Here is a list of all the postings Senior Yates has made in our forums. Click on a thread name to jump to the thread.
Thread: Fly Tying Vice |
30/10/2019 09:10:17 |
Nice work Paul, do you have any drawing available? |
Thread: What bearings for a submersible wheelchair? |
05/10/2018 14:06:14 |
Hi Gary, Try Nylacast I would recommend Aquanyl PA6/12 as it doesn't absorb water. No link to this company but I have used their material many times. Good luck |
Thread: Odd size hole to correct size |
11/01/2018 10:42:52 |
When I was an apprentice toolmaker I worked with a turner who could do this and he called them Dagenham reamers. If we didn't have the correct size reamer he would sharpen the drill to cut the correct size. I believe he was ex fords hence the name "Dagenham Reamer". He was the quickest and best manual turner I've ever meet. |
Thread: Tom Senior M1 suds belt |
30/12/2017 10:25:04 |
Hi Andy, If you can look at old MEW there is an article on refurbishing a Tom Senior, I've got them somewhere but can't put my hands on them. If not I made one as my M1 has a spacer to give me more head room out of 10 mm rubber belt that you glue together. Regards |
Thread: New chinese lathe or old Myford lathe |
19/10/2017 12:50:16 |
Hi Stuart, I've had a Drummond great little lathe. An old British made Challenger lathe terrible, a Myford which I couldn't get rid of quick enough. I have just purchased a Boxford TS10.20 in near new condition for £1500 and it is a dream to use the closest hobby machine I've used compared to industrial machines. I cannot recommend Boxford enough far better than the "M" word machines. Good luck. |
Thread: Is there a new competition in MEW |
04/10/2017 09:57:31 |
Just got my latest copy of MEW in the post and had a quick flick through. Is there a new competition this month??? How many photos of the editor can you find or Spot the editor!!!!! I counted 9.... Really Neil I think I'm onto something here. Lol |
Thread: What am I doing wrong |
31/07/2017 19:42:35 |
Hi Dave, Yes I'm a press tool maker by trade serving my time in an old fashioned tool room but it,s been 20 plus years. I understand the mechanic of them and I've always enjoyed turning but I just can't the feel right with the smaller lathes. I'm keen to know how people set the saddle, cross slide and top slides up I've never been able to master it on a model lathe give me a Colchester or Harrison any day. I think maybe it's me trying to get to much from a small machine but I haven't got the time to take .005" cuts when I need to remove 10mm + on a job. I know the machine are very old and maybe I need to strip them down and start again? Regards Andy
31/07/2017 16:24:16 |
Thank you Clive I will give that a go. Regards Andy |
31/07/2017 10:01:15 |
Thanks for the feedback. Clive do I need to put any leverage on the spindle bore when clocking as when checking with a clock spinning the spindle it runs spot on so I'm really confused. Are there any instruction on spindle inspection and dovetail adjustment I can download or buy? Regards Andy |
30/07/2017 22:02:58 |
Hi all I'm supposed to be an engineer by trade but I have two old lathes one is a challenger which is very old and not very rigid the other is the so call RR of model engineers lathes Myford. I've clocked them all up spindles and all. I just cannot stop the chattering please see photo attached. What am I doing so wrong? Edited By JasonB on 31/07/2017 07:32:48 Edited By Neil Wyatt on 31/07/2017 10:56:06 |
Thread: Men's Sheds on Beeb site |
11/05/2017 15:19:35 |
I Read this on the BBC News web page. Do you think we can get a prescription for CTAS because I've got it bad, that is all I do is make a tool to make a tool. I have books and plans of things to make but I just keep making tools to make tools. I'm off to lay down in a dark room now....... |
Thread: Rusty lathe for sale |
16/04/2017 08:29:47 |
Have we got a new segment for MEW 'Rust In Peace'
Thread: Help with lost wax casting |
21/03/2017 09:36:27 |
Hi Richard, I've been reading this thread for the last couple of days with some worrying signs. Could I make a suggestion that if you have a small milling machine and some aluminium plate you could make a tool, the best thing to do is to maybe simplify the design to aid how you make your tool. Even if you have to carry out some machining of the casting when made. You could make the two lungs that stand up parallel and even the bottom of the track flat. If you add a small wedge feed on one end this will help the foundry and make it cheaper, also helps you fettle them clean afterwards. Use a foundry that uses a ceramic shell system not a plaster flask method (Very expensive) The size of your component is small so the foundry should be able to make one tree with 100 plus parts on it. This method will also have the wax autoclaved out then flash fired to remove any residue from inside the tree. The foundry can then pour, cool, cut off and give to you to fettle yourself. If you need any help with your tool design PM me. I spent 20 years as the engineering manager of a large aerospace foundry. Good luck |
Thread: Keyless chuck so tight can get hole way out |
16/03/2017 16:48:58 |
Carver clamps always made good chuck keys when I worked in the Toolroom |
Thread: Lost wax casting advice needed |
03/03/2017 09:11:11 |
Nice work Brian, they have cleaned up well. I can see a show winner on it's way. |
07/02/2017 20:06:11 |
Hi, if you are after just a one off option B is best but remember if you want a decent surface finish burning RP is not the best. Most RP leave an ash residue which never leads to a good finish and any printing lines will be magnified 10 fold. It's always better to ask about the size of the companies wax presses and if possible max a little tool yourself, they are only made from aluminium and brass. I had 20 years working with all types of RPs and sometimes making a little hard tool was quicker and cheaper. Good luck |
Thread: New member from Suffolk |
07/12/2016 13:43:14 |
Hi Nathan, I'm just down the road in Long Melford and have a small model engineering workshop. I don't know of any clubs near by, but I am more than happy to help you out machine and such like if you could teach me some basic CAD. I work in Norwich so travel through Bury every day. Welcome. Regards Senior |
Thread: Delivery |
27/11/2016 19:55:20 |
Neil, I will consider myself told!! Funny way of update the new releases of ME and MEW!! Grumpy old so
27/11/2016 08:27:10 |
I've had the latest ME delivered which isn't shown above but not a copy of MEW! This starting to happen regularly and is getting annoying. |
Thread: LOST WAX CASTING |
13/10/2016 11:39:48 |
Hi Chas, I spent 20 years as a production manager in one of the UK best aerospace foundries. The tools we mainly used were all aluminium with brass cores, there was the odd resin type we always used silicone spray on each shot to release the wax pattern. The company you should speak to is Blaysons. Hope this helps Senior |
