Dickson Toolpost - Tool Holder Rack
Has anyone made a tool holder storage rack?
Steve Addy04/01/2017 16:37:37
158 forum posts
107 photos
Hi everyone.
I have just treated my lathe to a New Year clean and was thus moving and cleaning Dickson tool holders. I really have too many for them to be kicking about in the swarf tray and it set me wondering if there was an existing design for a storage rack.
An Internet search has only found aluminium ones for the dovetail type beloved of the Americans.
I was thinking of a few laser cut blades to slot them on. Stainless would be nice as it would remove the need for paint which would scrape off in use anyway.
Steve
Peter Spink04/01/2017 17:01:22
126 forum posts
48 photos
I seem to remember Model Engineers Laser did a kit but it's not on their website. I would like one too.
Peter
Jez04/01/2017 17:29:21
58 forum posts
Hi Steve,
I've made two, both to the same basic design - a flat bar with a series of pins let into the bar perpendicular to it, one at each end of the tee slot in the back of the toolholder, if that makes sense.
The first I made of wood and used dowel glued in (for T2 size holders), the second I made from steel with 6mm rod "puddle" welded from the back side (for S1 size holders).
HTH!
Jez.
mechman4804/01/2017 17:29:22
2947 forum posts
468 photos
I have used clip in shelf brackets screwed to the back shelving...
​George.
Steve Addy04/01/2017 17:44:03
158 forum posts
107 photos
Thanks guys. That was quick.
I know Malcolm of ME Laser, so I could ask him.
The two pins make sense and I was thinking of mounting them upright as they are used. Now I'll have to have a look to see if they are better as in George's pictures as I hadn't thought of that. Should be better for storing ones with large boring tools
I have a serious shortage of feline swinging room!
Steve
Nick Wheeler04/01/2017 18:22:11
1227 forum posts
101 photos
Mine is made from ten pieces of 25x1mm steel strap 70mm long with a roughly 30degree bend in them. These are welded to a length of 25x3mm steel left over from a previous project, and the whole thing is screwed to the cupboard wall next to the lathe.
and
That's about 30minutes work, which includes the 'design', and about a fiver in materials.
Gray6204/01/2017 18:35:10
1058 forum posts
16 photos
If you have access to the magazine archive, there is a photo in MEW84 of Barry Jordans Carousel tool holder and in MEW 183 there is an article on construction of a similar design as shown below:
Steve Addy04/01/2017 20:34:37
158 forum posts
107 photos
Thanks folks, Some food for thought there.
Nigel Bennett07/01/2017 17:53:27
500 forum posts
31 photos
I screwed two No.8 round-head wood screws into a board; these are spaced and stick out so that a toolholder will slide over them and the Tee section will slip under the heads and be retained by them. A short length of thin hardwood is screwed beneath the round-head screws to act as a stop for the toolholder. Pretty inexpensive - four screws and a short piece of wood per holder.
I made up a jig - two "tapping size" holes accurately spaced in a piece of steel bar - to ensure repeatability of drilling for the RH screws.
Antony Price05/02/2017 13:13:20
36 forum posts
29 photos
It has been a busy month, so I’m only just catching up with the Forum!
I can’t take credit for the idea. I stumbled across it on Pinterest.
The aluminium angle was an off-cut from when I relocated the leisure batteries in the mobile home.
The DIN rail was left over from when I rewired the milling machine. The screw slots in the DIN rail, made putting it all together very easy, and the design can be scaled
I did make a Lantern Chuck to size the screws, but that has already proved useful for other projects
thaiguzzi11/02/2017 13:56:56
704 forum posts
131 photos
Edited By thaiguzzi on 11/02/2017 14:04:15
thaiguzzi11/02/2017 14:05:34
704 forum posts
131 photos
Perspex shelf.
Gordon A11/02/2017 21:02:48
157 forum posts
4 photos
Offcut of mdf architrave, (top half slopes back at about 10 degrees) + offcuts of 1" (25mm) aluminium angle cut to length to fit slot of toolholder.
Steve Addy11/02/2017 21:32:20
158 forum posts
107 photos
Thanks for all the replies, not made anything for a couple of weeks, lathe still clean. I'm down with the lurgy!
Steve
thaiguzzi19/02/2017 03:49:10
704 forum posts
131 photos
Posted by Gordon A on 11/02/2017 21:02:48:
I like the cutting fluid bottle rack. Neat idea.
