2018 09:37:43:
angel
Thanks. It had not occurred to me that PGMS might be prone to the same fault; presumably, they are both centreless ground.
Nick Wheeler18/11/2018 11:28:39
1227 forum posts
101 photos
Posted by JasonB on 18/11/2018 10:08:22:
Don't you want a very light press fit on one part, and sliding fit on the part you're going to remove(cylinder head for example)?
Michael Gilligan18/11/2018 11:33:14
23121 forum posts
1360 photos
Posted by ega on 18/11/2018 11:19:44:
angel
blush Sorry if my attempt at clarity failed ... In that previous thread I was actually trying to distinguish between Silver Steel being 'centreless ground' and PGMS being 'precision ground' [i.e. implicitly ... ground between centres]
Hopper18/11/2018 12:14:06
7881 forum posts
397 photos
The ground stainless steel round bars out of old computer printers make pretty handy dowel pins. Otherwise I just use silver steel and a worn reamer that gives a nice firm fit.
Edited By Hopper on 18/11/2018 12:15:01
ega18/11/2018 14:15:31
2805 forum posts
219 photos
Posted by Michael Gilligan on 18/11/2018 11:33:14:
angel
Thanks again. I didn't read the rest of the thread; hence, probably, my misunderstanding.
I don't suppose a small amount of "lobacity" would necessarily prejudice use as a dowel pin.
lfoggy18/11/2018 17:58:30
231 forum posts
5 photos
In my experience silver steel can be surprisingly variable in diameter, roundness and parallelism. 10mm diameter silver steel for example can be anything from 9.97 to 10.00mm.
Silver steel is not that uniform a product. In find precision ground mild steel bar to be better if you need consistency. Wideley available....
I.M. OUTAHERE18/11/2018 18:12:42
1468 forum posts
Posted by Nicholas Wheeler 1 on 18/11/2018 11:28:39:
I have an under and over reamer set for this , two reamers per size - .001”over and one .001” under so you get a drive in fit on one side and a sliding fit on the other .
