Oil coolant pumps - which type of pump
Martin Newbold21/01/2017 11:57:32
415 forum posts
240 photos
Hi everyone which type of pump is best suited to pump oil coolant on to machined item . Are there specifics about the type of pump that is most effective to pump this and material around. Can a motor drive a pump pulley as well as the lathe head?
David George 121/01/2017 18:06:36
2110 forum posts
565 photos
Hi this is the type of coolant pump which I would recommend but you would need to have a tank with lid to support said pump. They are available in various sizes depending on tank depth and volume you need to pump and they come in single and three phase electricity supply. they work regardless for many years with little attention. I personally wouldn't run a pump from a spindle motor as it is not good to run coolant at the same time if anything goes wrong i.e. forgot to turn the coolant tap off it would take your concentration off the spindle work which could be dangerous and you could get wet with coolant. You would also need a control circuit with a no volt safety built it to the circuit.
David
Edited By David George 1 on 21/01/2017 18:08:45
Edited By David George 1 on 21/01/2017 19:14:19
Nick Hulme21/01/2017 18:24:22
750 forum posts
37 photos
Most commercial coolant pumps work on the same principle as pond pumps, I suspect that pond pumps may not be compatible with all types of coolant though.
Brian H21/01/2017 19:03:25
2312 forum posts
112 photos
I have a Vertex pump in a self contained unit similar to this from Rotagrip:
01a) Coolant Pump Kit 1/8 HP
Price per Unit (Each): £192.30
£153.84 (including 20 % tax)
You Save: 20.00%
Vertex 1/8HP Coolant Pump Kit
Fully combined unit consisting of a single phase 1/8 hp pump , flexible feed pipe, bracket to secure to your machine and magnetic base with coolant hose. This unit is ideal for the small to medium size lathe or milling machine
Specifications
Tank : 14 x 10 x 7.5"
1/8 hp motor
240 volt or 110 Volt
Capacity : 27-28 l/min @ 1m / 25-26 l/min @ 2m
Height excluding stem : 160mm
P.C.D. of mounting holes : 128mm
Diameter of impellor body : 92mm
Diameter of flange : 155mm
Outlet : 3/8NPT
Part Number 1026-030
Click here for data sheet
Mark Eisen24/01/2017 06:27:17
88 forum posts
68 photos
I am going to a washing machine pump, seen some good set ups on an Aussie forum.
daveb24/01/2017 08:47:29
631 forum posts
14 photos
I bought a used surface grinder a while ago, the PO had cobbled together a coolant system with a washing machine pump, the oil had caused all of the rubber parts to disintegrate.
Scrumpy24/01/2017 09:05:53
152 forum posts
My Mitchell lathe 8 1/2 swing X 10 ft bed has a built in pump being run from the main motor it also has a pressure valve to bypass the system some years ago it failed so we fitted a washing machine pump after adjusting the bypass it works perfect
Martin Newbold29/01/2017 11:46:37
415 forum posts
240 photos
Hi everyone and thank you for the posts am looking for a small pump for a self build on a small lathe. My post was in relation to the types of pumps as there is a lots of types usually gears are used for oil pumps and not an impellar or propellor. I am wondering if there are any small pump motors that use gears to pump. This is a water pump but i wonder if they make metal pumps at this site . Does anyone know the viscosity of the cutting liquid please?
I was thinking of something like this pump
Edited By Martin Newbold on 29/01/2017 11:57:15
David Jupp29/01/2017 11:57:56
978 forum posts
26 photos
Big advantage of centrifugal pumps is they are contamination tolerant, and will tolerate being 'shut in' on delivery side (for a while anyway). Depending on precise detail, delivery head may be a bit low (e.g. aquarium style).
Gear pump is possible, but prone to wear - quite expensive because much more difficult to manufacture. Won't be at all happy if shut in on delivery side, they are a positive displacement type and can generate high pressures.
Old fashioned fuel lift pump is another possibility. Contamination may give issues with the check valves, won't mind being shut in, as diaphragm is actually pushed back by a spring not the cam.
I bought a cheap mains solenoid pump to try - rather noisy, and again valves potentially prone to contamination problems.
Gravity feed is effective for some people - very simple.
Good luck!
Martin Newbold29/01/2017 11:59:32
415 forum posts
240 photos
Whats sort of pressure does the cooling pump ideally need to deliver?
David George 129/01/2017 12:22:56
2110 forum posts
565 photos
If you were to get a pump with 25 litre a minute at 2 meter head you would have a reasonable pressure to flush down a drilled hole with a small bore nozzle and if you turn off the tap without turning off the pump you would be better with a centrifugal type as there will be no increase in pressure with that type of pump.
David
RJW29/01/2017 12:51:42
343 forum posts
36 photos
Martin, it may be worth you looking at something similar to the parts cleaner shown in the link, you could use it as either a parts cleaner or a coolant tank and pump combined, they're designed to pump solvent as well as crap that escapes a filter, all the data you need is probably on the listing,
I've no connection to the seller, it's just to illustrate an alternative solution which would work for you,
I've saved a 'Safety Clean' parts washer pump myself for just such a job and which came as a spare with my parts cleaning tank, the intention being to make a coolant tank for the lathe, but the mill I bought last year came with a portable unit and has saved me the trouble,
I'll post a photo up of the pump unit later, it came with a flexible metal hose and appears to be a dead ringer for that shown in the listing.
**LINK**.
Mark P.29/01/2017 13:53:01
634 forum posts
9 photos
A few years ago I picked up a 240 volt"vibrating" type of pump off ebay. It came with a strainer, I mounted it in a plastic 5 liter paint kettle from Wlikos. Good rate of flow and had no problems with it, works for me.
Mark P.
David Jupp29/01/2017 14:19:01
978 forum posts
26 photos
Posted by Martin Newbold on 29/01/2017 11:59:32:
At least enough to lift the chosen fluid from bottom of your reservoir to the highest point in the pipework - plus a bit more if you want it to do more than crawl out of the end.
Assume a soluble oil (so treat is as water for calculation), say 1.5m lift height (lets say 2m for luck) - that's about 0.2 bar or 3 psi. If piping is very small or fluid particularly viscous, add some more to cope with pressure drop.
John Reese29/01/2017 17:58:25
1071 forum posts
I have used submersible pond pumps successfully for many years in water based coolants. Not sure if they are compatible with straight oil.
A lot of old machines used gear pumps. As already said, they don't tolerate particulates very well. If worn they don't prime well. If you want to go the gear pump route chjeck out carbonator pumps.
Martin Newbold01/02/2017 21:25:13
415 forum posts
240 photos
Hi RJW yep still to big though any idea what pump motor the parts washer uses please?
David by centrifugal i presume you mean like a slurry pump that will cope with particles I.e a rotating disc witch is like a slinger.
John are carbonator pumps this centrifugal design is there a particle size limit
Thanks for all your help
M
Muzzer01/02/2017 22:06:03
2904 forum posts
448 photos
Central heating pumps are pretty rugged and silent, and can develop a fine pressure head (~5m) and a decent flow rate. They are also very simple centrifugal pumps and don't cost a lot, particularly if you find a used one. The main problem is that they don't self prime, so you need to mount them below the fluid level.
This is a typical (Grundfos) performance characteristic:
RJW01/02/2017 22:46:23
343 forum posts
36 photos
Posted by Martin Newbold on 01/02/2017 21:25:13:
M
Hi Martin, sorry I'm still looking for the spare pump for my machine, it's buried somewhere under all the clutter I've been moving into the building, I'll pull the tank off my machine and take a shot of that next time I'm in there,
It's a different pump I think to what the tank uses shown in the link I gave,
From memory it's about 100mm diameter and deep, 240V, plenty of pressure too, you can get a fair old fan of spray by covering part of the knozzle, but the motor doesn't stall if you shut off the end, so the delivery could be regulated with a tap, it does need to be submerged, but you could shove it in a 5 litre container if size of the tank is an issue,
Something like this might do the job:
John.
RJW01/02/2017 22:54:39
343 forum posts
36 photos
Martin, done a bit of digging around on the web, the pump in the link is the same as mine, there's a data spec' on the listing that should help.
What about a fuel transfer pump?
John.
Edited By RJW on 01/02/2017 23:07:37
mgnbuk02/02/2017 07:40:23
1394 forum posts
103 photos
But CH pump motors have sleeve bearings that are lubricated by the pumped liquid, so would require pretty good inlet filtration to give reasonable bearing life.
Nigel B
