fizzy | 24/03/2018 08:54:24 |
![]() 1860 forum posts 121 photos | My old stamp is broken, place I bought it from no longer exists so I need a new one - any suggestions as I cant find an off the shelf one on internet? |
MichaelR | 24/03/2018 09:07:25 |
![]() 528 forum posts 79 photos | Is this any help **LINK** Mike. |
fizzy | 24/03/2018 11:20:59 |
![]() 1860 forum posts 121 photos | Thanks Michael - thats exactly what Ive been looking for |
fizzy | 24/03/2018 11:23:43 |
![]() 1860 forum posts 121 photos | ahhhh...mine has top be 50mm minimum and their biggest is 10mm...I will give them a call!
Chris Gunn | 24/03/2018 16:07:14 |
459 forum posts 28 photos | Fizzy, why not get some name plates blanks with the CE mark laser cut in and stamp all the other info on before fitting. No need for a big punch then. Chris Gunn |
JasonB | 24/03/2018 16:27:56 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by fizzy on 24/03/2018 11:23:43:
Why do you need 50mm high characters for your little boilers? I would have thought 5mm would be quite adequate |
KWIL | 24/03/2018 17:08:52 |
3681 forum posts 70 photos | Chris, I would have thought that sticking a nameplate on would not be accepted as permanently marked. |
JasonB | 24/03/2018 17:09:50 |
![]() 25215 forum posts 3105 photos 1 articles | I've seen the plates tack welded to steel boilers, John Rex ones spring to mind.
Also seems good enough for Tornado Edited By JasonB on 24/03/2018 17:16:18 |
Neil Wyatt | 24/03/2018 17:24:35 |
![]() 19226 forum posts 749 photos 86 articles | "the CE marking is at least 5 millimetres - unless a larger minimum dimension is specified in the relevant directive." |
blowlamp | 24/03/2018 17:29:54 |
![]() 1885 forum posts 111 photos | I could have a go at CNC milling a punch for you, if you get stuck.
Martin. Edited By blowlamp on 24/03/2018 17:31:18 |
duncan webster | 24/03/2018 17:55:58 |
5307 forum posts 83 photos | You must use a damn big hammer to make a mark with a 50mm punch |
Meunier | 24/03/2018 20:43:19 |
448 forum posts 8 photos | Posted by duncan webster on 24/03/2018 17:55:58:
You must use a damn big hammer to make a mark with a 50mm punch No hammers Duncan. it's all down to "witchcraft" I believe. |
Chris Gunn | 24/03/2018 20:48:06 |
459 forum posts 28 photos | KWIL, my 4CD boiler has a plate just like I describe tack welded to the boiler. Most machinery has nameplates stuck on or screwed on, I have never seen anything with stamped CE marks, but then again I have never bought one of Fizzy's boilers. |
JasonB | 24/03/2018 20:57:01 |
![]() 25215 forum posts 3105 photos 1 articles | I knew I had seen a good photo on a model boiler, ones from AJB below. Bit bigger than Fizzy usually knocks out, these are 13" dia Edited By JasonB on 24/03/2018 20:59:09 Edited By JasonB on 24/03/2018 21:01:43 |
fizzy | 24/03/2018 23:39:50 |
![]() 1860 forum posts 121 photos | thank yolu all - i made a reading error. 5mm is the minimum, but the cheapest is still £50, thanks one and all
Neil Wyatt | 26/03/2018 21:30:15 |
![]() 19226 forum posts 749 photos 86 articles | Posted by fizzy on 24/03/2018 23:39:50:
Photo Etching? |
peak4 | 26/03/2018 23:07:36 |
![]() 2207 forum posts 210 photos | There's a few more firms in Sheffield who make stamps Mick Shaw at Portland works for one, or maybe Davidsons
Bill
Edited By peak4 on 26/03/2018 23:08:49 |
