A video of my completed Howell Twin 4 stroke model engine
CorRad | 28/03/2018 02:19:29 |
19 forum posts | I have completed building the Howell Twin 4 stroke. The link below takes you to a video of the completed engine: Edited By Neil Wyatt on 28/03/2018 10:42:25 |
Michael Gilligan | 28/03/2018 08:36:17 |
![]() 23121 forum posts 1360 photos | Presumably because YouTube 'knows' that I am using an iPad ... using your URL takes me to https://m.youtube.com/watch?feature=youtu.be&v=F44qslr_AEA ... and that displays a black window with white text, stating: This video is unavailable
Edited By Michael Gilligan on 28/03/2018 08:37:54 |
Perko7 | 28/03/2018 08:43:15 |
452 forum posts 35 photos | Found it at this address: https://www.youtube.com/watch?v=F44qsIr_AEA |
Michael Gilligan | 28/03/2018 09:36:39 |
![]() 23121 forum posts 1360 photos | Posted by Perko7 on 28/03/2018 08:43:15:
Found it at this address: https://www.youtube.com/watch?v=F44qsIr_AEA . Thanks That one works https://www.youtube.com/watch?v=F44qsIr_AEA MichaelG. Edited By Michael Gilligan on 28/03/2018 09:37:34 |
Joseph Noci 1 | 28/03/2018 09:41:07 |
1323 forum posts 1431 photos | Hello Corad. Brilliant Engine! Runs great and looks fantastic. Very well done, and certainly done in a short time! While looking at the video, I saw this one...Amazing how inventive folk are! Joe https://www.youtube.com/watch?v=eKY-UNYdDHE Edited By Joseph Noci 1 on 28/03/2018 09:41:54 |
CorRad | 28/03/2018 10:37:00 |
19 forum posts | Apology for the problem with the link. I typed the address in stead of copying the link as a hyperlink. The link below works. Thank you Joe I enjoyed the building. The engine made from car scrap is certainly very innovative.
Neil Wyatt | 28/03/2018 10:42:55 |
![]() 19226 forum posts 749 photos 86 articles | Embedded it. Nice work Conrad! Neil |
not done it yet | 28/03/2018 10:54:27 |
7517 forum posts 20 photos | Is it fuelled by metanol in order to run cooler? I note there is no forced air cooling. I think the advantages of a shorter, stiffer crank is better in the V formation, rather than a 360 degree crank in an in-line configuration. Nice work and runs well. |
Trevor Crossman 1 | 28/03/2018 11:18:46 |
152 forum posts 18 photos | Congratulations CorRad, your result of six months labour looks and sounds very good indeed. Trevor. |
CorRad | 28/03/2018 11:30:20 |
19 forum posts | Methanol is used primarily because the emissions are much cleaner. There are two 50mm diameter computer style cooling fans on the front of the engine aimed at the heads. The drawings actually calls for a sheath over these fans that result in much more effective cooling. However, the look of the engine without these sheaths appeals more to me. The longest time that I have run the engine continuously was for 10 minutes. The heads certainly did get relatively hot but not to the extend that it was considered a problem. Should I want to run this engine for long periods, I will certainly have to add these sheaths. I agree with your remark regarding the short crank. |
daveb | 28/03/2018 17:24:52 |
631 forum posts 14 photos | CorRad, very nice indeed! Daveb |
John Rudd | 28/03/2018 20:27:48 |
1479 forum posts 1 photos | Does the starter motor remain engaged while the engine runs? |
CorRad | 28/03/2018 21:05:58 |
19 forum posts | Good question. When I had to make decisions about the starter motor, this did worry me. Yes, the starter motor remain engaged after the motor has started. The life time of the starter motor bushes is therefore in question. However, this allows the starter motor to be used as a dynamo to charge the battery. |
John Rudd | 28/03/2018 21:41:16 |
1479 forum posts 1 photos | Posted by CorRad on 28/03/2018 21:05:58:
Good question. When I had to make decisions about the starter motor, this did worry me. Yes, the starter motor remain engaged after the motor has started. The life time of the starter motor bushes is therefore in question. However, this allows the starter motor to be used as a dynamo to charge the battery. Just be careful that the engine does not over rev the starter motor....there is a risk of bursting the windings on the armature....I know...I have done it on a car! The starter got jammed with the flywheel gear... |
CorRad | 28/03/2018 22:11:50 |
19 forum posts | Good question. When I had to make decisions about the starter motor, this did worry me. Yes, the starter motor remain engaged after the motor has started. The life time of the starter motor bushes is therefore in question. However, this allows the starter motor to be used as a dynamo to charge the battery. Just be careful that the engine does not over rev the starter motor....there is a risk of bursting the windings on the armature....I know...I have done it on a car! The starter got jammed with the flywheel gear... Thanks for that information. |
Ian S C | 29/03/2018 10:34:46 |
![]() 7468 forum posts 230 photos | A car starter motor is usually between 15:1 and 20:1, where as the starter on CorRad's motor is nearer to 4:1. Ian S C |
CorRad | 29/03/2018 11:46:57 |
19 forum posts | Correct Ian S C. Initially, this caused a problem in that the starter motor does not have enough torque to turn the engine when it is one of its compression strokes. In order to start the engine using the mopet starter motor, I have to manually turn the flywheel in the opposite direction that it normally runs, until a compression stroke is reached. When the starter motor is energised it can then build some momentum before a compression stroke is reached. This works fine and the engine is easily started as can be seen on the video. |
thaiguzzi | 29/03/2018 15:35:20 |
![]() 704 forum posts 131 photos | Impressive, pretty, like it. |
Ian S C | 30/03/2018 10:33:23 |
![]() 7468 forum posts 230 photos | Starter motors are usually series wound, so not ideal as a battery charger, but a modern starter may have permanent magnet fields. A generator for battery charging with wound fields needs to be shunt wound. Ian S C |
CorRad | 04/04/2018 02:58:07 |
19 forum posts | I have uploaded two videos of my other completed engines. The links are below: https://youtu.be/_PH-iE7YmdY https://youtu.be/bZX-ajNffrY
Edited By JasonB on 04/04/2018 07:20:50 Edited By JasonB on 04/04/2018 07:43:11 |
