Anybody know what these are ?
Came in a job lot of tools
Alan Wood 402/03/2017 18:13:58
257 forum posts
14 photos
Speedy Builder502/03/2017 18:17:00
2878 forum posts
248 photos
Spot facers for socket head cap screws ?
Ed Duffner02/03/2017 18:28:52
863 forum posts
104 photos
I'd guess they are some sort of counter-bore tool, like a D-bit.
Ed.
Michael Gilligan02/03/2017 18:33:06
23121 forum posts
1360 photos
Posted by Speedy Builder5 on 02/03/2017 18:17:00:
Agreed ['though more probably counterbores]
... but am I right in thinking the one at the front is made for 'reverse' rotation ?
Sorry ... I think my eyes were in backwards blush
Edited By Michael Gilligan on 02/03/2017 18:50:31
Alan Wood 402/03/2017 18:33:49
257 forum posts
14 photos
Interesting suggestion
This would be a pretty deep counterbore even for cap heads.
There is a blind hole at each end which could be for a pilot drill.
Etched on them is Microtools T133945
Alan Wood 402/03/2017 18:34:25
257 forum posts
14 photos
Both the same
Michael Gilligan02/03/2017 18:39:02
23121 forum posts
1360 photos
Posted by Alan Wood 4 on 02/03/2017 18:33:49:
Not wishing to take this too far off track ... In some situations, it is good practice to counterbore as deep as is practical [it avoids bolt stretch]
Bazyle02/03/2017 21:37:21
6956 forum posts
229 photos
mmmm counterbore is an often miss-used term. Look it up.
Michael Gilligan02/03/2017 21:45:33
23121 forum posts
1360 photos
Posted by Bazyle on 02/03/2017 21:37:21:
To humour you ... I just did:
What point are you making ?
Quote from **LINK**
https://en.m.wikipedia.org/wiki/Counterbore
A counterbore (symbol: ) is a cylindrical flat-bottomed hole that enlarges another coaxial hole, or the tool used to create that feature. A counterbore hole is typically used when a fastener, such as a socket head cap screw, is required to sit flush with or below the level of a workpiece's surface.
< etc. >
Edit: A typical 'use case' for deep counterbores would be items like this:
https://www.thermofisher.co.nz/Uploads/file/Environmental-Industrial/Environmental-Monitoring-Safety/Environmental-Simulation/Vibration-Test-Analysis-Systems/LDS-Test/pdf/Head-Expanders-Fixtures.pdf
... not one of mine, but I have designed a couple in my time.
Edited By Michael Gilligan on 02/03/2017 21:56:10
JasonB03/03/2017 07:27:58
Not sure it is a counterbore as the difference between the pilot and larger dia does not seem enough even allowing for a very large clearance hole for the bolt/screw.
Maybe just something to put a small radius around the edge of a hole?
Michael Gilligan03/03/2017 07:59:05
23121 forum posts
1360 photos
Posted by JasonB on 03/03/2017 07:27:58:
Yes, I did wonder about the proportions .... maybe not for capheads after all.
Perhaps Alan could tell us the diameters
... I've had no luck searching for that Microtools reference.
Edit: another possibility is that the disproportionately large pilot diameter matches a flanged insert for use in a relatively soft component.
Edited By Michael Gilligan on 03/03/2017 08:10:10
Ian P03/03/2017 08:12:48
2747 forum posts
123 photos
Posted by Michael Gilligan on 02/03/2017 18:39:02:
Any bolts that is tightened is going to stretch, its not avoidable.
OK it might not be a measurable amount but many fixings rely on 'prevailing torque' to stop them coming undone and bolt stretch is deliberately 'designed' in to keep the two parts being held together with the correct pressure between the faces.
Ian P
Michael Gilligan03/03/2017 08:29:14
23121 forum posts
1360 photos
Posted by Ian Phillips on 03/03/2017 08:12:48:
O.K. Ian ... I should have said something like "[it reduces bolt stretch to manageable values]" ... Note: I was using "stretch" in the dynamic sense; but I hadn't made that explicit.
On a 20,000 lb thrust shaker ... I can assure you that short caphead screws, down deep counterbores, are much more effective than long ones in shallow counterbores. [see the 'head expander' that I linked.]
Feel free to continue the discussion without any further input from me.
MichaelG
Edited By Michael Gilligan on 03/03/2017 08:43:13
Martin Whittle03/03/2017 10:22:04
102 forum posts
12 photos
To return to the original photo, the counterbore on the parts is not deep - on the contrary, it is very shallow. There is little exit for the swarf, so it will completely choke up before 5mm depth is achieved. So more for shallow spot facing than a counterbore for a cap head.
But it does demonstrate a very simple way to make a custom counterbore cutter!
Martin
Edited By Martin Whittle on 03/03/2017 10:23:44
Vic03/03/2017 10:25:28
3453 forum posts
23 photos
I think it's a deburing tool.
Martin Whittle03/03/2017 10:43:59
102 forum posts
12 photos
Posted by Vic on 03/03/2017 10:25:28:
Agreed
Ian S C03/03/2017 11:07:12
7468 forum posts
230 photos
I agree, it is for deburring holes, and putting a radius on the edge. Ian S C
Richard S203/03/2017 11:10:45
237 forum posts
135 photos
Deburring is my opinion also, with the addition that the tool could produce a shallow, larger bore to allow for a dowel to be inserted leaving a relief around it's base to avoid a raised burr.
Alan Wood 403/03/2017 12:29:34
257 forum posts
14 photos
Thanks all for your thoughts.
I will store in the drawer marked 'Might be useful one Day' (which is slightly overflowing).
Alan
Roy M03/03/2017 12:46:13
104 forum posts
7 photos
They could be ejector pins from an injection mould tool, or quick change punches from a press tool. The scallops could be for retaining the pins/punch in the platen/die-set. Roy M.
