Howard Lewis | 03/08/2017 13:59:14 |
7227 forum posts 21 photos | Armed with a 63T gear, are there any tables available, please, giving the Change wheel sets to cut Imperial thread pitches on a Mini lathe with a 1.5mm pitch leadscrew? (Am too idle to spend days making an Excel spreadsheet, and hope that someone has been there already) Howard
Thor 🇳🇴 | 03/08/2017 14:21:36 |
![]() 1766 forum posts 46 photos | Hi Howard, LMS has ha change gear calculator for the Mini Lathes,have you tried it? You can choose between a metric or imperial leadscrew and the same for the thread you want to cut. Thor |
Howard Lewis | 03/08/2017 14:37:55 |
7227 forum posts 21 photos | Hi Thor! Very Many Thanks. It looks to work a treat, based on the couple of checks made so far. Will save me HOURS of suck it and see on Excel. Filed away for future reference! Kind Regards Howard |
Brian Wood | 03/08/2017 14:41:36 |
2742 forum posts 39 photos | Hello Lewis, Edited By Brian Wood on 03/08/2017 14:57:07 |
Neil Wyatt | 03/08/2017 15:10:47 |
![]() 19226 forum posts 749 photos 86 articles | Hi Howard, Check your inbox Brian's book is still recommended if you want to really explore the subject. Neil |
Andrew Tinsley | 03/08/2017 15:13:43 |
1817 forum posts 2 photos | I second that! Brian's book is superbly produced and crammed with screwcutting information on a whole host of lathes. It really is useful and would also make a good coffee table book for a model engineer! Do yourself a favour and buy one from Arc right away, you won't regret it. Andrew. |
Bob Gitsham | 30/08/2017 11:44:05 |
22 forum posts | It is my uinderstanding that to cut a metric thread on an imperial lathe or vice versa, you need a127 x 120 tooth gear, as the gender bender gear in the train, The other gears will then give you the pitch you require. there are other combinations that are used but they only give an approximation of the desired thread pitch. |
John MC | 30/08/2017 13:44:28 |
![]() 464 forum posts 72 photos | My second lathe of many years ago was a round bed Drummond, the almost complete set of change wheels for that had a 63T gear for metric. No chart but worked out the trains soon enough thanks to the subject being taught at technical college, I wonder if its taught now? Interestingly the error in pitch using the 63T rather than a 127T gear was minimal, way smaller numbers than the accuracy the lathe was capable of. John |
Roderick Jenkins | 30/08/2017 13:51:46 |
![]() 2376 forum posts 800 photos | While Bob's comment is true enough in a purely mathematical sense, the "approximations" will give a result to more accuracy than the lathe is physically capable of producing. They also have the advantage of not requiring a 127 tooth gear or, indeed, finding a way to mount it on small lathes. Cheers, Rod |
Bob Gitsham | 30/08/2017 16:25:56 |
22 forum posts | Thanks Rod, I hadn't realised that the error was actually that small. I made sure that when I ordered my new lathe LD1216 last year that it came with the 127 x 120 compound gear, and although it is nominally an imperial lathe, Imperial leadscrew etc., all the handwheels are calibrated in both imp and metric, and the screw cutting chart gives both imp and metric threads straighrt from the norton style box., with only haveing to set the compound gear for Imp or metric.
SillyOldDuffer | 30/08/2017 17:24:29 |
10668 forum posts 2415 photos | Posted by Bob Gitsham on 30/08/2017 11:44:05:
It is my uinderstanding that to cut a metric thread on an imperial lathe or vice versa, you need a127 x 120 tooth gear, as the gender bender gear in the train, The other gears will then give you the pitch you require. there are other combinations that are used but they only give an approximation of the desired thread pitch. That's the conventional wisdom Bob, but it's not rock-solid. The magic 127, or slightly less magic 63, toothed gears allow one to calculate a TPI and then convert it to metric, or vice versa. The logic is analogous to 'multiply thou by 25.4 to get mm'. Calculating ratios with paper and pencil using the method mentioned by John MC is hard work. Having 127 or 63 makes the sums easier. However, we don't have to do it the hard way - a computer can crunch the numbers in nanoseconds and tell you how big the error is. Only if the error was too big would I get a 63 tooth gear. (I would never buy a 127 tooth gear because fitting on the banjo is likely to be problematic - it's too big for comfort!) Whilst the conversion method might suit the way we do arithmetic, and it gets results, it may not be the only way of producing an acceptable thread. My metric lathe produces more imperial threads than the imperial version and it doesn't have either a 63 or a 127 toothed wheel. What it does have is a set of gears that can be combined in ways that produce thousands of different thread possibilities. Many of them are duplicates or non-standard, but quite a few produce reasonable approximations of imperial TPIs. A quirk of the mathematics means that the gears provided with the imperial model are not quite so productive as it's metric equivalent. Nonetheless, given a calculator like that suggested by Thor, it's well worth checking to see if your existing gear set will do the job without needing a special 63 toothed gear. Dave
Martin Dowing | 04/09/2017 20:28:55 |
![]() 356 forum posts 8 photos | 63 tooth gear gives rather poor accuracy in metric/imperial translations. There are far better combinations than that with standard gears of 20-21-25-30...75 teeth. For superb accuracy you will also need 38 and 42T. 127T gear even if perfect is rather impractical (too large). Read "Screwcutting in the Lathe" by Martin Cleeve. You will find nearly everything you need to know (and more) there. |
Roderick Jenkins | 04/09/2017 20:48:42 |
![]() 2376 forum posts 800 photos | Posted by Martin Dowing on 04/09/2017 20:28:55:
63 tooth gear gives rather poor accuracy in metric/imperial translations. Depends on whether you are using it as a driver or driven. Rod |
Hopper | 05/09/2017 01:08:27 |
![]() 7881 forum posts 397 photos | I turn metric threads on my imperial lathe without any special gears. Using Martin Cleeves' book Screwcutting on the Lathe. He has the charts to use the original gears set-up as compound gearing, giving an accuracy usually in the range of 1 in 3,000 or so. Close enough for my shed. The book has the charts for imperial on metric also. |
Howard Lewis | 07/09/2017 11:56:32 |
7227 forum posts 21 photos | Thanks for all the replies. Have down loaded a chart, giving the combinations and the errors. As already said, the ideal solution is 127/120 compound gear., (as on the big lathe) Might have a job fitting it in, but will ponder it! Howard
Neil Wyatt | 07/09/2017 19:49:01 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Martin Dowing on 04/09/2017 20:28:55:
63 tooth gear gives rather poor accuracy in metric/imperial translations. What? 1 part in 16,000 not good enough for you? That's about 1/3 of a wavelength of red light in a millimeter or the length of a cricket pitch in 100 miles... Neil Edited By Neil Wyatt on 07/09/2017 19:53:07 |
Bob Gitsham | 08/09/2017 02:23:38 |
22 forum posts | How is this figure calculated? It would seem to me that as 63 is half of 126 that is 1 full tooth per revolution, short of 127, and given that the 63 tooth gear is run with a 60 T gear it is an attempt at approximating 127 x 120 gear setup which is, and has been, used on larger lathes for a very long time.
John Olsen | 08/09/2017 07:08:26 |
1294 forum posts 108 photos 1 articles | You don't actually use the 63 tooth in the same way as the 127, so the error is much less than your estimate. Check out some of the tables referred to by others above, the errors are quite acceptable for most purposes. I have a 127 tooth gear to fit the Myford, but have never used it since it would need a different banjo and a slot cut in the stand to actually get it on. It is about the size of a bread and butter plate. Looks good hanging on the wall though. John |
Michael Gilligan | 08/09/2017 08:25:23 |
![]() 23121 forum posts 1360 photos | Bob, Our esteemed Editor's article on the subject is available for download: **LINK** http://www.arceurotrade.co.uk/reviews/MEW204-P31_P36-Thread-Cutting.pdf ... this should reveal the magic of 63 MichaelG. |
Bob Gitsham | 08/09/2017 08:41:13 |
22 forum posts | Posted by Martin Dowing on 04/09/2017 20:28:55:
