Source of 1/16 inch square silver steel sought
Mike Crossfield | 24/01/2017 17:42:49 |
286 forum posts 36 photos | I need a short length of 1/16 inch square silver steel for a clock project. Tried all my usual sources without success. Anyone know where to get some? Mike |
MW | 24/01/2017 18:07:13 |
![]() 2052 forum posts 56 photos | Mike, I think this is hard to find, I only know of round. You might want to try gauge plate as this ground flat, high carbon, harden-able stock.
Michael W
Edited By Michael-w on 24/01/2017 18:07:44 |
John Haine | 24/01/2017 18:27:13 |
5563 forum posts 322 photos | MSC Industrial do 1/8th but not 1/16. You might have to buy 1/16 gauge plate, saw out a length, and file/mill to size. |
Roy M | 24/01/2017 19:31:34 |
104 forum posts 7 photos | Mike, you can get 1/16" square key steel, this is really tough,but not sure of the hardening process. It's normally nominal size plus. RoyM |
pgk pgk | 24/01/2017 19:39:16 |
2661 forum posts 294 photos | Mo idea on price but ask these guys: **LINK** |
David George 1 | 24/01/2017 19:54:05 |
![]() 2110 forum posts 565 photos | Hi Mike What is it for and do you it need to heat treat it. If you don't live to far from (Nottinghamshire) me I have some 1/16 by 2" wide gauge plate which is the equivalent spec to silver steel and what length do you need. Send me a message if any good. David |
Bizibilder | 24/01/2017 19:57:56 |
![]() 173 forum posts 8 photos | College engineering stock some square but unfortunately not as small as 1/16 http://www.collegeengineering.co.uk/product/imperial-13-long/ Might be worth a phone call to see if they know a supplier. |
Richard S2 | 24/01/2017 20:11:22 |
![]() 237 forum posts 135 photos | Check These people out- **LINK** based in the Midlands judging by the area phone code. |
Mike Crossfield | 24/01/2017 21:41:22 |
286 forum posts 36 photos | Thanks for all the replies. It looks like I!'s probably not available. At least not in the very small quantity I need at a sensible price. I need it for a maintaining spring in a clock barrel. What matters is stiffness after hardening. Doing some sums just now it looks as though a round section would need to be about 20% greater in diameter than the side dimension of a square bar for the same stiffness. So substituting a round bar for the 1/16 square bar would means I would need a round bar 0.075 diameter. This is pretty close to 2mm, which is readily available size. So I'll go with that. Mike |
julian atkins | 24/01/2017 21:50:01 |
![]() 1285 forum posts 353 photos | Hi Mike, I have plenty of 1/8" square silver steel. I cant see me needing much of it for any future projects. I can send you whatever length you need. You can then mill or file it down to size. PM me if you want some. Cheers, Julian |
John Reese | 26/01/2017 02:07:30 |
![]() 1071 forum posts | Does McMaster Carr serve the UK? They have it in keystock, W1 tool steel, 1095 spring temper, Stainless, and more. |
Speedy Builder5 | 26/01/2017 07:01:19 |
2878 forum posts 248 photos | Why not file down a bit of round rod to suit ? |
Michael Gilligan | 26/01/2017 08:39:05 |
![]() 23121 forum posts 1360 photos | Posted by Speedy Builder5 on 26/01/2017 07:01:19:
Why not file down a bit of round rod to suit ? . +1 for that The filing of squares is a very useful horological skill. Here: on a reduced scale, I supect, is a good demonstration **LINK** http://great-british-watch.co.uk/how-to-file-a-square-on-a-cylinder/ Relevance will of course depend on your interpretation of 'a short length' MichaelG. Edited By Michael Gilligan on 26/01/2017 08:39:58 |
Neil Wyatt | 26/01/2017 09:06:12 |
![]() 19226 forum posts 749 photos 86 articles | I think I may have a bit of 1/16 SS - I'll be able to check later, what length do you need ? is it for pallets? Neil |
Mike Crossfield | 26/01/2017 10:43:51 |
286 forum posts 36 photos | Neil, It's a spring for a Harrison maintaining mechanism on the barrel of a long case clock. I need a piece about 90 mm long. Mike |
