Sam Longley 1 | 24/10/2017 21:14:23 |
965 forum posts 34 photos | I bought an arbour at the Midlands exhibition & have been given a handful of 3mm saws. I went to use one today & was surprised that it would cut nothing. The blade is 80mm diameter, 3mm th, & tooth pitch is 8.5mm point to point. I wanted to form a tongue in the end of a piece of 9.5mm diam chromed steel shaft taken from a photo copier that I am using for the piston in a hand feed water pump for my traction engine. (where it joins a slot in the handle) If I ran the cutter slow ie 100RPM it just bounced off the steel & as I increased speed to 650 RPM it just created sparks Can someone advise me on the correct RPM for a saw of this diameter & tooth pitch please. I have several so will try others although this one seemed really sharp at first- It is HSS. I have not tried a milling cutter yet but it may be that the steel is very hard but i think not as it seemed soft in the middle when I cut it to length. It is just that I thought that i would try it out the saw as i could clamp the rod horizontally, take a slice of the top, drop the cutter down & take a slice of the bottom & leave the tongue in the middle nice & parallel Edited By Sam Longley 1 on 24/10/2017 21:19:57 |
Samsaranda | 24/10/2017 21:21:34 |
![]() 1688 forum posts 16 photos | Is the blade rotating in the correct direction? Surprising how easy to make that mistake, don't ask how I know. Dave |
Sam Longley 1 | 24/10/2017 21:27:30 |
965 forum posts 34 photos | Posted by Samsaranda on 24/10/2017 21:21:34:
Is the blade rotating in the correct direction? Surprising how easy to make that mistake, don't ask how I know. Dave That would be an "egg on face moment " I will check in the morning. I did that once with a spindle moulder. Bits of cutter flew all round the workshop !!!! |
John Reese | 24/10/2017 21:28:27 |
![]() 1071 forum posts | Surface speed in mild steel would be around 100 ft/min or 30 m/min. The 100 rpm should have been fine. It is possible the shaft is surface hardened. |
John Reese | 24/10/2017 21:32:24 |
![]() 1071 forum posts | Look at the teeth of the cutters under 10X magnification. The fact they were given to you means they could have been used and need resharpening. |
Mick B1 | 24/10/2017 21:32:25 |
2444 forum posts 139 photos | You do sometimes get steel shafts with intensely case hardened skins, but soft inside. I can remember trying to machine some knitting machine pushrods that I'd been able to cut with a hacksaw, but couldn't turn with HSS. |
Roy Moss | 24/10/2017 21:35:33 |
11 forum posts | If by chromed steel you mean chrome plated, that could be the problem. Chrome plating can leave a very hard coating which may need to be ground off before attempting any other machining. I tried drilling a chromed bar and the drill glowed red as its tip deformed. Roy |
Sam Longley 1 | 24/10/2017 21:38:25 |
965 forum posts 34 photos | Posted by Roy Moss on 24/10/2017 21:35:33:
If by chromed steel you mean chrome plated, that could be the problem. Chrome plating can leave a very hard coating which may need to be ground off before attempting any other machining. I tried drilling a chromed bar and the drill glowed red as its tip deformed. Roy That may be the problem as the centre looks like honeycomb in comparison to the surface. Perhaps I should try some other steel as a test |
Neil Wyatt | 24/10/2017 21:44:29 |
![]() 19226 forum posts 749 photos 86 articles | Use the same rpm as you would use if turning a bar of the same diameter as the slitting saw in a lathe. They don't work like abrasive cut off saws at thousands of rpm. |
David Standing 1 | 24/10/2017 22:12:08 |
1297 forum posts 50 photos | Sam If the shaft is one of those that the print head traverses on, it will be as hard as hell on the surface. |
steamdave | 24/10/2017 23:09:58 |
526 forum posts 45 photos | Posted by David Standing 1 on 24/10/2017 22:12:08:
Sam If the shaft is one of those that the print head traverses on, it will be as hard as hell on the surface. Very interesting observation, that. I've always thought that they were Stainless of some grade. I've got quite a stock of printer rods in various diameters and from different makes and have never had any problem machining them and getting a very good finish using HSS tools. Guess I'm just lucky. Dave |
fizzy | 24/10/2017 23:32:54 |
![]() 1860 forum posts 121 photos | from bitter experience - run it slow...real slow and all will be good
Rik Shaw | 25/10/2017 08:13:03 |
![]() 1494 forum posts 403 photos | Sam - I have a draw full of printer cartridge guide rods, scanner guide rods and guide rods from photocopiers. Maybe some machines use hardened rods but I have yet to come across any. It all machines like a dream and leaves a lovely finish. My guess is that the cutter you used is either very blunt or you are running in reverse or both. Try turning a bit in the lathe to prove or disprove. Rik PS How do you know it's chromed? |
SillyOldDuffer | 25/10/2017 09:00:54 |
10668 forum posts 2415 photos | Posted by steamdave on 24/10/2017 23:09:58:
Sam If the shaft is one of those that the print head traverses on, it will be as hard as hell on the surface. ... I've got quite a stock of printer rods in various diameters and from different makes and have never had any problem machining them and getting a very good finish using HSS tools. Guess I'm just lucky. Dave If my experience is anything to go by, it's the people who get a hard one who are unlucky. The very first rod I tried to turn was hard enough to defeat carbide. Very discouraging! Since then all my other ex-printer rods (10+) have machined without problems. It may be to do with the printer type. The very hard rod came out of a hefty HP Office Printer that worked hard for a living; all the others from lightweight domestic types. Dave |
Sam Longley 1 | 25/10/2017 13:24:41 |
965 forum posts 34 photos | Solved it with a 70mm diam carbide tipped blade 2mm th running a 200 RPM Thanks for comments |
Neil Wyatt | 25/10/2017 15:21:56 |
![]() 19226 forum posts 749 photos 86 articles | I've come across both, really nice ones and ones that turn like a ploughed field. Neil |
