14mm spanner
Vic28/10/2016 11:51:08
3453 forum posts
23 photos
I worked as a mechanic many years ago and thought I had all the spanners I would ever need. Some time ago though I found a nut or bolt that needed turning and my digital caliper told me I needed a 14mm spanner. Spanner bought and job done but I never did check what size thread it was. Looking back the most used spanners in a Ford main dealer were 10, 13, 17 and 19mm AF. Looking in my tool box though I also have a 15mm Snap-On spanner. According to a chart I looked at recently it's not a common size but I must have bought it for a reason! Anyone know what size fastener threads are used with 14mm and 15mm spanners?
I thought there was some kind of law against non standard spanners ... cheeky
Jon Gibbs28/10/2016 11:58:54
750 forum posts
Hi Vic,
According to this table it could have been either a 9mm fastener or a Japanese 10mm...
Jon
Mike Poole28/10/2016 12:46:59
3676 forum posts
82 photos
14 is a common size used on motorcycles and often you will find the finer metric thread pitches and just to be totally mad brake bleed screws can be M7x1.
Speedy Builder528/10/2016 13:03:24
2878 forum posts
248 photos
Was it for undoing hazel nuts at Christmas?
Hopper28/10/2016 13:10:52
7881 forum posts
397 photos
+1 on motorcycles. Had to buy 14mm socket and spanner to add to my kit years ago for working on my Laverda and more recently Honda. Never thought to measure the thread size though. 8mm I would have presumed. Will check next time I'm in the shed.
Nick_G28/10/2016 13:12:41
1808 forum posts
744 photos
A lot of Japanese motorbikes will have a 10mm thread that requires a 14mm spanner on the head. Fairly normal.
Nick
Gordon W28/10/2016 14:05:07
2011 forum posts
My Chinese stuff uses 14 mm spanner for M10 , Cit. 2CV uses 11mm for M7 nuts and 14 mm for M9 nuts.
Trev6728/10/2016 14:07:56
37 forum posts
Hi
14mm is common on a lot of jap cars, I think the thread is M10 but fine pitch, they also use 12mm heads on M8 bolts instead of 13mm. Also nowadays you get a lot of 15, 16, 18 mm heads that you never used to. Also come across 7 and 9 mm hex on bleed nipples and 9mm 12point bolts on a vw clutch. Along with all the various torx, ribe and other fixings, there's always something to spend money on!
Trevor
Old Elan28/10/2016 14:10:41
92 forum posts
34 photos
Bicycle pedal spindles are generally 15mm across the flats with a 9/16" x 20 right or left thread.
My tool kit for modern vehicles and bikes comprises 8mm through to 17mm (others as well, eg 19 and 23) and they all get regular use.
I still have the Whit and AF kit of course.
Edited By Old Elan on 28/10/2016 14:14:55
Mike Poole28/10/2016 14:20:43
3676 forum posts
82 photos
Get a Volkswagen and you will find a use for those 16 and 18 millimetre spanners, those bolts that look at first glance like torx may well be spline drive.
Edited By Michael Poole on 28/10/2016 14:23:35
Nick Hughes28/10/2016 15:41:44
307 forum posts
150 photos
DIN Standard nuts, rather than the more usual ISO?
Hacksaw28/10/2016 16:00:58
474 forum posts
202 photos
Jap 12mm head 8mm thread drive me up the wall !!! The bolts you then lose, get replaced with a 13mm head and the next time you want to remove it you're hammering on the 12mm socket...
Did i just say that? cheeky
15mm is for certain Whitworth bolts smiley.... and that 1 annoying spanner , not 14mm ,nor  9/16    bsf  is it ?? It only fits that particular bolt...
Edited By Hacksaw on 28/10/2016 16:07:41
Vic28/10/2016 19:15:52
3453 forum posts
23 photos
I'm getting the impression this "problem" has been caused by the Japanese and the Germans then?! I thought we won the war. wink
Nick Wheeler28/10/2016 19:16:53
1227 forum posts
101 photos
It's why every tool manufacturer sells spanners/sockets in sets. I'd never used a 15mm spanner until I bought a BMW. Before this week, the only place I'd used my 7mm socket/spanner was on Jubilee clips; it's since had a workout on Sukhoi turnbuckles.
Does it really matter if a European M8 bolt uses a 13mm spanner and a Japanese one is 14? It's the need for hex, internal hex, the same in Imperial and Whitworth, then Torx, E-Torx, Ribe etc, etc that rankles. 22 years ago I inherited some BA spanners from my Grandfather, that I've never used, but they are another standard.
Edited By Nicholas Wheeler 1 on 28/10/2016 19:18:37
Bob Youldon28/10/2016 19:30:55
183 forum posts
20 photos
Hi Vic,
I've got a metric adjustable!
Bob
Roy M28/10/2016 19:38:26
104 forum posts
7 photos
Hydraulic and pneumatic fittings use thes sizes.
JA28/10/2016 19:46:41
1605 forum posts
83 photos
Posted by Vic on 28/10/2016 19:15:52:
That's why we use Whitworth threads.
JA
Chris Evans 628/10/2016 20:31:38
2156 forum posts
You will have bought the 15mm spanner for working on Ford brakes.
Vic28/10/2016 20:42:14
3453 forum posts
23 photos
Posted by Chris Evans 6 on 28/10/2016 20:31:38:
Thanks for that, I was wondering! smiley
John Parry 429/10/2016 18:08:08
11 forum posts
Hullo all,I am surprised no one has mentioned that a 15mm is very close to a 5/8 American AF spanner. As I was a mechanic in the 1960/ s 70/ s the British industry had moved to UNF & UNC at that time. At the dealership I was at we were sub agents for Ford & Renault,so having MM spanners as well was normal. The new R8 cars arrived with a nice tool roll with 3 spanners,a plug spanner & a wooden handled screwdriver. Of course the lads soon increased their tool kit with these ! The biggest of the 3 was 14 & 17 in size, with The name Renault on one side. I still have some of these which are used occasionally. Just to mention,just for fun. Can you bend a spanner in your hands ? I can. I have some Stahwille A/F ones. Put one in a vice,push hard,it bends but of course comes back again. Now try that with a Britool or any other. Why ? A superior kind of steel I suppose.
