Here is a list of all the postings Bob Gitsham has made in our forums. Click on a thread name to jump to the thread.
Thread: In praise of Oldtimers |
18/11/2017 12:16:28 |
Posted by larry Phelan on 16/11/2017 12:14:01:
I came across a notice recently,which I think sums up the ability of some of these men of former years,and I post it below. It could serve as our motto.! We,the willing Led by the unknowing Are doing the impossible For the ungreatful We have done so much With so little,for so long We are now qualified to do almost anything,with nothing !
My copy of this is in a sorry state,but I,m about to get a few new copies printed to hang up in a few workshops,on the grounds that IT SAYS IT ALL !!! I spent most of my working life as a Marine Engineer. The above message often appeared on the workshop notice board on many of the ships I worked on.
Thread: Wanted - a guide to adhesives |
20/09/2017 03:13:09 |
Posted by David Standing 1 on 19/09/2017 09:50:03:
Posted by Bob Gitsham on 19/09/2017 08:14:49:
Posted by Tim Stevens on 18/09/2017 18:00:09:
Indeed, this is the case. Then, I wanted to stick an aluminium sheet to a marine ply panel. Last week it was to stick ABS letters to a plastic-coated plate. Next week it will be some other combination, I'm sure. I am particularly keen to find adhesives which are not affected by plasticiser migration, which is especially common with PVC stuff (including vehicle wiring). And it does seem that the only serious tomes are intended for serious professionals and cost serious three-figure money. Thanks, everyone, for trying to help. Regards, Tim
Edited By Bob Gitsham on 19/09/2017 08:17:10
If you want to quote someone else's post(s) without getting yours all mixed up with it, start your comment below the vertical line on the left of the text Sorry I didn't see any instructionon how to do that, I hope this is correct. Thanks. |
19/09/2017 08:14:49 |
Edited By Bob Gitsham on 19/09/2017 08:17:10 |
19/09/2017 08:00:43 |
Posted by Michael Gilligan on 18/09/2017 16:00:07:
Posted by David Standing 1 on 18/09/2017 14:19:46:
Bob Have you realised the thread you are replying to was from five months ago? . Does that matter, David ? Tim has never given any 'closure' ... so presumably he has not yet found what he was seeking. MichaelG. In fact the whole thread has since come alive.
18/09/2017 13:58:23 |
Posted by Tim Stevens on 15/04/2017 17:19:21:
The Tee website gives no detail about content or date written - is it really up to date? I ask because many such books do have a rather old-fashioned content. Or do I just have to splash out and hope? Cheers, Tim
Thread: Imperial Thread Cutting on Metric Mini Lathe |
08/09/2017 15:42:06 |
Posted by Neil Wyatt on 08/09/2017 15:28:41:
If you read to the bottom of the main page, they pre-grind the lead screws then roll them presumably to get the best of both worlds with ground accuracy and rolled form and surface finish. I think the 0.3mm per 300mm bit is an error as the text it's in mentions 60-degree metric form threaded rod rather than precision leadscrews and the 0.05/300mm is mentioned elsewhere and 0.003"/for for v-thread precision leadscrews. "Cold Rolled Formed Lead Screws Abssac supplies both machined and rolled thread formats. Lead screws that are cold rolled formed have the immediate advantage of a work hardened surface on which the load bearing nut will travel. Starting with a pre-ground bar stock, the thread form is gradually rolled into the material with increasing pressure ensuring precise material deformation along the thread form as it is worked. By repeating this process the screw stock work hardens into a smooth, polished like finish with the desired diameter and lead as the finished product." Edited By Neil Wyatt on 08/09/2017 15:33:57
08/09/2017 15:35:51 |
Posted by Andrew Johnston on 08/09/2017 10:05:02:
Posted by Neil Wyatt on 08/09/2017 09:47:50:
Visiting this site I see their precision metric leadscrews have an accuracy of 0.08mm per 300mm. Hmmm, and further down on the same page they say the lead error over the length of the rod is 0.3mm per 300mm, rather different. I would expect precision leadscrews to be ground rather than rolled. Of course that doesn't change the fact that a 63 tooth gear is perfectly satisfactory for cutting metric pitches with the correct gear train. Personally I say hooray for quick change gearboxes; imperial, metric, DP and module all at the change of some levers, and one gear. Andrew
08/09/2017 08:41:13 |
Posted by Martin Dowing on 04/09/2017 20:28:55:
63 tooth gear gives rather poor accuracy in metric/imperial translations. There are far better combinations than that with standard gears of 20-21-25-30...75 teeth. For superb accuracy you will also need 38 and 42T. 127T gear even if perfect is rather impractical (too large). Read "Screwcutting in the Lathe" by Martin Cleeve. You will find nearly everything you need to know (and more) there.
08/09/2017 02:23:38 |
How is this figure calculated? It would seem to me that as 63 is half of 126 that is 1 full tooth per revolution, short of 127, and given that the 63 tooth gear is run with a 60 T gear it is an attempt at approximating 127 x 120 gear setup which is, and has been, used on larger lathes for a very long time.
Thread: New member |
30/08/2017 17:16:41 |
Thanks Neil, Not sure what other recent thread you refer too. But yes it's all good now. I've just got to find the time to get into the workshop and actually make something. My head is full of ideas, but no time to do them.
30/08/2017 16:25:56 |
Thanks Rod, I hadn't realised that the error was actually that small. I made sure that when I ordered my new lathe LD1216 last year that it came with the 127 x 120 compound gear, and although it is nominally an imperial lathe, Imperial leadscrew etc., all the handwheels are calibrated in both imp and metric, and the screw cutting chart gives both imp and metric threads straighrt from the norton style box., with only haveing to set the compound gear for Imp or metric.
30/08/2017 11:44:05 |
It is my uinderstanding that to cut a metric thread on an imperial lathe or vice versa, you need a127 x 120 tooth gear, as the gender bender gear in the train, The other gears will then give you the pitch you require. there are other combinations that are used but they only give an approximation of the desired thread pitch. |
Thread: Level lathe set up |
29/08/2017 08:44:10 |
I'm fairly certain that by level they actually mean that the bed is flat and straight, without any twist, also that the centerline of the head stock is parallell to the flat staright bed, inboth the horizontal and vertical plane.The tail stock should also be on the same centerline. I spent most of my adult working life as a Marine Engineer |
Thread: Ignition Spark |
29/08/2017 06:04:14 |
You can buy minature spark plugs, ignition coils and points sets from the specialty hobby shops that supply parts for RC internal combustion racing cars, I've not bought any, but I have seen them there when looking for other small stuff.
Edited By Bob Gitsham on 29/08/2017 06:06:20 |
Thread: Epoxy Resin |
29/08/2017 05:20:51 |
Hi, I have used a wide variety of epoxy adhesives and fillers over many years both as a hobbiest and as a professional marine engineer. |
Thread: Bob Gitsham from Adelaide Sth Australia. |
29/08/2017 03:31:00 |
G'day, I originally posted this back last December 2016, but must have put it in the wrong place, so I'll try again. |
Thread: Cheap 3 in 1 tig welder - any one used one? |
09/01/2017 21:59:44 |
yep, I been thinking that for a while, I suspect this guy is just looking for someone to disagree with. It pisses me when people ask for help and get a heap of good advice, then go and stuff it up because of their own stupidity, ignorance and arrogance. The moderators should pull him up, tell him, if he's not prepared to listen then at least do us all a favour and shut up. Bob.
19/12/2016 16:38:32 |
Yes I've tried a couple and for my money I would rather buy a real product from a known brand. |
Thread: Spring is Sprung |
15/12/2016 14:04:34 |
Item under Scribe a line in Autumn 2016 of Model Engineers Workshop showing a method of winding springs on a lathe using various sizes of screws as a pattern,
Edited By Bob Gitsham on 15/12/2016 14:05:11 |
11/12/2016 12:13:33 |
G'day Chris, good to hear that you lathe is still going strong after 20 years, I hope mine does too but I doubt if I'll last that long. |
