andrew lyner | 17/11/2018 21:37:42 |
274 forum posts 5 photos | I have a Warco Super Mini lathe and I have just bust my second drive belt. The first one lasted longer than the recent one. I though I had learned how to treat it right but obviously not! It os starting to get expensive. When I replaced the belt I looked for a motor adjustment for belt tension but couldn't find anyone the vicinity of the motor. Has anyone had this problem and is there anything I can do about it? Could it be too slack? The belt is actually quite flimsy and replacing it takes an annoying length of time. Buying one from Warco is expensive and a cheaper source would also be handy to know about. But basically I'd appreciate tips for ways of avoiding having to put in a replacement. |
not done it yet | 17/11/2018 22:59:26 |
7517 forum posts 20 photos | You have no profile entry, so difficult to suggest a local supplier. I use ABC for all my belts and mostbearings. Plenty of belts available from lots of suppliers on the ‘net. How about arranging for the motor to trip if it is overloaded? |
andrew lyner | 17/11/2018 23:42:05 |
274 forum posts 5 photos | I must update my profile (I live in West Essex aamof) but I haven't found anywhere local for these things. I mostly use eBay for bits and bobs but I don't know how to specify a belt and the ones I have seen seem to be only 8mm wide for mini lathes. Mine is 10mm wide. I did try on e enquiry but he said he couldn't help me. The idea of an electrical cut-out is attractive. I was wondering how to detect a speed drop that would operate faster than the simple rev counter that's on the machine already. There is probably a good mod that can be done on the brushless motor control directly. I would like to know how to avoid jams better in the first place, though. I am, much better at parting off these days. I make sure the carriage is locked down, the gibbs strips are not sloppy and I regularly sharpen the blade. It may be I am too chicken to run at a fast enough speed, perhaps. |
Jeff Dayman | 18/11/2018 03:38:20 |
2356 forum posts 47 photos | How wide is your parting blade? a narrower one will reduce load on your belt. If parting is the only op that strips your belts it might be wiser to use a hacksaw or portable bandsaw to part off. Use a saw only with the lathe stopped, for safety. No shame in parting by sawing . If using a saw in the lathe take a bit of time beforehand to make a wood or sheetmetal guard for the bed below your cut, in case saw breaks or drops through the cut unexpectedly. If you are stripping belts on other ops you may need to think about getting a second much bigger lathe! |
Hopper | 18/11/2018 04:28:26 |
![]() 7881 forum posts 397 photos | Have you tried running the parting tool upside down so the chips fall out (with lathe running in reverse of course)? Carriage and topslide locked in position while parting off? |
David George 1 | 18/11/2018 07:02:54 |
![]() 2110 forum posts 565 photos | Hi Andrew when you are parting off using a part off tool in the normal toolpost it puts a stress on the slides and ways as the force is trying to rotate the toolpost. The usual part off toolholder sticks out to the side and gives a slight more rotational force and if any play it multiplies the force as it grabs. If you have a rear toolpost with tool upside down,for parting off, the force is contained within the main carriage with no chance to twist the toolpost and then grab. Does this help, in a larger lathe it is much more sturdy so less of a problem. David Edited By David George 1 on 18/11/2018 07:03:53 |
jann west | 18/11/2018 09:02:41 |
106 forum posts | on the topic of parting off ... parting off tools can be very finnicky about being 100% dead on perpendicular ... even a little out and the deeper you go the more you rub on the side. Also, topslide rigidity is a concern in minilathes! |
Brian G | 18/11/2018 09:11:48 |
912 forum posts 40 photos | It sounds like your belt is way too slack (especially if you can fit it without adjusting the motor position). My son's machine had the same issue, with the belt slipping on deep cuts or parting off. Unless anything dramatic has changed between Warco's mini lathe and super mini lathe, there won't be any adjustment mechanism visible when the motor cover is removed, as the motor slides up and down, rather than pivots. Remove the four screws holding the control box on the front of the lathe and move it to one side so you can see the motor bolts in their vertical slots. It is a couple of years since I did it but I am pretty sure I removed the motor cover at the rear as well in order to hold the motor when adjusting. It is important to ensure that when you tension the belt the motor remains level or the belt will not run true on the pulleys. In the absence of any tensioning instructions I tightened it until I could just turn it 90 degrees, at which point there was no more resistance than turning the motor without the belt. Since then there has been no sign of bearing wear and no slipping, so that is probably about right. Brian |
larry phelan 1 | 18/11/2018 09:38:30 |
1346 forum posts 15 photos | Parting off ! The old foe,once again ! I find that the rear post does help a lot [most times ] |
SillyOldDuffer | 18/11/2018 09:47:03 |
10668 forum posts 2415 photos | My first thought was you're expecting too much of the lathe Andrew. Parting off is notoriously difficult and it's harder to do on small light machines than big heavy ones. But snapping a belt is unusual, and breaking two suspicious. On second thoughts, I wonder if you've got a combination problem:
The website is down at the moment so I can't provide a working link or check it makes sense but I think www.mini-lathe.com has a good description of how to adjust the belt. Dave PS I see while I've been typing slowly and slurping coffee that Brian got in first with the same point.
Edited By SillyOldDuffer on 18/11/2018 09:50:47 Edited By SillyOldDuffer on 18/11/2018 09:53:31 |
andrew lyner | 18/11/2018 10:56:04 |
274 forum posts 5 photos | Thanks for all the responses. Of the possible causes, I don't think it's my being heavy handed as I am on the timid side. I get the blade well lined up at right angles and re-adjust the compound on the go, to stop the blade touching the sides. It's a narrow blade, of course and it cuts very convincingly when it does cut. It really could just be failure to clear the swarf. This last time, there was a really solid ball, jammed / welded in the slot which I had difficulty clearing manually - going in alternate directions until it loosened. The speed was only about 350rpm. An upside down blade may help me out and I can easily try that at no extra cost(!).
andrew lyner | 18/11/2018 11:17:10 |
274 forum posts 5 photos | Posted by Brian G on 18/11/2018 09:11:48:
It sounds like your belt is way too slack (especially if you can fit it without adjusting the motor position). My son's machine had the same issue, with the belt slipping on deep cuts or parting off. Brian The belt was tight enough to need to remove the top sprocket to fit it. But I will still address the tension problem. I was searching for info on rear tool posts and came across this link. There are some valid sounding arguments against mounting tools in a way that lifts the cross slide off the bed. I shall investigate height and angle of the cutting face |
SillyOldDuffer | 18/11/2018 13:35:23 |
10668 forum posts 2415 photos | A few comments Andrew:
For what it's worth, I found parting off on a mini-lathe to be a challenge to the extent I avoided doing it unless essential. The lathe was OK parting off brass, but Aluminium and Steel both needed extra care in different ways. As the lathe is light and bendy, parting off requires the operator to have good judgement. Fortunately for foolish old me, quite often it wasn't a problem to remove the job from the lathe, saw it, and then pop it back on the lathe to tidy up. Parting off is much easier to do on a heavier lathe. Upgrading to a WM280 reduced my front-post parting-off failures by at least 90%. Fitting a rear tool-post, which is easy to do because the saddle has T-slots, made parting off almost fool-proof. Now when it goes wrong, it's almost always obviously my fault. (Like optimistically cutting a bendy rod too far away from the chuck.) Dave |
Neil Wyatt | 18/11/2018 16:21:17 |
![]() 19226 forum posts 749 photos 86 articles | I'm not familiar with the adjustment on the Warco Super Mini, assuming that (a) you have a toothed belt and (b) its similar to other mini lathes, then adjustment is by moving the motor. Some machgines have a push-puill arrangement fo screws under the headstock, but the super mini may be different. The screeching is the toothed belt slipping and this will rapidly degrade both belt and any nylon pulleys. You need to get the tension so high you can just twist the belt 90 degrees between finger and thumb. If the motor pulley is worn, you may be able to extend its life by reversing it though spare should be available. If the tension and pulley alignment are good then the belts should last several years of frequent hobby use. Neil
Neil Wyatt | 18/11/2018 16:26:45 |
![]() 19226 forum posts 749 photos 86 articles | Posted by andrew lyner on 18/11/2018 10:56:04:
Thanks for all the responses. Of the possible causes, I don't think it's my being heavy handed as I am on the timid side. I get the blade well lined up at right angles and re-adjust the compound on the go, to stop the blade touching the sides. It's a narrow blade, of course and it cuts very convincingly when it does cut. It really could just be failure to clear the swarf. This last time, there was a really solid ball, jammed / welded in the slot which I had difficulty clearing manually - going in alternate directions until it loosened. The speed was only about 350rpm. An upside down blade may help me out and I can easily try that at no extra cost(!). Depending on diameter 350rpm sounds high for HSS. Being timid is the main reason for people having failures with parting - the tool chatters, the instinct is to reduce the infeed and it rubs then blunts or grabs and... Better to keep the speed modest and the infeed nice and steady - have confidence. This is true of all sizes of lathe. Don't move the blade sideways while cutting, that's a real recipe for a dig-in. If you want to do this retract the tool before moving it sideways. Neil |
andrew lyner | 18/11/2018 16:27:16 |
274 forum posts 5 photos | Posted by Neil Wyatt on 18/11/2018 16:21:17: The screeching is the toothed belt slipping and this will rapidly degrade both belt and any nylon pulleys. Neil
Luckily, the sprockets are steel. I know there's no shame in using a hacksaw but parting off is something I'd like to be capable of but not at £20 per failure. |
andrew lyner | 18/11/2018 16:29:47 |
274 forum posts 5 photos | @Neil "Don't move the blade sideways while cutting, that's a real recipe for a dig-in. If you want to do this retract the tool before moving it sideways." I only move it to stop it from drifting to the side of the cut. But where is the drift coming from if the carriage is locked and the blade is square on? (I ask myself. - there's a lot to learn here, I think.) |
mechman48 | 18/11/2018 16:50:58 |
![]() 2947 forum posts 468 photos | Obvious questions but; have you got the tool on centre height, do you have enough back rake on your tip ( HSS ? ) so that the swarf 'curls' up & out of the slot. you say you have paraffin as coolant, are you parting off aluminium in which case you need to up your rpm as 350 rpm will heat up the aluminium & make it stick. Not having a mini lathe ( I have a WM250V-F ) I assume that there is no auto X feed & you are feeing in by hand, can you 'feel' what the tip is doing, you should be able to 'feel if you are feeding in too fast / slow... adjust accordingly. |
Ron Laden | 18/11/2018 17:15:04 |
![]() 2320 forum posts 452 photos | Andrew, Though it is no consolation you are not alone, I think most beginners go through this when they first try parting off, I certainly did. My CJ18 lathe is pretty much the same as your machine except mine is not brushless and it currently has no low gear range, I only have the top range. I had a couple of stalls when parting off and the second time the low gear change wheels which are nylon gave way. I still have to get replacements and fit them, something I am not looking forward to as the head needs to be stripped down. Its a while since I did any parting off but I did get to a stage where I was reasonably ok with it. Like most beginners I guess I was just too timid, taking tiny cuts and hesitating at every change in sound or the slightest hint of chatter. Then some of the guys here on the forum told me to keep cutting, keep feeding into the cut, dont go mad but keep cutting and that did work for me. I think once you have had one or two failures it does knock your confidence though which makes you nervous and hesitant the next time you do it. At the end of the day Andrew I guess all we can do is keep at it and learn from what works and what doesnt and hopefully it will come together. Ron
Martin Connelly | 18/11/2018 17:20:24 |
![]() 2549 forum posts 235 photos | Here's a calculation to consider. If you cut at 0.005" per rev how fast does the tool have to move in at 350 rpm. Are you going anywhere near this speed? 200 revs requires a movement of 1" in just over 34 seconds. If you are not power feeding then this is whst you need to consider when turning that handle. Martin C |
