JasonB | 28/07/2017 19:18:23 |
![]() 25215 forum posts 3105 photos 1 articles | Why did you stone the key, far better to enlarge the depth of the keyway in the gear. File will do but broach would be better If you can't ream them to the size you need then bore them on the lathe |
John Haine | 28/07/2017 19:38:08 |
5563 forum posts 322 photos | New lathe? Take this up with the supplier. |
John Stevenson | 28/07/2017 19:54:20 |
![]() 5068 forum posts 3 photos | Plastic. Gears are hyfroscopic. They will easily overcome ereee these tolerances. From new, better to be A slip filt than a prick. In a shirt sleeve . it fit thdab me a bag in. a |
Samsaranda | 28/07/2017 20:17:25 |
![]() 1688 forum posts 16 photos | John what language are you posting in, could we have a translation please? Dave |
Ian P | 28/07/2017 20:25:33 |
![]() 2747 forum posts 123 photos | Makes as much sense as Jason's reply to an invisible question Ian P |
ASF | 28/07/2017 20:27:17 |
131 forum posts 12 photos | Posted by Ian Phillips on 28/07/2017 20:25:33:
I was just going to remark the same |
JasonB | 28/07/2017 20:29:30 |
![]() 25215 forum posts 3105 photos 1 articles | I have a feeling that someone with fat fingers may have deleted the first post by accident as well as typing gibberish and double posting it to boot
The problem is that us moderators see another line below each post and "edit" is next to "delete" so easy to click the wrong one and the software does not ask you to confirm the deletion or have an option to retain deleted postings so they can be reinstated. Add in the fact that JS may have been posting via his phone and mistakes can happen.
Edited By JasonB on 28/07/2017 20:33:27 |
Martin Whittle | 28/07/2017 20:29:36 |
102 forum posts 12 photos | Que? While (not quite) this subject: Martin |
Bob Stevenson | 28/07/2017 21:57:30 |
579 forum posts 7 photos | I think I can guess what this is about;.......
Mini-lathes are made by two different Chinese factories, at least as far as the lathes that come to to the UK are concerned. These are 'Sieg' and 'Real Bull'. Although the lathes are essentially the same design there are some detail differences, one of which is the change wheels. Internal diameter is the same but the key-way cut-out causes a problem if you wish to fit Sieg wheels on a Real Bull machine.
You need to enlarge the key-way slot 1mm wider to fit and the best way that i have found is to carefully cut the sides of the slot away using a scalpel, while repeatedly trying for a fit...... The wheels are made of a 'delrin' type of material and abrasive methods are tricky and difficult so firm cuts are needed. Once you have done a wheel it gets much easier to do.
The only source of wheels i could find in UK for my Real Bull lathe (Chester Conquest) was Arceurotrade who only have the Seig wheels. |
JasonB | 29/07/2017 07:31:39 |
![]() 25215 forum posts 3105 photos 1 articles | Original post has 12.03mm shaft and about 11.80 bore in the changewheels which was the main problem but top of keyway was tight after trying to open up the hole with a reamer which did not work well due to keyway. |
Bob Stevenson | 29/07/2017 08:56:51 |
579 forum posts 7 photos | Yes, the change wheels are quite a tight fit but CAN be 'urged' onto the studs!....it helps to lightly chamfer the inside edge of the wheel bores. The key-way slots are the same height for both makes of wheel but the width is considerably different. |
larry Phelan | 29/07/2017 11:49:43 |
![]() 544 forum posts 17 photos | Why dont they make sure that the wheels fit,before they sell them? That,s like buying a car and then finding that the wheels dont fit. There is no excuse for that kind of thing,no matter where they are made. |
Bob Stevenson | 29/07/2017 12:18:05 |
579 forum posts 7 photos | ......Probably because there's a difference in the perception of 'fit' between the Chinese production engineers and a model engineer living in the UK...... the wheels DO fit, albeit with some persuasion, provided you use either the right make of wheel or some 'remedial'....... |
JasonB | 29/07/2017 13:08:37 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by larry Phelan on 29/07/2017 11:49:43:
Why dont they make sure that the wheels fit,before they sell them? That,s like buying a car and then finding that the wheels dont fit. There is no excuse for that kind of thing,no matter where they are made. As per JS's post the plastic they are made from moves so they may fit in the factory but could expand or contract while sitting in a shed workshop that can be freezing in winter and very hot in summer. |
KWIL | 29/07/2017 13:37:52 |
3681 forum posts 70 photos | Larry, I am sure the changewheels that Arceurotrade sell do fit the Seig machines they sell, if they do not you can complain. But if you try them on a Real Bull you takes your choice. Bit like trying to mend a BMW with VW parts!! |
John Stevenson | 29/07/2017 13:48:11 |
![]() 5068 forum posts 3 photos | A few points Possibly me deleting the fist post instead of editing I'm in for a long time with only a mobie Secondly for the 20,000 time Real Bull Web bankrupt about 5 years ago The result was the better sets saw Iight under the real bull logo and the rest by the second cussing on aliexpress |
Neil Wyatt | 29/07/2017 15:12:51 |
![]() 19226 forum posts 749 photos 86 articles | Posted by John Stevenson on 29/07/2017 13:48:11:
A few points Possibly me deleting the fist post instead of editing I'm in for a long time with only a mobie Secondly for the 20,000 time Real Bull Web bankrupt about 5 years ago The result was the better sets saw Iight under the real bull logo and the rest by the second cussing on aliexpress As Dick Dastardly would say "Give me a translation Zilly..." "Real Bull went bankrupt about 5 years ago. The result was the better sets saw light under the real bull logo and the rest sold by the second cousin on Ali Express." John, I think you are meant to use your finger not your nose... and maybe switch auto-replace off Neil |
Neil Wyatt | 29/07/2017 15:18:04 |
![]() 19226 forum posts 749 photos 86 articles | Yes, Real Bull and SEIG mini lathes are the same basic design, but not identical, as as attempted to explain above although real 'Real Bull' are OK there are cheap 'Unreal Bull' lathes brought in by some minor importers/via ali express that aren't up to scratch. There also appear (in Australia at least) to be a few sources of machine made from spares (or even the reject bins of the better factories). |
