flexible tubing for steam
for use with steam generator
mick H14/09/2017 14:47:59
795 forum posts
34 photos
I wish to connect a steam generating boiler (60psi) to a small loco chassis for testing purposes. I suspect that the traditional method is to use copper tubing with a coil incorporated to give flexibility. If I used copper tubing it would need to be 5/32"/4mm OD. Is there any other type of tubing that would give more flexibilityand less heat loss than a copper tube arrangement? I am thinking maybe nylon tubing but I am a bit unsure about the stability of the connections (olive/union nut) when heated.
Mick
Brian Sweeting14/09/2017 15:37:01
453 forum posts
Came across this website which may be useful.
I have used small bore plastics/nylons up to 30 bar with olive/compression fittings in days gone by.
fizzy14/09/2017 18:20:22
1860 forum posts
121 photos
"I have used small bore plastics/nylons up to 30 bar with olive/compression fittings in days gone by" at 140 degrees C?
Jeff Dayman14/09/2017 18:24:06
2356 forum posts
47 photos
Even the best nylons (HTN range from DuPont) start melting at 264 deg C. Normal nylons will melt much lower temp than that. If your steam is high pressure or superheated it can easily reach over 200 deg C.
Silicone rubber hose with stainless steel woven outer casing would be far safer, rated at 500 deg C plus. Personally I would use copper, maybe wrapped with rock wool or fibreglass insulation. Much cheaper and easier to get, and easier to work with.
Clive Brown 114/09/2017 18:25:21
1050 forum posts
56 photos
Steam @ 60psi will be at least 150 deg. C. AFAIK this is considerably above the recommended max. for nylon air lines.
Silicone rubber tube would stand the heat OK.
If your worry is heat-loss, fitting a plastic tube as a jacket over a copper tube would help.
Clive.
Snap with above post !!!
Edited By Clive Brown 1 on 14/09/2017 18:26:53
JasonB14/09/2017 18:30:37
Blackgates do a grey neoprene tube that is suitable for steam, smallest is 3mm ID x 4.5mm OD
Neil Wyatt14/09/2017 18:46:07
19226 forum posts
749 photos
86 articles
I've used ordinary 5mm O/D silicone fuel tube for steam up to 30PSI.
I think coffee machines use larger tube at higher pressures with a spring around it.
Edited By Neil Wyatt on 14/09/2017 18:46:22
duncan webster14/09/2017 19:30:47
5307 forum posts
83 photos
Articles in ME some time ago about articualted locos suggested PTFE lined hydraulic hose, but I think you'll struggle to get it that small
mick H15/09/2017 07:43:06
795 forum posts
34 photos
Thanks very much gents. Looks as if it will be copper covered in silicon tube for now as I have it handy but neoprene and that stainless braided silicon look to be worthy alternatives as and when I get hold of some. (One of the problems in asking questions on this forum is that you end up like the kid in the sweet shop surrounded by goodies but not sure what to go for).
Mick
Ian S C15/09/2017 09:29:29
7468 forum posts
230 photos
Ask a question of a dozen engineers, and you'll get a dozen different answers, eleven of them will get the right result in the end, a couple will be straight to the point, or you might just do it your way after all.
Ian S C
Nick Hughes15/09/2017 11:33:36
307 forum posts
150 photos
Goodridge braided brake hose **LINK**
Nick.
