Ed's Bench Magnifier
Bonus Content for MEW 256
Neil Wyatt12/06/2017 10:52:12
19226 forum posts
749 photos
86 articles
Download the STL files for the Ed's Bench magnifier (with new battery box) here:
www.model-engineer.co.uk/lamp
Edited By Neil Wyatt on 12/06/2017 10:52:33
Circlip12/06/2017 10:58:39
1723 forum posts
Looks nice and pretty but what about files that the great unwashed can read????
Regards Ian.
John Stevenson12/06/2017 11:11:30
5068 forum posts
3D printers use STL files so no problem. If you don't have a 3D printer then the project isn't for you and it's off down IKEA for you 😀
SillyOldDuffer12/06/2017 11:19:34
10668 forum posts
2415 photos
Is there a prize for identifying the skull? The teeth remind me of my mother-in-law...
Gary Wooding12/06/2017 11:24:19
1074 forum posts
290 photos
Neil,
When I looked at the Pivot in Cura it was shown on it's side. Did you use scaffolding or did you rotate it 90 degrees about the X or Y axes?
Circlip12/06/2017 11:45:25
1723 forum posts
Can't see anything on the picky that can't be made by conventional methods John, Even the Pozi pan head bolts look like they could be bought.
' Spose since muddle ingineering has become a "What can I spend my disposable income on" 3D printers will become the must have. Is there a universal 3D printer component manufacturing measuring system? Metric or Imperial? No doubt whichever is stated, somebody will want T'other.
Regards Ian
Neil Wyatt12/06/2017 11:51:31
19226 forum posts
749 photos
86 articles
Posted by Gary Wooding on 12/06/2017 11:24:19:
Neil,
It all prints without support, but i rely on people choosing the best orientation for themselves.
Neil Wyatt12/06/2017 11:52:54
19226 forum posts
749 photos
86 articles
Posted by Circlip on 12/06/2017 11:45:25:
The reason I 3D printed it was (a) vastly cheaper than using up loads of aluminium section and fabricating all the joints, (b) no worries about getting all the parallelogram bits the same size and (c) a very easy way of making a body to suit both the lens and the LED lamp.
A great example of the advantage of 3D printing was making a proper battery box. I wanted to fit in a standard lithium cell, a little charger board with a micro USB socket and use the switch out of the lamp used as a donor for the LEDs. It didn't take long to design the box so the board and switch clip in place, and the cell is held in place. There's a hole for the status LEDs to shine through (glazed witha touch of clear silicone). The box clips together, taking advantage of the texture of 3D-printed items (a useful tip) and the box itself clips to the base of the lamp.
If redoing it I might 3D print all the screws, you can go down to M5 quite easily.
Regards Ian
STL files just have measurements in 'units', I happened to design these in mm so if you use inches it will be rather big, the joy of 3D printing is you can scale things to whatever size you want.
Edited By Neil Wyatt on 12/06/2017 12:11:42
Neil Wyatt12/06/2017 11:59:53
19226 forum posts
749 photos
86 articles
Posted by Circlip on 12/06/2017 10:58:39:
Regards Ian.
That's why I posted a photo.
You can download something like Modulework's free STL Viewer to look at the files, or use Cura or similar, or even TurboCAD.
The skull is from Ultimaker's T-Rex. I have printed the full skeleton, it's about 18" long and , quite honestly, looks amazing. It's also noticeable how much better designed it is than 99% of things on Thingiverse - it actually does clip together (although the central support pillar is 15mm, too short as designed).
Michael Gilligan12/06/2017 15:50:48
23121 forum posts
1360 photos
For info. ...
The STL files will open in the MeshLab App on iPad ... but the rendering isn't quite right.
No ... I don't know whose 'fault' this is.
richardandtracy12/06/2017 15:54:52
943 forum posts
10 photos
I do wish ASCII STL files would be used, much more chance of finding out where your stl reading file routine is screwing itself into knots than with binary. OK, ascii files are bigger, but more packages open them reliably.
Richard.
Journeyman12/06/2017 16:23:49
1257 forum posts
264 photos
Seems to work in Geomagic Design (soon to be Alibre again apparently).
I still can't work out a way to see the insides of hollow items though.
JasonB12/06/2017 16:33:40
You could try setting the opacity of the part to a lower level
SillyOldDuffer12/06/2017 16:40:57
10668 forum posts
2415 photos
May be because that's two parts in the same space, not a single part. (Bench Lamp pivot and Bench pivot 2)
Edit: no it isn't, silly me.
Renders OK in FreeCAD.
Edited By SillyOldDuffer on 12/06/2017 16:42:16
Journeyman12/06/2017 16:56:04
1257 forum posts
264 photos
Posted by JasonB on 12/06/2017 16:33:40:
Works for some bits but not others. The pivot above just reacts as a normal Alibre drawing and becomes semi-transparent. The arms which have holes down the middle stay completely solid. I was only trying it to see if you could see the layers for the print or any honeycomb centre filling. I don't appear to be able to edit anything either but I think that is the way Alibre imports things (perhaps).
Neil Wyatt12/06/2017 17:11:51
19226 forum posts
749 photos
86 articles
Posted by Journeyman on 12/06/2017 16:23:49:
Try using Cura, it has X-ray and transparent modes.
Or the STL viewer I linked to above.
Edited By Neil Wyatt on 12/06/2017 17:15:12
Neil Wyatt12/06/2017 17:13:16
19226 forum posts
749 photos
86 articles
Posted by Michael Gilligan on 12/06/2017 15:50:48:
For info. ...
It looks like you have some sort of smoothing switched on. By definition STL objects are composed entirely of flat triangular facets.
Michael Gilligan12/06/2017 18:11:12
23121 forum posts
1360 photos
Posted by Neil Wyatt on 12/06/2017 17:13:16:
Indeed I did, Neil
... here's the same view, with flat rendering:
Mind you ... MeshLab does render some curves pretty well surprise
[ Yes, this is an STL file ]
Journeyman12/06/2017 18:28:37
1257 forum posts
264 photos
Posted by Neil Wyatt on 12/06/2017 17:11:51:
Ah yes, CURA makes it clear how it all works. Now all I need is a printersmiley
JasonB12/06/2017 18:43:47
Never mind the desk lamp, where is the STL file to print out the "Super Adept Man" action toyquestion
