mick70 | 14/03/2018 14:24:29 |
524 forum posts 38 photos | trying to find a 3ft rule with just imperial markings. it's going to inlaid into a bench my eldest daughter wants building for her design work. even though only 17 prefers what she proper measurements. similar idea to tailors bench. tried e-bay but no joy or not using right search words. |
larry Phelan | 14/03/2018 14:29:04 |
![]() 544 forum posts 17 photos | Might not be too easy to find,so I wish you luck. What,s wrong with Metric ? most clothing these days comes in Metric sizes anyway. |
KWIL | 14/03/2018 14:31:51 |
3681 forum posts 70 photos | Try this. |
mick70 | 14/03/2018 14:34:33 |
524 forum posts 38 photos | perfect thanks Kwil will get one ordered. even got imperial at top. Larry it's not for clothing it's design work she does and as grown up with me using old style measurements. Edited By mick70 on 14/03/2018 14:35:41 |
Speedy Builder5 | 14/03/2018 15:54:08 |
2878 forum posts 248 photos | Not exactly, but close ? |
Speedy Builder5 | 14/03/2018 15:58:18 |
2878 forum posts 248 photos | And a wooden one |
Chris Shelton | 14/03/2018 16:12:06 |
![]() 92 forum posts 46 photos | Hi a hunt for a yard stick on eBay turned this one up, item no 263270278507
HTH
John Reese | 14/03/2018 16:34:35 |
![]() 1071 forum posts | Have you considered self adhesive measuring tapes like this: |
Speedy Builder5 | 14/03/2018 17:02:59 |
2878 forum posts 248 photos | If the rule is for dressmaking, try to find a rule marked in 1/8" or 1/10" as smaller divisions would not be required. Perhaps ask if she works in 1/8 or 1/10" ?? |
Bazyle | 14/03/2018 17:33:14 |
![]() 6956 forum posts 229 photos | As a model engineer shouldn't you be getting a nice piece of brass strip and engraving it, using the lathe leadscrew to set the dimensions? |
Mike E. | 14/03/2018 20:01:44 |
![]() 217 forum posts 24 photos |
I found this stainless steel rule at Poundland or Poundworld several months ago here in Wales. The edges were very sharp, but smoothed up nicely when stoned. One inch wide, thirty thousandths thick, and forty inches long. Its Imperial on one edge of the scale reading in 16 ths. and the other edge in 10 ths. of an inch. On the reverse side its Metric. Couldn't go wrong for a pound considering they were much more expensive else where. I believe, but not sure, I have seen them also in a chain store here in South Wales called....... " What ". Edit: Sorry, for some reason I can't get photos to fall in sequence after my written post.
Edited By Mike E. on 14/03/2018 20:04:13 |
OldMetaller | 15/03/2018 08:02:11 |
![]() 208 forum posts 25 photos | How about an old boxwood folding carpenter's rule? You'd need to incorporate the brass hinges, but I think it would look nice. Regards, John. |
Douglas Johnston | 15/03/2018 09:39:26 |
![]() 814 forum posts 36 photos | I have a couple of 60cm poundland ones but the scales are not spot on in terms of accuracy. Not a problem for most work but almost 1mm difference over 60cm between the two rulers. |
SillyOldDuffer | 15/03/2018 10:29:18 |
10668 forum posts 2415 photos | hwebber.co.uk (as per KWIL's link) do nice brass counter scales including an imperial only model. £70 might be a bit much though. |
larry Phelan | 15/03/2018 11:22:52 |
![]() 544 forum posts 17 photos | Hi Mick 70, No offence intended. I too grew up with feet and inches,but had no bother getting used to Metric. Now I use both,which is the more suitable for the job. It,s just that if you mention feet and inches to young people now,they look at you as if you came out of the Ark ! [but even Noah did not use that system ] Nice to know that long rules like that are still around,have not seen any of those mentioned by Mike E although I would like to pick up one of them if they show up here. |
David Standing 1 | 15/03/2018 11:50:43 |
1297 forum posts 50 photos | Posted by larry Phelan on 15/03/2018 11:22:52:
Same here. And I have one imperial and one metric lathe, and one imperial and one metric milling machine, so I am lazy sometimes and do jobs on whichever one suits the dimensions or specification of the job in hand. |
mark costello 1 | 15/03/2018 13:17:16 |
![]() 800 forum posts 16 photos | Should have said something, I have several laying about and would gladly post one over. |
Howard Lewis | 16/03/2018 16:02:48 |
7227 forum posts 21 photos | Some of the D I Y stores do Metre long rules with imperial along one edge, and Metric along the other. Mine's Aluminium, but suffices for "near enough" jobs. Howard |
