what size rotary table?
mick7003/11/2016 08:25:35
524 forum posts
38 photos
had couple of jobs where i needed rotary table that i have had to ask someone at club to do for me.
i don't have milling machine at min ( or workshop ) but do have 5.5" lathe chuck mounted to steel plate that easily fits on both my drill press and one at club.
planning on getting rt so i can do the bits myself and planning on good size milling machine when i get workshop sorted.
question is what size 4 or 6 inch?
plan is to use extra money at end month to get tooling ready for when i move.
Michael Gilligan03/11/2016 08:43:19
23121 forum posts
1360 photos
I would go for the 6" ... They are typically more robustly built than the 4"
Simon Collier03/11/2016 08:50:36
525 forum posts
65 photos
I have both. The 4" has a chuck mounted permanently. I use it almost exclusively, but the 6" comes out for e.g., rod bosses. Also, the 4" is a nice blue but the 6 is that ugly rough black finish. Both Vertex.
Roderick Jenkins03/11/2016 08:55:39
2376 forum posts
800 photos
Mine's only 4" and I wish it were 6 sad. Mostly because the clamping arrangements can take up more room than the job.
Rod
Brian H03/11/2016 08:59:42
2312 forum posts
112 photos
I have a Vertex 6" and even that can sometimes be a problem with the clamps taking up room as mentioned by Roderick.
I think the 6" is the way to go though.
JA03/11/2016 09:09:43
1605 forum posts
83 photos
I bought a 4" Vertex rotatory table because it was lighter than the 6". Obviously the 6" would have been more useful but I would not have used it often because of the weight.
JA
Chris Evans 603/11/2016 09:16:48
2156 forum posts
Depends on what mill you end up with. I have a 10" Vertex for my Bridgeport, bigger would be nice for my sort of work but the 12" plus jobbies take some lifting when you get older.
Ian S C03/11/2016 09:44:14
7468 forum posts
230 photos
When you get much over 6" it's a good idea to build , or obtain some form of crane, or hoist. With a windscreen wiper motor, or similar you can have it power operated.
Ian S C
Tim Stevens03/11/2016 10:15:16
1779 forum posts
You need to be sure that your table, when fitted upright on the mill, does not overhang too much, preventing you from using the bolt lugs to hold it down. So, you might delay your table purchase until your mill needs are sorted, or even as this is the season for presents, get the mill now as a present to the most deserving person you know, and you will know which table fits.
Cheers, Tim
Paul Jarvis 203/11/2016 10:46:34
13 forum posts
Totally agree with Tim you need to ensure that the table is not to big for your machine and that you have enough machine table movement to use the table effectively.
However in my experience if you can fit a larger size table to your machine then that is the one to buy. Clamping arrangements as said before generally take up a lot of table space. I have a 6 inch and an 8 inch unit and struggle sometimes with the 6 inch to clamp up the work effectively.
Cheers, Paul
Michael Gilligan03/11/2016 11:04:53
23121 forum posts
1360 photos
Posted by naughtyboy on 03/11/2016 08:25:35:
... i don't have milling machine at min ( or workshop ) but do have 5.5" lathe chuck mounted to steel plate that easily fits on both my drill press and one at club.
dont know Given these opening remarks; I find the enthusiasm for 4" rotary tables rather surprising.
Paul Lousick03/11/2016 11:08:50
2276 forum posts
801 photos
I would reccommend you purchase the bigest RT that will fit your mill. See my post about one that failed.
I am still fighting to get a replacement part.
Paul.
Ian S C04/11/2016 11:24:47
7468 forum posts
230 photos
The one major problem I have with the 6" Vertex that I have is that with the 8" chuck from my lathe mounted on it I have about 2" clearance with the Rexon mill head at maximum height and the drill, or milling chuck. A collet in the MT3 gives a couple of inches more.
Ian S C
