Ask and ye shall receive.....
richard 2 | 05/12/2017 16:53:00 |
127 forum posts | Have just read all the blurb on the Eccentric Engineering parting-off tool so am asking what other people think? I know there are a great many opinions and threads on this subject but I do like to ask before I spend a fair amount of money. My lathe is a Myford Super 7B with two rear tool posts - one a Myford which is a heavy block and the other is home-made taking a QCTP. Have looked at other makes and need a new p/o tool for the rear tool-post So suggestions, please. Many thanks richard 2 |
blowlamp | 05/12/2017 17:02:08 |
![]() 1885 forum posts 111 photos | Keep to a narrow tool on that size of lathe. I use a 2mm wide GFN style insert with positive rake geometry on my Mini-Lathe from the front toolpost, with no issues, so it should be fine with your setup.
Martin. |
Mick B1 | 05/12/2017 17:48:36 |
2444 forum posts 139 photos | I use a Chronos (I think) holder with a 1/16 x 5/16" HSS blade. It's cheap, adjustable, and easily does everything I can remember up to maybe 2 1/2" diameter - wood, delrin, brass, phosphor bronze, LG2, BDMS, titanium, silver steel. I can't see that I'd want anything better unless I started making batches of several tens or more - and then it wouldn't really be a fun hobby, would it?
ega | 05/12/2017 17:49:14 |
2805 forum posts 219 photos | Gary of Eccentric Engineering makes a persuasive case for his Front or Rear p/o toolholder. I bought one for use on my larger lathe but found the 2mm blades I opted for rather fragile and pricey (I believe he offers blades down to 1mm wide). I am now using a tangential insert tool from ISCAR. On the Myford, I long ago made the GHT rear toolpost and, by and large, it does everything I need. I had one of the KIT-Q-CUT insert tools from Greenwood Tools for a time; this worked well but I found the cost of replacement blades uneconomic. My personal preference is for p/o tools with minimum overhang on the Z axis. Edited By ega on 05/12/2017 18:01:14 |
ega | 05/12/2017 17:57:08 |
2805 forum posts 219 photos | Mick B1: Your impressive feat of parting off 2.5" dia silver steel with that blade makes the point that the "best" toolholder/blade and/or insert combination will be of little use on an unsuitable or badly-adjusted lathe; speeds, feeds and lubrication are also important. Edited By ega on 05/12/2017 17:58:39 |
Neil Wyatt | 05/12/2017 18:09:20 |
![]() 19226 forum posts 749 photos 86 articles | Greenwood have a new replacement for the Kit-Q-Cut coming soon, hopefully some news in the next MEW. Neil |
ega | 05/12/2017 18:31:51 |
2805 forum posts 219 photos | Posted by Neil Wyatt on 05/12/2017 18:09:20:
Greenwood have a new replacement for the Kit-Q-Cut coming soon, hopefully some news in the next MEW. Neil I shall read this with interest as I always thought the original design was rather basic. I hope the news will include information about the reasons for any changes. |
Mick B1 | 05/12/2017 18:50:22 |
2444 forum posts 139 photos | Posted by ega on 05/12/2017 17:57:08:
Mick B1: Your impressive feat of parting off 2.5" dia silver steel with that blade makes the point ... Well, I didn't mean to exaggerate, but I don't think I've ever seen 2.5" silver steel - that just got into the list through sloppiness on my part. But I have parted 60mm. EN8, and that can be quite argumentative... |
Vic | 05/12/2017 19:43:50 |
3453 forum posts 23 photos | I like the T shape blades that Chronos sell. They are the best parting blades I’ve used to date and I no longer feel the need to use expensive insert parting tools anymore. |
Geoff Theasby | 05/12/2017 19:49:44 |
615 forum posts 21 photos | I've just bought a Chinese tool costing £10, using MGMN200G inserts. I considered Greenwood, etc., but £70 is a lot to pay if it doesn't work. Even the competition at £30 is quite dear. Geoff |
Muzzer | 05/12/2017 20:04:41 |
![]() 2904 forum posts 448 photos | APT Tools also stock various MGMN-type grooving / parting tools in various widths from 1.5mm to 6mm. Their 2mm one is £15. These tools cut sideways as well as parting but the max parting depth is limited due to being double-ended. You can also get rounded "profiling" inserts and the inserts are available uncoated for aluminium machining. Murray |
Chris Evans 6 | 05/12/2017 20:09:39 |
![]() 2156 forum posts | I think it is more to do with the condition of the lathe than the tool. I use a 2mm tipped blade from ARC on a home made rear tool post. It works very well up to 2" diameter EN1A and well on smaller tougher stuff. After that it is operator wimping out and sawing rather than risking scrapping the work ! |
SteveI | 05/12/2017 20:27:30 |
248 forum posts 22 photos | Posted by ega on 05/12/2017 18:31:51:
That is interesting. I've been using the Greenwood Kit-Q-Cut for the last few years. It parts like a hot knife through butter, but I've worn it out, the holder is slightly bent and it no longer retains the tip. Due to the high cost I've now switched to GFN inserts and regular SGFH blade and holder. Steve |
richardandtracy | 05/12/2017 20:48:43 |
![]() 943 forum posts 10 photos | I bought an MGMN style toolholder + 4 double ended inserts for under £9 from e-bay seller cskwin2015. That was earlier this year. I have done a fair bit of parting with it (by my standards) and there have been a couple of times when I'd have expected my £9 HSS tool to shatter. No trouble from the MGMN tool even at 2mm wide on my Warco WMT300. So, have to back Muzzer's assessment, worth getting, but with limitations and benefits. Regards Richard.
Harry Wilkes | 05/12/2017 21:19:42 |
![]() 1613 forum posts 72 photos | I have one of the Eccentric Engineering parting-off tool mounted in the rear toolpost on my myford S7 best thing since sliced bread as far as I'm concerned ! Previously I was one of the guy's that struggled with part off but since fitting the Eccentric Engineering parting-off tool I don't have any problems. H |
Hopper | 05/12/2017 23:08:34 |
![]() 7881 forum posts 397 photos | Mate of mine bought a T shaped parting tool blade and holder from Eccentric. It has a strip of carbide along the top of the T. He uses it for putting circlip grooves in the outside diameter of hardened steel bearing races about 50mm diamter -- in a mini lathe. Can't complain about that for performance. |
Nick Hulme | 06/12/2017 00:14:46 |
750 forum posts 37 photos | For general parting and large work I use a Glanze holder with 3mm inserts in the front QCTP on my Super 7. Having the blade vertical and parallel to the slide travel are both critical to a good parting experience, good spindle bearing adjustment is a big help too. |
ega | 06/12/2017 10:15:09 |
2805 forum posts 219 photos | Posted by Hopper on 05/12/2017 23:08:34:
Mate of mine bought a T shaped parting tool blade and holder from Eccentric. It has a strip of carbide along the top of the T. He uses it for putting circlip grooves in the outside diameter of hardened steel bearing races about 50mm diamter -- in a mini lathe. Can't complain about that for performance. Hopper: I couldn't find this interesting item on the EE website. |
John Haine | 06/12/2017 10:41:41 |
5563 forum posts 322 photos | I use 2. One is a Kit-Q-Cut from Greenwood bought a long time ago which is excellent (in a standard Dickson QC holder), I think I'm on my second insert. The other is a rear p/o tool I got from Kirjeng that takes Dickson-style QC holders, and I have one designed for a wide blade 2.5mm wide. I grind this with a hollow in the top surface (made with a diamond needle file) to curl the chips in (like the Kit_Q-Cut).
They both work very well, but I use the kitqcut usually since the rear toolpost gets in the way and I can just put it on the Dickson post when I want to part off. |
Neil Wyatt | 06/12/2017 11:11:33 |
![]() 19226 forum posts 749 photos 86 articles | Posted by ega on 06/12/2017 10:15:09:
Mate of mine bought a T shaped parting tool blade and holder from Eccentric. It has a strip of carbide along the top of the T. He uses it for putting circlip grooves in the outside diameter of hardened steel bearing races about 50mm diamter -- in a mini lathe. Can't complain about that for performance. Hopper: I couldn't find this interesting item on the EE website. www.eccentricengineering.com.au/index.php?option=com_content&view=article&id=31&Itemid=45 |
