Peter Simpson 1 | 09/01/2018 20:42:06 |
![]() 206 forum posts 9 photos | I realise that there have been several posts on bandsaws recently. Does anybody use the typical Sealey, Warco Axminster variations in the vertical mode, The tables fitted to these saws look flimsy to say the least. Has anybody retrofitted a decent quality table to the saws. Looking at photos of these saws there does not appear to be much metal around the blade area to secure a solid table. Femi sell optional table at £100 which seems very pricey.
daveb | 09/01/2018 20:54:56 |
631 forum posts 14 photos | I bought my saw from APTC, There was a note saying that EEC rules did not allow tables for vertical operation so this item was no longer supplied. There is not much to fit the table to, it fits to the end of the blade guide with 2 screws. I made a table 150mm square X 3mm, used it once, haven't seen it for ages. |
larry Phelan | 10/01/2018 10:36:28 |
![]() 544 forum posts 17 photos | Like Daveb,I too made a table for my saw,in order to cut some sheet steel. I was not impressed by either the speed or the ease of the operation. I considered it to be dangerous,even with the bigger table,so I never bothered with it again. Has anyone ever made a saw bench type cutter,using a metal cutting blade,at a slower speed,I should think? Just a thought ! |
Martin Kyte | 10/01/2018 10:49:45 |
![]() 3445 forum posts 62 photos | Axminster Trade Series BS11-INV BandsawI have a BS11-INV from axminster which works well for metal sheet and wood but then I was not really looking for a cut off saw. It's here on the web if anyone is interested. regards Martin |
Michael Cox 1 | 10/01/2018 10:55:29 |
555 forum posts 27 photos | I have made a small but more substantial table for vertical bandsawing on my Axminster 4 x 6 saw. I made the table smaller and hinged so that it can remain in position even when using the saw in the horizontal mode. I also made a detachable fence for the table to facilitate straight cuts. Because it is always on the bandsaw, ready for action, it gets used quite frequently. More details are here: http://mikesworkshop.weebly.com/bandsaw-table-and-fence.html For thin metal (<1.5 mm) it is necessary to feed slowly and steadily to avoid snatching and the possibility of breaking the teeth on the blade but it is only a matter of practice to develop a good technique. I prefer to use a nibble to cut thin sheet, see http://mikesworkshop.weebly.com/nibbler.html and http://mikesworkshop.weebly.com/a-nibbler-table.html |
larry Phelan | 10/01/2018 12:03:04 |
![]() 544 forum posts 17 photos | Hi Martin, I do have a vertical bandsaw,bought years ago for woodwork,and I have used it to cut sheet steel,from time to time. I just dont like the idea of getting metal chips embedded in the rubber tires of the wheels [very difficult to remove them ] I was thinking more along the lines of a circular saw,as used for woodwork [not a chopsaw ],perhaps running at a lower speed. I have cut Ali sheet on my benchsaw,so that,s what set me thinking.I know that the speed of my saw is much too fast,so perhaps a slower running machine ? I have never seen any such machine so I suspect it,s a non-starter. These are the kind of things which keep us busy ! |
Les Jones 1 | 10/01/2018 12:29:28 |
2292 forum posts 159 photos | I have built Michael Cox's modified tabe for a Clarke 4 x 6 bandsaw. It is much better than the original table. It is a very worthwhile modification. Les. |
RichardN | 10/01/2018 12:58:35 |
123 forum posts 11 photos | Posted by larry Phelan on 10/01/2018 12:03:04
Are you thinking of a larger version of the Myford saw table, as shown here which is modified for mini lathes? I have used a 4” square of 1/4” sheet clamped at suitable height with a block on top as a fence as a poor mans version of this which worked quite well... but relatively small capacity to suit my needs any S7... |
larry Phelan | 10/01/2018 13:32:34 |
![]() 544 forum posts 17 photos | Hi Richard N, Yes,something along those lines but bigger. Would be thinking about a table around 18" square with a long fence.. Still thinking !! |
Martin Kyte | 10/01/2018 13:45:02 |
![]() 3445 forum posts 62 photos | Posted by larry Phelan on 10/01/2018 12:03:04:
Hi Martin, I do have a vertical bandsaw,bought years ago for woodwork,and I have used it to cut sheet steel,from time to time. I just dont like the idea of getting metal chips embedded in the rubber tires of the wheels [very difficult to remove them ] The INV version I have runs slow for metal cutting. I run vacuum extract and that with the brushes and chip diverter seem to keep the chippings off the tyres. As I said I selected it because I wanted to use it for wood and sheet metal, mostly brass for clock plates. Some years ago I bought some compo brass sheet from GLR and was informed that it had been cut on a normal table saw so it can be done. I imagine with steel it would generate to many sparks to be safe. I'm not sure I would want to do brass either really! regards Martin
richardandtracy | 10/01/2018 14:04:17 |
![]() 943 forum posts 10 photos | Michael Cox's table mod looks very clever. I shall make one for my Clarke 6x4. Regards, Richard.
Kerrin Galvin | 11/01/2018 04:41:20 |
44 forum posts 9 photos | Hi Peter, If you check out my photos there’s a couple of photos of my table. Takes about 10 seconds to get on & off, “& best of all no tools required! Cheers Kerrin |
the artfull-codger | 11/01/2018 08:14:05 |
![]() 304 forum posts 28 photos | Although not the fastest machine but often underated is the meddings scroll/jig saw, I've just cut out some large radiused parts for our village church organ out of 2 inch brass Which it coped with easily,the real bonus is you can pick up bandsaw blades at autojumbles cheaply for either wood or steel etc they also cut inside shapes which a bandsaw cannot do (without cutting & rewelding the blade), I've cut 1/4 inch steel many times,as I say, not the fastest but l wouldn't be without mine. |
