Centre punches/bench tools
Tractor man17/01/2018 10:00:54
426 forum posts
I bought these from H.roberts measuring tools, to be honest to make up my order to get free delivery.
The smallest punch was listed as a prick punch but the ones I have seen are different in design.
The scriber is nice and big compared to the usual eclipse ones.
And the 8 inch rule is a super flexible one useful for the lathe.
Anyone have preferences of bench tooling?
Hopper17/01/2018 12:19:45
7881 forum posts
397 photos
Oooh, 8 inch rule, I haven't come across one of them before. Looks right handy. Just when I thought I had all the tools I'll ever need...
Muzzer17/01/2018 12:31:26
2904 forum posts
448 photos
Posted by Tractor man on 17/01/2018 10:00:54:
I've seen a few of those given out for free, usually in pub carparks around closing time. I've never been offered one but I know a few who did. From what I heard, it didn't sound as if there was a lot going for them.
Murray
JasonB17/01/2018 13:02:47
I much prefer my 8" rule over the 6" ones, B&Q had them several years ago for 99p and I got several
not done it yet17/01/2018 14:22:32
7517 forum posts
20 photos
I think it is a metric ruler - the imperial scale is the inferior one (they used to be the superior scale - which meant drawing, or marking, a line using the device was more difficult if wanting a metric length!).
Tape measures were the same for a long time (and might still be) after metrification - a pita to use for metric measurements - and it was difficult to even find a metric-only tape for quite some time afterwards.
Vic17/01/2018 14:45:44
3453 forum posts
23 photos
A Mitutoyo Eight inch rule! Now if they did a 200mm only one I might be interested. smiley
Tractor man17/01/2018 14:58:26
426 forum posts
Not sure if I should mention this but I did get a rather nice calendar with said tools featuring some tastefully attired females of the womanly kind. Now I thought this sort of thing had been banned by the PC brigade. But I have the evidence to the contrary hanging on my workshop wall. SWMBO not over impressed but she only goes in there to drop off my tea lol
Mick B117/01/2018 16:40:35
2444 forum posts
139 photos
Is the second from left an automatic? If so, I'd be interested in how well such a slim point survives use on steel. All the ones I've had tend to either blunt if they're soft or chip if they're hard. I've made silver steel replacements with some success, but only after quite a bit of faffing about - it's not easy to strike a soft/brittle balance.
Muzzer17/01/2018 16:56:30
2904 forum posts
448 photos
In my experience with a branded example (Eclipse?), these can only be used effectively if you are standing almost next to a bench grinder. As you say, a soft / brittle balance. I expect a carbide scriber tip would just shatter.
Murray
Chris Evans 617/01/2018 18:28:06
2156 forum posts
Am I alone in very rarely using a centre punch ? I mainly mark out on the mill using the readout and a 1/4" diameter piece of tool steel spun to a concentric point for scribing and a spotting drill for starting/positioning holes.
Access to a cutter grinder or similar is required for the marking scriber but they last years.
Trevor Drabble17/01/2018 18:29:51
339 forum posts
7 photos
When I worked for James Neil (Eclipse ) we made the pocket scribers with either hardened or carbide points , and my two samples are still working well many years later . Perhaps things have changed now Eclipse is owned by a foreign company ?
Trevor .
Tractor man17/01/2018 20:16:56
426 forum posts
The prick punch I was thinking of is made of square tool steel with a barley sugar twist formed on the shank so that when you have picked up the scribed lines you twirl it between thumb and finger to produce a very fine mark that is followed up with a struck lunch then finally a centre punch.
I usually use an optical centre punch for very accurate laying out.
MW17/01/2018 21:09:34
2052 forum posts
56 photos
I have that automatic centre punch, it's a much better quality one than the £5 ones you see a lot. Definitely a good buy.
People might scoff at centre punches in a day of cnc but it isn't always practical or even possible to mount something on a milling table.
Michael W
Edited By Michael-w on 17/01/2018 21:11:47
roy entwistle17/01/2018 21:24:09
1716 forum posts
Some of us still do things the proper way using rules, squares, dividers etc and centre punches
Roy
DMB17/01/2018 22:28:46
1585 forum posts
8" rule?
I have been given a free 7" rule by one of our regular advertisers with my order. No makers name on it. Nice clear markings so I'm pleased with it and use it a lot in workshop.
Does seem very odd not to keep to traditional 6/12" for imperial measure rules.
Cannot understand failure to put name on a product that seems good/OK. Experience has shown that no name tools can be excellent to awful, no rhyme or reason.
Colin Heseltine17/01/2018 22:30:10
744 forum posts
375 photos
I've just centre punched 864 holes ready for punching out with 5mm punch on flypress.
I use one of the Eclipse automatic ones, but it is so painful on the hand after that quantity of dinks.
Admittedly it is in aluminium 1.5mm sheet. Trouble is I need a deep dink in order for the pointed tip on punch tool to locate correctly.
I'm on my third Eclipse punch, the mechanism seams to give up after several thousand uses.
I did find one of the larger size Eclipse automatic punches on which the tip can be unscrewed and changed, but I have never seen any of the alternate tips.
Colin
not done it yet17/01/2018 23:18:01
7517 forum posts
20 photos
Colin,
Do you make heavy duty meccano? smiley
Colin Heseltine18/01/2018 09:48:39
744 forum posts
375 photos
NDIY,
It feels like it sometimes. Over last few weeks cut up around 60 metres of Unistrut into pieces 12" or 20" long. The bandsaw, linisher all get lots of use and then finish filing by hand, then average of 6 holes in each piece. The aluminium I mentioned earlier all has corners radius cut on fly press. then partially rolled on Gabro folder once holes punched. My should takes a lot of stick on the flypress. then all rivetted together. Trouble is it don't get chance to use equipment for hobby use.
Colin
