C J | 05/03/2018 09:20:33 |
![]() 113 forum posts 86 photos | I somehow thought it would be easy to choose a MT2 live centre but find myself up against great swathes of unbranded items for sale online. Could someone recommend a good one for me. With thanks in advance |
ega | 05/03/2018 09:41:54 |
2805 forum posts 219 photos | Gepy (Swiss) - good but expensive. |
Michael Gilligan | 05/03/2018 09:57:59 |
![]() 23121 forum posts 1360 photos | Posted by ega on 05/03/2018 09:41:54: Gepy (Swiss) - good but expensive. . +1 ... actually, make that +2 Male and female versions are both superb. MichaelG. http://www.model-engineer.co.uk/sites/7/images/member_albums/79913/567176.jpg http://anglo-swiss-tools.co.uk/gepy-centres-spindles/
Edited By Michael Gilligan on 05/03/2018 09:59:47 |
Emgee | 05/03/2018 10:01:01 |
2610 forum posts 312 photos | Not as expensive but work well are Skoda. Emgee |
JasonB | 05/03/2018 10:08:39 |
![]() 25215 forum posts 3105 photos 1 articles | I'm happy with my SKoda too, they have quite a slim body which is good for getting in close. |
C J | 05/03/2018 10:26:30 |
![]() 113 forum posts 86 photos | Thanks for the posts. Having checked, I appreciate the design of the Gepy and like the slimness of the Skoda yet want still something a bit cheaper than £105.29 or am I seeking a false economy? Edited By C J on 05/03/2018 10:27:02 |
C J | 05/03/2018 10:36:53 |
![]() 113 forum posts 86 photos | I've just found a better price for a Skoda LC £64.97 this is more like it. |
Lambton | 05/03/2018 10:48:45 |
![]() 694 forum posts 2 photos | + for Skoda.
C J | 05/03/2018 10:49:47 |
![]() 113 forum posts 86 photos | Yep!
ega | 05/03/2018 11:01:34 |
2805 forum posts 219 photos | MichaelG: Thanks, as so often, for the definitive link. So far as I could see, however, the makers do not specify the type, etc of the "OEL" which should be used to lubricate. In the Centres PDF they say that most modern lathes are equipped with taper roller bearings (presumably, to the spindle). I know very little about modern machines and wonder how true the statement is today. |
Thor 🇳🇴 | 05/03/2018 11:23:52 |
![]() 1766 forum posts 46 photos | Another vote for Skoda, I bought mine many years ago and it is still working very well. Thor |
Neil Wyatt | 05/03/2018 11:48:19 |
![]() 19226 forum posts 749 photos 86 articles | Posted by ega on 05/03/2018 11:01:34:
In the Centres PDF they say that most modern lathes are equipped with taper roller bearings (presumably, to the spindle). I know very little about modern machines and wonder how true the statement is today. Virtually all modern lathes except the smallest have taper rollers. Neil |
John Haine | 05/03/2018 11:52:08 |
5563 forum posts 322 photos | But not Myfords... |
John Haine | 05/03/2018 11:58:39 |
5563 forum posts 322 photos | Unless you are going to be using your rolling centre every day I would just go for one from a reputable hobby supplier - I got mine from Arc IIRC and it's just fine for what I want. The worst that can happen when you get it is it's not quite running true, but a reputable supplier such as Arc would replace it without question in that case. From Arc an MT2 live centre is ~£19. |
Andrew Johnston | 05/03/2018 12:09:30 |
![]() 7061 forum posts 719 photos | Mine is Skoda, so far so good. I don't use it a lot, but it has a hard life when I do use it. I started with a cheap hobby grade one, can't remember where from. Hopeless, it failed within a couple of years, locked up solid. I don't know if it was the bearings breaking up, or the seals were poor and it let swarf into the internals. I turn a lot of cast iron, the swarf gets everywhere. Andrew |
David Standing 1 | 05/03/2018 12:34:16 |
1297 forum posts 50 photos |
Posted by Neil Wyatt on 05/03/2018 11:48:19:
In the Centres PDF they say that most modern lathes are equipped with taper roller bearings (presumably, to the spindle). I know very little about modern machines and wonder how true the statement is today. Virtually all modern lathes except the smallest have taper rollers. Neil Posted by John Haine on 05/03/2018 11:52:08:
But not Myfords...
But, being a 70 year old design, you would be stretching anyone's imagination to call a Myford a 'modern lathe'. However, playing the pedant card, my Myford 254S has a taper roller bearing supported spindle, not all Myford's are created equal
Edited By David Standing 1 on 05/03/2018 12:36:02 |
Ian S C | 05/03/2018 12:55:36 |
![]() 7468 forum posts 230 photos | I'm on my second Skoda, the first one got some heavy work and eventually the bearings collapsed, and although the supplier could overhaul it, it ended up quite a bit cheaper to buy a new one, this one should see me out, not having such a hard time. Ian S C |
John Haine | 05/03/2018 13:27:43 |
5563 forum posts 322 photos | Maybe we should have a "criticise Myford" thread just to save other threads being derailed... |
Michael Gilligan | 05/03/2018 13:31:55 |
![]() 23121 forum posts 1360 photos | Posted by ega on 05/03/2018 11:01:34:
MichaelG: Thanks, as so often, for the definitive link. So far as I could see, however, the makers do not specify the type, etc of the "OEL" which should be used to lubricate. . Mine get a drop or two of 'light spindle oil' occasionally. I bought them secondhand, nearly 30 years ago, and it doesn't appear to have been a bad choice. MichaelG. |
Ian P | 05/03/2018 13:42:05 |
![]() 2747 forum posts 123 photos | Posted by John Haine on 05/03/2018 11:58:39:
Unless you are going to be using your rolling centre every day I would just go for one from a reputable hobby supplier - I got mine from Arc IIRC and it's just fine for what I want. The worst that can happen when you get it is it's not quite running true, but a reputable supplier such as Arc would replace it without question in that case. From Arc an MT2 live centre is ~£19. There is another item to add to the 'worst that can happen' category. I have several revolving centres one of which is a no-name version which I don't use very often partly because of its bulk, but mainly that its revolving part is not concentric with the MT2 shank! Ironically the rotating part runs very true to its bearings (which are probably very substantial) so it come in handy when using the tailstock pressure to grip a part being machined I use a Skoda MT2 quite a bit but its MT2 shank is quite short so does not get ejected without a bit of a faff. Ian P |
