Double diamond tool
An unusual lathe tool
John McNamara03/11/2018 04:26:30
1377 forum posts
133 photos
Hi All
I stumbled on this post on You Tube **LINK**
Cam at battler is an Australian you tuber that does some pretty impressive work, in this case a slotter. It would make a great series for MEW
An interesting shop built lathe tool, easy to make too.
john
Rod Ashton03/11/2018 06:32:58
344 forum posts
12 photos
Would be interesting to know exactly how the double diamond fits onto the carrier bar. Screwed or spigoted or both?
Anthony Kendall03/11/2018 09:07:00
178 forum posts
Apologies, but couldn't resist it. I'll get my coat!
peak403/11/2018 12:07:28
2207 forum posts
210 photos
And here's the link on his channel for the universal tool;
Bill
Rod Ashton03/11/2018 12:54:19
344 forum posts
12 photos
Off to draw that up. Thanks
Neil Wyatt03/11/2018 15:28:47
19226 forum posts
749 photos
86 articles
Posted by Rod Ashton on 03/11/2018 06:32:58:
Looks like a smaller conventional diamond shaped insert at each end held with a screw.
Can't see what it does at the back that you can't do with ordinary tools at the front.
I suppose Double Diamond works wonders...
Bazyle03/11/2018 18:40:36
6956 forum posts
229 photos
If set up as he mentions with different tips it saves one quick change holder, It perhaps could be used as a way of doing quick changes itself. It would be a great way to interchange screwcutting tips without having to have a complete qctp holder for each one.
Clive Foster03/11/2018 20:06:01
3630 forum posts
128 photos
The commercial Impero tool-post system included similar double tool-tip devices albeit (apparently) more versatile in being capable of setting at different angles.
See **LINK** and **LINK**.
Doesn't look to be an inexpensive set-up but seems to have been on the market for at least a decade so there must have been sufficient practical virtue in the tooling set-ups for hard headed commercial shops to buy the sets. Especially as the system doesn't handle common square shank tooling and bits as well as more conventional QC systems. I imagine that, as usually with odd-ball equipment, you need to rethink the way you approach jobs to get the best out of the system.
Michael Gilligan03/11/2018 20:39:10
23121 forum posts
1360 photos
Posted by Neil Wyatt on 03/11/2018 15:28:47:
It's worth watching the video that 'peak4' linked, Neil
Vic03/11/2018 21:55:26
3453 forum posts
23 photos
Interesting. No longer available because few were sold says it all really. I can see it would be useful if you only use a four way tool post - it could save you quite a lot in tool holders. Not quite so useful if you use a QCTP. I’ve actually got a double sided insert tool holder for left and right cutting but must admit I’ve never turned it over! 😊
John McNamara04/11/2018 03:26:42
1377 forum posts
133 photos
Hi All
Another variation on the theme
Ball indexing added, a kind of Hirth coupling it will be very accurate.
https://www.google.com.au/search?q=hirth+coupling&rlz=1C1ASUT_enAU791AU791&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi7up7-5bneAhUFNo8KHSIKAnIQ_AUIDigB&biw=838&bih=501
Edited By John McNamara on 04/11/2018 03:30:15
BW04/11/2018 06:36:23
249 forum posts
40 photos
MEW November 2016 page 35
Fairly similar idea by a chap called Richard Smith documented over 2 issues. Have been wondering for a while now about having a go.
Bill
Cam McKeown04/11/2018 06:50:40
5 forum posts
G'Day all, my name is Cam, just joined but look in from time to time as a casual observer. I posted the YouTube video on the multi angle tool holder that I purchased a number or years ago. I had some comments that there was interest asking for some more infomation so if you have any questions ping back to me.
Cam
Michael Gilligan04/11/2018 08:33:26
23121 forum posts
1360 photos
Posted by Cam McKeown on 04/11/2018 06:50:40:
G'Day all, my name is Cam [ ... ] if you have any questions ping back to me.
Welcome, Cam
First question is about the post locking: There appears to be a flat-ended pushrod, locking a close-fitting post into its hole ... so have you seen any probems with bruising of the post ?
Some comments on choice of materials and tolerances would probably be useful.
Thanks
Nick Hulme04/11/2018 12:03:37
750 forum posts
37 photos
How is a tool with Diamond Inserts a "Slotter" ?
For anyone with a big lathe having a tool-holder mounted on a tool-holder is a (very) limited alternative to a rear tool post, but a rear tool post is a far more useful and capable option, especially with matching front & rear QCTPs.
Michael Gilligan04/11/2018 12:12:21
23121 forum posts
1360 photos
Posted by Nick Hulme on 04/11/2018 12:03:37:
It isn't ... The tool is featured part way through episode 21 of a series
Oldiron04/11/2018 12:31:38
1193 forum posts
59 photos
Hi Cam. Welcome to the forum. I follow your channel. Very interesting. See you on Emma's live show chat sometimes.
regards
Cam McKeown04/11/2018 13:01:47
5 forum posts
Hi Michael, the tool is probably a chrome moly at around 30 RC. It doesn't look like it has had any heat treatment other than the blueing as I can touch it with a file. The post is a nominal 12mm in diameter with a 0.03mm clearance on the hole. The pin is a precision ground dowel at 3/8" diameter and 2 1/4" long. As I mentioned in the Video I've given this tool an absolute hammering over the years and has not failed me once. I cannot see any visible deformation of the "post" from the dowel locking onto it.
Hi Nick, no a diamond tool is certainly nothing like a slotter. I had a number of requests during the "Powered Lathe Slotter" build series to give a description of how it works and how it is put together. I included this description as part of episode 21. As I mentioned, it is extremely versatile and very quickly adapted to suit both left hand and right hand turning, facing, counter boring up to 5mm deep and even thread cutting, all without having to touch the tool post. I find that sometimes a build series like this can get a bit dry and even a bit boring at times, so its good to throw in some other content. I'll be putting a short session together on 3D modelling, coding and 3D machining shortly on a curved spoked flywheel for a small Stuart Turner engine Emma from Emma's Spare Room is building.
Michael Gilligan04/11/2018 15:51:47
23121 forum posts
1360 photos
Posted by Cam McKeown on 04/11/2018 13:01:47:
Thanks for the detail, Cam
GoCreate04/11/2018 17:08:42
387 forum posts
119 photos
Here's another interesting variant by ROBRENZ a master at his art.
Nigel
