Brush Change kills my X3 mill, No it lives on
JasonB30/09/2017 10:13:18
I wonder if any of the electrical/motor gurus can help
Over the last couple of weeks I had noticed the odd drop in speed of the X3 while cutting, not enough to stop it just a slight fluctuation for a fraction of a second. Thought I would have a look at the brushes (switched off at wall socket) and one was worn down to about 1/4" long the other fine so I put in a new one.
Turned back on and nothing. Took brushes back out and held multimeter in the brush sockets and got 34V but that did not vary when pot turned. Then tried the same with a lamp in a pendant and no sign of life, tried the multimeter again and nothing.
I am getting 240V to the board but not reading anything where the motor connects. The green light is not comming on but I think that may have been dead before and I am getting 240V to that as it connects to teh on/off switch not the board.
Any suggestions of other things I could check?
Thanks J
Simon Collier30/09/2017 10:58:17
525 forum posts
65 photos
My SX3 has had the board in the head fail and the main board has a problem too as the tapping function doesn't work anywhere. It is 10 years old. The green light not working was a symptom before total failure. I know nothing of electronics unfortunately.
Gordon Tarling30/09/2017 10:59:27
185 forum posts
4 photos
I think the main control board has some fuses, so worth checking those before you go much further. Can't suggest anything else at the moment, except maybe a loose connection somewhere.
JasonB30/09/2017 11:14:21
No fuses on the board.
Quick blow fuse is fine as power has to go through that to get to the board.
Ian S C30/09/2017 11:21:03
7468 forum posts
230 photos
Check fuses, then check cut out switches on guards and covers. Are the new brushes seating on the commutator?
Ian S C
JasonB30/09/2017 12:17:55
I have checked all the obvious things. Loose Wires and interlocks
As there is no DC output from the board I don't think brush seating is the problem, lamp test also shows no voltage to motor.
JasonB30/09/2017 13:13:32
Found DC voltage at the board, then lunch stopped play, will report back later.
JasonB30/09/2017 14:31:04
Looks like the fault was probably caused by a plonker.
I went back and did a continuity check on the safety interlocks, chuck guard was working OK and I had it in the closed position. just thought I would check across the safety cut out on the front of the machine and it was open. Quick turn to release the button and circuit complete.
Strange as I had pressed and released this button a few times to see if things would work but depending on how it is tripped you do need to turn the power off to reset it, combined with the non working green light I had not set it correctly.blush
All back together and running nicely now. Thanks to all those who responded in the thread and by PM.
J
Nick_G30/09/2017 14:35:57
1808 forum posts
744 photos
Posted by JasonB on 30/09/2017 14:31:04:
J
Huuuuuzzzzzar.! laugh
Nick
Jim Nic30/09/2017 16:12:07
406 forum posts
235 photos
Tricky chaps, those plonkers, they seemed to have got you going big time. wink I have to confess I have been victim to one in a similar way in the past.
I'm glad all is now well. After all the help and advice you have given me and others over the years I felt a little helpless not being able to offer something constructive on this occasion in return.
Jim
Neil Wyatt30/09/2017 19:45:52
19226 forum posts
749 photos
86 articles
It saw the SX2.7 and threw its toys out of the pram.
You give it some TLC and now it's playing again.
JasonB30/09/2017 19:59:02
Talking of the SX2.7 I was toying with the idea of a Brushless conversion to the X3 as I know where I can lay my hands on a nice Brushless motor that is just the right sort of size, Ketan will never know and I won't have to worry about changing brushes againsmiley
Edited By JasonB on 30/09/2017 19:59:26
Michael Gilligan30/09/2017 21:00:56
23121 forum posts
1360 photos
Posted by JasonB on 30/09/2017 19:59:02:
That's a very neat little motor, Jason !!
Ian S C01/10/2017 13:55:37
7468 forum posts
230 photos
Glad I don't have interlocks on my machines. That's a nice looking motor, I suppose you have the power supply as well, how does it compare in power to the old motor?
Ian S C
JasonB01/10/2017 16:13:30
Michael & Ian. That is the motor from the SX2.7 that I will be using for the forthcoming series on milling for beginners so it comes with all the control gear in the back of the column.
It is very neat and not too heavy, that combined with the greater torque meaning it can be directly coupled to the spindle via a toothed belt and therefore elimination the need for a gear box makes it so much easier to raise and lower the head and there is no gearbox noise either. As to how it performs I have not yet cut enough metal to give an opinion but initial tests look very promising.
Michael Gilligan01/10/2017 16:32:37
23121 forum posts
1360 photos
Thanks, Jason
A sneak peek at the controller would be nice
John Rudd01/10/2017 17:00:09
1479 forum posts
Michael, there's nothing special,about the motor controller, have a look at the spares listing on Arc's website...
Here's the controller from my SX2.......
Edited By John Rudd on 01/10/2017 17:04:57
Michael Gilligan01/10/2017 17:07:42
23121 forum posts
1360 photos
Thanks for that, John
Sorry, I didn't realise that it was a standard item blush
... couldn't find spares listed for the SX2.7
Edit: ... So is the 750W version the same board, with uprated components ?
Edited By Michael Gilligan on 01/10/2017 17:15:18
Ketan Swali01/10/2017 18:47:56
1481 forum posts
149 photos
Hi Michael,
The concept of the control board for 500w brushless motor for SX2 is similar to the control boards for SX2.7 - 750w motor, SX3 -1000w motor, and SX4 - 1500w motor. However they are a little different in construction from each other as well as program of each board is different. Spares for SX2.7 will be put up on our website soon, but we do not have a clear time line at present.
Ketan at ARC
John Rudd01/10/2017 18:48:20
1479 forum posts
I'd expect the board to be about the same, but as you say, uprated for the extra power, however, there may have been technical developments since the X2 was launched.....the microcontroller on the X2 is an Atmel device with the software needed, the latest offering may be completely different?
Maybe Ketan could enlighten us?
Ah, I see he already has......
Edited By John Rudd on 01/10/2017 18:49:03
