oil or grease
Richard Cleaver | 08/11/2016 16:56:35 |
![]() 15 forum posts | So today's annoyingly amateurish question concerns coolants. Back at school I vaguely remember having to apply a swarf(?) grease with an old brush and am aware that turning and cutting metal will require cooling. I've seen some using a few drops of what looks like oil on their work administered from a small squeazy bottle or oil can. As I only have a micro lathe I would probably administer this way rather than an expensive cooling system. That being said, what should I use? I will mainly be using ally or nickel/brass alloy if that helps. |
fizzy | 08/11/2016 17:18:58 |
![]() 1860 forum posts 121 photos | you shouldnt need any coolant so long as you take light cuts. I rarely use it and when I do I use a small hand held spray with straight water. |
SillyOldDuffer | 08/11/2016 17:27:16 |
10668 forum posts 2415 photos | I use CT90 Cutting and Tapping fluid most of the time but it's pricey. Paraffin (from a Garden Centre) is good for Aluminium. Not sure about Nickel/Brass alloys but I turn Brass without any fluids. Carbide tips are all or nothing - don't dab coolant on them because thermal shock tends to crack the carbide. A lot of the time cooling isn't necessary when taking light cuts. Using coolant regularly keeps tools sharp longer and improves finish though. Heavy cuts are a different story, but they're not a good idea on a small lathe. Dave |
Emgee | 08/11/2016 17:38:03 |
2610 forum posts 312 photos | Richard Light spray of WD40 will assist the cut and prevent any build up on the tool from the ally, or you could buy any of the advertised cutting fluids available, some are used neat and others are soluble in water. there is such a wide choice at reasonable cost on ebay. Emgee |
JA | 08/11/2016 17:54:39 |
![]() 1605 forum posts 83 photos | Richard I would use a neat cutting oil applied by a small brush for all metals other than brass and cast iron. Obviously, given your lathe, you will not need much. You will find such oil sold in small amounts, 500ml plastic bottles, by model engineering suppliers. One small advantage with such oils over water or soluble cutting oil is that it will not corrode or mark the lathe. JA |
mechman48 | 09/11/2016 12:04:39 |
![]() 2947 forum posts 468 photos | Posted by Emgee on 08/11/2016 17:38:03:
Richard Light spray of WD40 will assist the cut and prevent any build up on the tool from the ally, or you could buy any of the advertised cutting fluids available, some are used neat and others are soluble in water. there is such a wide choice at reasonable cost on ebay. Emgee +1... if you need to have some form of coolant on a particular material & you have nothing to hand it has been known to use veg'/rape seed cooking oil, or light viscosity 32 grade hydraulic / engine oil, there is always some form of lubrication / cutting fluid around the house for immediate needs. George.
Ian S C | 10/11/2016 10:08:56 |
![]() 7468 forum posts 230 photos | Except for brass and cast iron(these are cut dry), some form of cutting oil will reduce the load on the lathe, meaning that you could take a little bigger cut, or faster feed. If you try carbide tools, cut dry on all metals. Ian S C |
