Keyless chuck so tight can get hole way out
petro1head16/03/2017 15:44:25
984 forum posts
207 photos
I used a hole saw in my keyless chuck, now its so tight I cant get it out,
Any ideas that do not involve a hammer
Jon Gibbs16/03/2017 15:50:29
750 forum posts
Have you tried a strap wrench around the chuck body?
richardandtracy16/03/2017 15:53:44
943 forum posts
10 photos
Angle grinder? Not a hammer... crook
The other thought is a stilson or chain wrench, water pump pliars, mole grip, something where it grips hard and you do the twist.
Richard
Senior Yates16/03/2017 16:48:58
34 forum posts
Carver clamps always made good chuck keys when I worked in the Toolroom smiley
Peter Krogh16/03/2017 17:03:33
228 forum posts
20 photos
Drill a hole through a piece of wood, that is as thick as where you want to grip or more, a bit smaller than the grip area. Then saw the piece longways through the center of the hole. Now you can grip the chuck in a vise without damaging the chuck!
Pete
petro1head16/03/2017 17:19:01
984 forum posts
207 photos
Thanks
I found this which worked, shap tap with a copper mallet and it freed. This has put me off keyless chucks tho.
http://www.pistonheads.com/gassing/topic.asp?t=969082
Edited By petro1head on 16/03/2017 17:20:03
Brian Oldford16/03/2017 18:30:40
686 forum posts
18 photos
Percussive maintenance works well most times.
petro1head16/03/2017 18:47:06
984 forum posts
207 photos
Posted by petro1head on 16/03/2017 15:44:25:
Indeed, I knew I bought that copper hammer for a reason
Edited By petro1head on 16/03/2017 18:47:20
JasonB16/03/2017 19:06:26
Posted by petro1head on 16/03/2017 17:19:01:
Don't let it put you off them but bear in mind that most of them will tighten when loaded. A large dia holesaw has quite a bit of leverage so will make the jaws tighten up. Also if your saw arbor was hexagonal as most are it will just keep putting more load onto the jaws whereas a drill bit will spin in the jaws.
petro1head16/03/2017 19:20:53
984 forum posts
207 photos
I did wonder about the arbor being hex and the saw teeth putting quite a load on the chuck
Grizzly bear17/03/2017 18:23:34
337 forum posts
8 photos
Slightly O.T.
I have a Clarke Metal Worker drill press, always had bother with the keyed chuck, lack of grip.
Since reading the posts about using all the positions to tighten the chuck, its been fine. Thank you.
Bear..
