JasonB | 24/10/2017 12:18:01 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Colin LLoyd on 24/10/2017 11:36:19:
Does anyone have any thoughts on the new Arceurotrade Original Stevenson's ER collet blocks (square for 4-jaw and 6-sided for 3-jaw chucks. Seems to sort of turn my lathe into a horizontal milling machine - but I already have a vertical milling machine - so can't really see where I'd use these. If used on the lathe they can be very handy for holding thin or delicate items that may be damaged by a 4 jaw chuck for example think how you would adjust a bit of thin wall tube in the 4 jaw without distorting it or faffing about with packing to save marking the surface with the jaws Boring 3/8" eccentric hole 2" long which left 0.010" wall on the thin side I have started this new thread to answer Colin's question about ER blocks hence no opening post by him, just the quoted part. Edited By JasonB on 24/10/2017 13:26:27 |
Martin Kyte | 24/10/2017 12:23:50 |
![]() 3445 forum posts 62 photos | Cross drilling holes in the mill, machining squares and hexagons in the mill. Holding screws to slot the heads in the mill. Basically holding round bar in the milling vice. regards Martin Edited By JasonB on 24/10/2017 13:23:16 |
Chris Trice | 24/10/2017 12:50:16 |
![]() 1376 forum posts 10 photos | Blocks like this for 5C collets have been around for a long time and I've got some home made ones for 2MT collets I made ten years ago. I was using them mostly for grinding and sharpening various tooling.
Edited By JasonB on 24/10/2017 13:23:34 |
not done it yet | 24/10/2017 12:51:23 |
7517 forum posts 20 photos | I've not yet used my set in the lathe, but they certainly get used in the milling vise. Saves using a rotary table for simple squaring and making hexagonals or machining them afterwards cross drlling, slotting etc
They can be used in the lathe, so plenty of uses. Now I have them, I would not get rid of them, for definite certain sure! Edited By JasonB on 24/10/2017 13:23:49 |
SillyOldDuffer | 24/10/2017 13:45:31 |
10668 forum posts 2415 photos | Yes, useful for various purposes. I don't use mine very often, when I do it's usually to hold small work in the lathe as described by Jason. It's also sometimes useful for moving work between a lathe and the miliing machine, for example if you want to turn an axle and put a flat on it to seat a grub screw. My mistake was to buy the Hex version. In practice I soon found the Square type would have suited me better. The reason I haven't bought a square one yet is because I'm dithering about getting a Collet Chuck instead. As always the usefulness of a particular tool or accessory depends on what you're making. You can always manage without a Stevenson's ER Block, but there are times when owning one makes life easier. Dave Edited By SillyOldDuffer on 24/10/2017 13:46:16 |
Rik Shaw | 24/10/2017 13:48:14 |
![]() 1494 forum posts 403 photos | I have both square and hexagonal ER25 blocks which I use mostly on the milling machine. BTW, are these attributable to the late JS? Rik |
Chris Evans 6 | 24/10/2017 14:28:48 |
![]() 2156 forum posts | My "Go To" blocks for putting hexagon or square on the mill. Also used for putting two flats on and screwdriver slots. A great compliment to the lathe collet chuck. |
Colin LLoyd | 24/10/2017 14:38:31 |
![]() 211 forum posts 18 photos | Jason - sorry about not creating a new thread - just didn't know whether the query was worthy of a new thread. |
Colin LLoyd | 24/10/2017 14:47:11 |
![]() 211 forum posts 18 photos | Posted by Martin Kyte on 24/10/2017 12:23:50:
Cross drilling holes in the mill, machining squares and hexagons in the mill. Holding screws to slot the heads in the mill. Basically holding round bar in the milling vice. regards Martin Edited By JasonB on 24/10/2017 13:23:16 This technique was also mentioned by Chris Evans 6. Can someone enlighten me as to what is meant here? |
Colin LLoyd | 24/10/2017 14:48:47 |
![]() 211 forum posts 18 photos | Sorry - I mean the first 3 items - "cross-drilling, machining squares and hexagons" |
Colin LLoyd | 24/10/2017 14:51:10 |
![]() 211 forum posts 18 photos | OK - just worked it out. The square and hex blocks go into a milling vice and the workpiecee you want to have square and hexagonally faces is then rotated in the milling vice beneath the mill tool. If I'm wrong tell me. |
JasonB | 24/10/2017 15:26:25 |
![]() 25215 forum posts 3105 photos 1 articles | Colin,you are right and no problem about the thread. Though do be careful if working on the end of a long bar that the block is seated down well as the bar can cause the block to tilt and you get an irregular 4 or 6 sided shape. I find the Stevenson spin indexer quicker than the blocks.
Rik, both designed by the late JS along with metric 10-20-40 and 20-40-80 blocks also available via ARC. |
IanT | 24/10/2017 15:49:30 |
2147 forum posts 222 photos | Yes Colin - all that and a bit more with a little thought. Very handy things... I'm in the process of making a holding block (that bolts on my boring table) to lift my ER32 blocks to the centre height of my small lathe - and then it will be possible to use them a bit more conveniently than if they were just in the vice (which doesn't hold them at c/h)... And of course they can be handy for bench work too. I needed to make a new regulator rod for my Atlantic and my first attempt at filing a square on the end of the 1/8th stainless wasn't very pretty (or square either) - so I got some round scrap about the right height and used it with the ER collet to do it right. Pictures being worth a thousand words... it went something like this... Regards, IanT |
IanT | 24/10/2017 15:52:52 |
2147 forum posts 222 photos | PS - looking more closely - that is my 5C block and I only had a few sizes of 5C collet back then, so the 1/8th rod was held in a brass adaptor - but these days it would be held directly in an ER collet.... IanT |
JasonB | 24/10/2017 16:21:44 |
![]() 25215 forum posts 3105 photos 1 articles | Talking of 5C blocks, keep them away from your ER blocks as they can start to interbreed! Actually I had machined one end of the brass rod and needed to machine the other so to keep things lined up I tightened the 5C before releasing the ER and with both faces on a flat plane all stayed true.
Michael Briggs | 24/10/2017 16:50:35 |
221 forum posts 12 photos | I find the blocks very useful. Quick to put a square or hex on a round bar and a simple way to hold a piece of round bar very securely without bruising the surface. Secure the bar in the block and then put the block in the vice or clamp to milling table. |
Enough! | 24/10/2017 17:18:19 |
1719 forum posts 1 photos | The thing I find awkward about them (on the mill) is that the nut is larger than the body so I'm always having to block them up (like Jason's pic) and or hang the nut outside the vice etc. |
IanT | 24/10/2017 17:23:00 |
2147 forum posts 222 photos | Yes indeed Michael, Another use that comes to mind is when tapping into the end of a rod. Whilst tapping can be started in the lathe (which is good for getting them in straight) - if the work is held in a 3-Jaw - then sometimes the grip can be limited and the work will turn in the chuck instead of being tapped. Assuming any 'turning' work is finished, then taking the work piece out and griping it in a collet & block (held in the vice) will usually allow the tapping to proceed. It's much better than just trying to grip the work in a vice alone.... Regards, IanT |
JasonB | 24/10/2017 17:24:16 |
![]() 25215 forum posts 3105 photos 1 articles | "The thing I find awkward about them (on the mill) is that the nut is larger than the body so I'm always having to block them up (like Jason's pic) and or hang the nut outside the vice etc."
That can be used to your advantage a the underside of the nut will act as a vice stop so you can mill a hex or square up to a face and end up with a level face. Edited By JasonB on 24/10/2017 17:24:53 |
Roderick Jenkins | 24/10/2017 17:36:58 |
![]() 2376 forum posts 800 photos | Very useful for milling at an angle: +1 for Ian T's comment. Very good at getting a good grip on circular stuff in the vice - will hold a 1/2" bar for screwing BSW with a die without turning the job. Rod |
