Martin W | 10/03/2017 16:53:12 |
940 forum posts 30 photos | Just had a browse round LIDL while the good lady did some shopping. In the tool section I noticed that they were selling Digital Angle Finder at £9-99 so bought one to see how good or bad it is; well could always confine it to the woodworking box if really bad. Having set it at 0 deg on a plane surface I used a set of ground angle blocks and checked it at various angles from 0 to 90 degrees and was surprised at the results, they are:
Needless to say I am pleased with my spend of £9-99 and won't be consigning the Digital Angle Finder to the woodwork box Martin W Edited By Martin W on 10/03/2017 16:55:07 |
Michael Gilligan | 11/03/2017 07:07:39 |
![]() 23121 forum posts 1360 photos | Martin, 326 views without any comment Please let me correct that; by thanking you, for taking the trouble to share the results of your check. MichaelG. |
Matthew Reed | 11/03/2017 08:38:16 |
41 forum posts | Thank you for the tip. Wife sent to get one😀! Is the sharpener any good? Thinking masonary drills and diy stuff rather than my best machine kit. Matthew |
Sandgrounder | 11/03/2017 08:40:55 |
256 forum posts 6 photos | My thanks as well, I'd never considered a Digital Angle Finder would be that accurate, no good reason for thinking that as I use a digital vernier, perhaps it's memories of using trig' tables at school, I'll buy one now. John |
Neil Wyatt | 11/03/2017 09:21:16 |
![]() 19226 forum posts 749 photos 86 articles | I surprised your angle blocks are that far out Must see if our Lidl has any left! Neil |
John Haine | 11/03/2017 09:45:03 |
5563 forum posts 322 photos | I did some similar tests on a Wixey one a while back, reported somewhere on the forum. It gave very similar results, I guess all of these must use similar sensors so not surprising I suppose. If they are the same as in mobile phones, they have no moving parts being just accelerometers. They are remarkably good. |
Chris Evans 6 | 11/03/2017 09:51:09 |
![]() 2156 forum posts | May get one of those for the quick "Ruff n Ready" set ups. I have an old Starrett plastic bodied one with a swinging needle pointer that is ready to be retired. |
Michael Gilligan | 11/03/2017 09:55:52 |
![]() 23121 forum posts 1360 photos | Posted by John Haine on 11/03/2017 09:45:03:
I did some similar tests on a Wixey one a while back, reported somewhere on the forum. It gave very similar results, I guess all of these must use similar sensors so not surprising I suppose. If they are the same as in mobile phones, they have no moving parts being just accelerometers. They are remarkably good. . John, May be mistaken, but; I think the Lidl device under discussion is this one: https://m.youtube.com/watch?v=dRprgDuOKA0 MichaelG.
Vic | 11/03/2017 10:06:58 |
3453 forum posts 23 photos | I've no idea how accurate my Moore & Wright one is but it's been very useful for what I do. |
Clive Foster | 11/03/2017 11:17:18 |
3630 forum posts 128 photos | Matthew Think I shall be looking for an angle gauge too. Got the drill sharpener last time round and was very much underwhelmed. Ill start a new thread with details. Clive.
Martin W | 11/03/2017 14:26:53 |
940 forum posts 30 photos | Michael G Yes that's the Digital Angle Finder I was referring to, I should have been more specific and given details so as to avoid any confusion
Martin W PS Neil, I was surprised that my angle blocks were that good Edited By Martin W on 11/03/2017 14:28:22 |
Enough! | 11/03/2017 18:31:45 |
1719 forum posts 1 photos | Posted by Martin W on 11/03/2017 14:26:53:
I have an identical-looking one from way back. Hope yours is better than mine in that I have to leave the battery out between uses or it goes dead (like the cheep calipers) Edited By Bandersnatch on 11/03/2017 18:32:57 |
duncan webster | 11/03/2017 18:41:29 |
5307 forum posts 83 photos | Just bought the last one in local branches. Looks OK, will be better than my cheap protractor at any rate |
MalcB | 11/03/2017 18:49:43 |
257 forum posts 35 photos | Went in yesterday to get one of their dampness meters and picked one up also. Rude not to at the price. |
Neil Wyatt | 14/03/2017 20:24:37 |
![]() 19226 forum posts 749 photos 86 articles | The steel blades aren't well finished, I had to stone the corners a bit to make it more pleasant (=bearable) to handle. I thought I would see how accurately I could estimate angles. I set 30 degrees by eye and it read 29.5, 60 degrees I managed 59.0 and 90 degrees 90.2. A bit disappointed by the last one as humans are very good at estimating right angles. Neil |
vintagengineer | 14/03/2017 21:06:07 |
![]() 469 forum posts 6 photos | I would double check the angle blocks. I would have expected the digital angle gauge errors to be incremental. Posted by Neil Wyatt on 11/03/2017 09:21:16:
Martin W | 15/03/2017 01:12:14 |
940 forum posts 30 photos | Angle Blocks are intended for production and inspection work and are specified to the following;
So I suspect that there is little wrong with them; looking at the results the indicated error appears to be at intervals of about 15 deg i.e 15, 30, 60 deg. While at 0, 45, 90 deg the angle finder agrees with the blocks. This may be pure coincidence or down to me not taking enough care when making the measurement. That said it is well within the quoted tolerance and will certainly do me for setting or measuring less critical angles. For the money they are a good bit of kit.
Neil, I agree with what you say about the edges being a not well finished and like you I have relieved the edges to make it more comfortable to use. Martin w |
Bill Pudney | 15/03/2017 03:27:37 |
622 forum posts 24 photos | I have had a similar "box of angles" for several years and it gets used a lot. For the stuff I use it for the accuracy is fine, I did a similar test/check against some angle blocks, and got similar results, as far as I can remember. I'm slightly surprised at myself for not keeping any notes, but I can remember thinking "...that's close enough for me...". cheers Bill |
Roy M | 15/03/2017 09:03:37 |
104 forum posts 7 photos | Mathew Reed. I bought a drill grinder from Lidl, because it was only £15.00. It says it can grind drills from 3mm dia to 10mm. I wanted it to grind small drills. Here is a report. The main body construction is adequate. It comes with 3 detachable 'units' for use as a knife sharpener, a chisel grinder, and drill sharpener. The chisel grinder works ok and gives a good square edge to the chisel prior to honing, it has an adjustable angle table. The drill grinder is interesting. The drill is secured along a vee groove using a thumb nut, and so the centre line of the drill changes ,(relative to the fixed rest on the grinder), depending upon the dia. This is a big dis-advantage. As the construction of the holder is only plastic there is a lot of un measurable movement which leads to very poor results on small drills. Aligning the drill ready for re-grind using the instructions and stops on the unit is really not very good and if you don't know how to grind a drill to start with, the unit, in my opinion, would be un usable. However I got good results when grinding a 10mm drill, which is the interesting bit. For £15.00 you get the opportunity to reverse engineer the drill grinding unit and make it accurately from steel, improve the drill alignment system and end up with a really good workshop project and a drill grinder that you could trust. As an off the shelf drill grinder it is of little use,in my opinion, but then I don't have a problem grinding drills off-hand. Hope this has been of some use. Roy M. |
Neil Wyatt | 15/03/2017 09:43:26 |
![]() 19226 forum posts 749 photos 86 articles | Posted by vintagengineer on 14/03/2017 21:06:07:
I would double check the angle blocks. I would have expected the digital angle gauge errors to be incremental. The angle gauge appears to use a capacitative rotary encoder, which would make any errors random and not cumulative. Edited By Neil Wyatt on 15/03/2017 09:45:13 |
