sean logie | 31/12/2017 20:19:17 |
![]() 608 forum posts 7 photos | Just ordered one of these so here's hoping I get a good un
Sean |
John Haine | 31/12/2017 21:25:55 |
5563 forum posts 322 photos | It might help if you were more specific as to type and from where you ordered it? |
sean logie | 31/12/2017 21:49:10 |
![]() 608 forum posts 7 photos | https://www.ebay.co.uk/itm/Precision-3-Toolmakers-Vice/261742367730?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2648 |
not done it yet | 31/12/2017 22:33:29 |
7517 forum posts 20 photos | Mine is only 70mm and it came from our reliable supplier Arceurotrade. Perhaps a little more expensive (actually I doubt it) but no risk of getting a wrong un. Works well enough. Edited By not done it yet on 31/12/2017 22:50:07 |
Emgee | 31/12/2017 22:44:18 |
2610 forum posts 312 photos | Hi Sean Looks like a compact unit and look forward to your findings when set up and used. Emgee |
ChrisB | 31/12/2017 22:49:43 |
671 forum posts 212 photos | Whilst on the subject of milling vices, I'm after one for a WM18 mill but cant make up my mind. From most reviews on here it would seem the preferred ones are the DH-1, the Arc versatile, and the precision tool vice... I'm more inclined towards the versatile vice 80mm as it has the largest jaw opening compared to similar jaw sized vices. Not sure if its the right size for my mill tho. Sorry for the thread hijack Sean |
duncan webster | 01/01/2018 00:01:19 |
5307 forum posts 83 photos | The arc euro looks more useful as it has slots in the side to clamp it to the table. However, how do you move the jaw on either, I cant see any clamp screw. Or does the angled one somehow traverse the moving jaw. |
John Hinkley | 01/01/2018 00:13:11 |
![]() 1545 forum posts 484 photos | I, too, bought one from Arc Euro Trade, preferring the slots to anchor it to the table of the Perfecto shaper that I acquired recently. Works well and is ideally sized for the purpose.
Gray62 | 01/01/2018 01:19:34 |
1058 forum posts 16 photos | Posted by ChrisB on 31/12/2017 22:49:43:
Whilst on the subject of milling vices, I'm after one for a WM18 mill but cant make up my mind. From most reviews on here it would seem the preferred ones are the DH-1, the Arc versatile, and the precision tool vice... I'm more inclined towards the versatile vice 80mm as it has the largest jaw opening compared to similar jaw sized vices. Not sure if its the right size for my mill tho. Sorry for the thread hijack Sean I've owned a DH-1 for several years and for the majority of milling jobs, this is my goto vice, very versatile, has a bigger capacity than any other vice in the same footprint. Additional Jaws are well worth purchasing |
sean logie | 01/01/2018 06:46:03 |
![]() 608 forum posts 7 photos | Posted by duncan webster on 01/01/2018 00:01:19:
This will suit my needs , for it's compactness it' still has 4" jaw opening . There are slots underneath that a hardened Tee pin if you like sits in then you use the allen key to take up the slack by pulling down and towards the fixed jaw .
Sean |
JasonB | 01/01/2018 07:15:00 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by ChrisB on 31/12/2017 22:49:43:
Whilst on the subject of milling vices, I'm after one for a WM18 mill but cant make up my mind. From most reviews on here it would seem the preferred ones are the DH-1, the Arc versatile, and the precision tool vice... I'm more inclined towards the versatile vice 80mm as it has the largest jaw opening compared to similar jaw sized vices. Not sure if its the right size for my mill tho. Sorry for the thread hijack Sean The 90mm Type 2 from Arc is no bigger physically from the 80mm versatile but it will open up to 120mm ( 76mm versatile) and has deeper jaws. The only thing you don't get is the abilty to hold large items for gentle work that the extra jaw positions on the versatile allow. You can also see the hole for the key to tighten the precision ones. J
PS The e-bay seller Harryuk is Harry from Amadeal. Edited By JasonB on 01/01/2018 07:41:34 |
sean logie | 01/01/2018 08:05:49 |
I looked at the 76mm versatile ,the different clamping down positions was what I need also the extra jaw opening . I looked at loads of vices and it all became rather confusing in the end . Looked at a few youtube videos .....as you do
Happy New Year to everyone .
Sean |
ChrisB | 01/01/2018 08:48:35 |
671 forum posts 212 photos | Posted by JasonB on 01/01/2018 07:15:00:
The 90mm Type 2 from Arc is no bigger physically from the 80mm versatile but it will open up to 120mm ( 76mm versatile) and has deeper jaws. The only thing you don't get is the abilty to hold large items for gentle work that the extra jaw positions on the versatile allow. You can also see the hole for the key to tighten the precision ones. Alright, I thought the versatile could handle 205mm work, looking closer to the listing it says light work only in that config - as you say. Is the table size on your mill similar to a WM18 Jason? that is will a 90mm type 2 fit or it's too large? |
not done it yet | 01/01/2018 11:09:47 |
7517 forum posts 20 photos | “the fixed jaw has a slight curve accross the face”
Isn’t that what a milling machine is good at - milling things flat? |
Neil Lickfold | 01/01/2018 12:37:31 |
1025 forum posts 204 photos | For my cnc router , I brought a pair of Toolmakers vices, similar to what is listed , but from a local tool company. They are within 0.01mm everywhere to being the same. I mounted them onto a sub plate that has dowels to located the vice to. 3 pins , 1 is an end stop, and the other 2 are a side stop. These are spaced so that I can have the vices 25mm apart to a max of 200 mm between the 2 vices. The dowels are a neat slide fit for the side pins, so can be removed if required. I'm very happy with them so far and it's been 2 years now. The new vices all seem to have the short retaining pin that can be loosened off and then slide to the next hole point. The older ones used to have a through dowel that needed changing and that really was a pain at times. I used M8 capscrews for the end clamps, so the 6mm allen key does all the clamps and the vice jaw tightening. Mine also has M8 threaded holes for the side stops etc as well. Neil |
JasonB | 01/01/2018 13:08:22 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by ChrisB on 01/01/2018 08:48:35:
That is the table of the SX2.7 which is 140 x 590. Yes 90mm type 2 against the 80mm versatile both suit that size table, you may be able to go larger on your WM18 |
Jon | 01/01/2018 21:59:47 |
1001 forum posts 49 photos | Having had to replace another rebranded Versatile 5" from JLS that broke the back out i replaced with a 120 Type 2 and regretted every second with it. Personally i would risk the Versatile again and put two rows of off the shelf cheap bearings in about £2, wish i had.
Ian P | 01/01/2018 22:26:35 |
![]() 2747 forum posts 123 photos | Posted by Jon on 01/01/2018 21:59:47:
Must say that my experience with the Allen key type vice is the same. I bought one of the smaller ones because I thought it would be good for holding small components but I hardly ever use it. Two reasons, one is the step in the jaws which never seems to suit the part I am gripping, and secondly there is no method to secure the vice to the table so it has to be held in my main chuck, which sort of defeats the object. Ian P
Neil Lickfold | 01/01/2018 23:43:21 |
1025 forum posts 204 photos | Ian, That is why I made a sub plate to hold the vices with. The new ones have a sping and are very user friendly. I have never had the bottom nut come off yet at all. Neil |
Neil Lickfold | 01/01/2018 23:55:45 |
1025 forum posts 204 photos | I have since added some more hold down clamp holes and more dowel holes. The new holes were done in position after the plate was put in place.
