Richard Dobson | 11/09/2016 10:59:53 |
27 forum posts 1 photos | Hello everyone, my names Richard or Rich, don't really mind what I'm called. I'm new as new can be to ME. Picked up a mini lathe a few months ago, and been loving it ever since. I am practical minded thankfully, and a quick learner. My ambition is to talk the wife into allowing me to purchase a Mill/Drill, so I can start some nice little projects. I will if possible try to sponge up as much info as I can from you guys... Thanks. |
Thor 🇳🇴 | 11/09/2016 14:10:06 |
![]() 1766 forum posts 46 photos | Welcome to the forum Rich, you will probably learn a lot here, I know I do. Thor Edited By Thor on 11/09/2016 14:16:27 |
Richard Dobson | 11/09/2016 18:39:19 |
27 forum posts 1 photos | Thanks Thor, yeah eager to learn asap. I'm located in Leighton Buzzard, Bedfordshire. Anyone nearby???? |
Brian Wood | 11/09/2016 18:50:51 |
2742 forum posts 39 photos | Hello Rich, |
Richard Dobson | 11/09/2016 18:56:49 |
27 forum posts 1 photos | Brian, It's certainly changed since I was younger, although I'm only 35, so still a young pup If anyone has one tip that they wished they knew when starting out, what would it be? Thanks Guys.
Bazyle | 11/09/2016 19:22:26 |
![]() 6956 forum posts 229 photos | Nice timing. MEX next weekend and the superb St Albans Model Engineering Society show the following weekend. |
SillyOldDuffer | 11/09/2016 19:52:35 |
10668 forum posts 2415 photos | Posted by Richard Dobson on 11/09/2016 18:56:49:
... If anyone has one tip that they wished they knew when starting out, what would it be? Thanks Guys.
Find a supplier of brass, aluminium and steel that's intended for machining, either locally or on the web. When I first had a mini-lathe I fed it with anything that came to hand and the results were often disappointing. Most of the scrap metal in my garage was bad news. Sticky aluminium, gritty steel, tough welded pipe, and work hardening stainless. DIY store metal is mostly horrible too. Cutting decent metal with sharp tools made a huge difference. Tip two: don't get discouraged when you make mistakes. It's all part of the fun. Enjoy, Dave
Neil Wyatt | 11/09/2016 23:40:24 |
![]() 19226 forum posts 749 photos 86 articles | Welcome to the forum Richard. You might be better going to WebMD with those ears... Neil |
I.M. OUTAHERE | 12/09/2016 06:01:58 |
1468 forum posts 3 photos | Don't be afraid to ask , Assume nothing and take the chuck key out of the chuck before hitting the on switch - they hurt when they hit you but hurt even more when they plough out a nice big chunk of your previously undamaged lathe bed ! Ian. |
not done it yet | 12/09/2016 06:12:31 |
7517 forum posts 20 photos | Perhaps getting a mini vertical slide for your mini lathe might be a good idea for getting into projects? Depends on how one interprets the 'little' in your post, I suppose.
It's not another 'separate' purchase, only an 'addition' to the lathe, so may not 'need' executive approval. Look on it as 'another lathe tool'? |
Iain Downs | 12/09/2016 07:38:39 |
976 forum posts 805 photos | My Tips are, don't buy metal from a scrapyard (see what SillyOldDuffer says). Lock your vertical axis (and any others you can) when you get a mini mill. Don't go too small on your mini-mill. I wish I'd got a bigger one (I have a CMD10 /Sieg X1) Come back to Yorkshire. It's crackin' up here!
Iain |
mechman48 | 12/09/2016 09:58:12 |
![]() 2947 forum posts 468 photos | Welcome Rich, lot's of help on here, just remember that there isn't a 'stupid' question ... just one that you haven't got the answer to... yet! George. |
Andrew Johnston | 12/09/2016 10:06:03 |
![]() 7061 forum posts 719 photos | Posted by Richard Dobson on 11/09/2016 18:56:49:
If anyone has one tip that they wished they knew when starting out, what would it be? If I had realised I suffered from OIS and hence how much old iron I would thus acquire I'd have bought a bigger workshop, or at least organised it differently. There are also two rules to obey, once you've bought proper material of known provenance: Rule 1 - Never buy cheap cutting tools Rule 2: See rule 1 Andrew - near Cambridge OIS = old iron syndrome |
Richard Dobson | 12/09/2016 21:52:59 |
Thanks everyone, lots of good advice for me to chew on! Has anyone used Chronos ltd in Dunstable for stock and tools. It's only 20 minutes down the road if it's any good? Thanks again.
Howard Lewis | 12/09/2016 22:11:31 |
7227 forum posts 21 photos | Hi Richard! Welcome. (i am a little further north, just off the A1 and A47) You will get a lot of advice and knowledge here, (and some leg pulling). When I first started, I was a Chronos customer, (still am from time to time), but mostly deal with Arc EuroTrade. Ketan sometimes posts on here. he is a really fair minded bloke, and will help even when there is nothing in it for him as a trader. Tooltips, I tend to buy from Jenny at J B Cutting Tools. Again, a pleasure to deal with, and is at most of the shows. Try making a Tangential Tool Holder, it will be time well spent, and cheaper than buying one. You can make a lot of tools and fixtures for that "one off" job, and save time and temper! If you are not a member, do find your local M E Club and join. Again, you should get a lot of help and advice. If you have a problem having someone come round and help, hands on, or saying "Bring it round, and we'll sort it out" is a HUGE help. Enjoy yourself Howard |
Andrew Johnston | 12/09/2016 22:12:07 |
![]() 7061 forum posts 719 photos | Posted by Richard Dobson on 12/09/2016 21:52:59:
Has anyone used Chronos ltd in Dunstable for stock and tools. It's only 20 minutes down the road if it's any good? Stock never, tooling infrequently in the past, but I had some issues, so I don't use them now. Instead I use commercial tool merchants. Bear in mind though that I have industrial size machines; the Chronos offerings may well be fine for the smaller mini lathe. Others will be more qualified to comment. Andrew |
Reg Rossiter | 13/09/2016 08:47:50 |
![]() 29 forum posts | Richard, I've used Chronos, amongst others, regularly over the years and haven't had any issues. If they are only 20 minutes down the road you can see what you are buying and potentially save on a lot of postage charges. Reg |
Brian Wood | 13/09/2016 09:08:25 |
2742 forum posts 39 photos | Hello Richard,
Ketan Swali | 13/09/2016 10:43:28 |
1481 forum posts 149 photos | Hi Richard, Welcome to the forum. - I would direct you to invest in Neil Wyatts book on the Mini-lathe. - Join a club...probably St.Albans ME club in your case. - Look up classes at SMEE in London. I think train goes from St.Albans to Loughborough Junction station in London, walking distance to SMEE. You will probably bump into like minded people boarding at St.Albans going to SMEE on first Saturday of each month. - to be fair, Chronos are a good business and very close to you. You get what you need for the budget you have. This may be good, bad or ugly, and also open to perception/misperception for the price. So do go and pay them a visit. They are good people, just like most of the model engineer suppliers... including ARC, even if I do so so myself. - Above all, this is a hobby... so enjoy. Ketan at ARC. |
NJH | 13/09/2016 12:32:32 |
![]() 2314 forum posts 139 photos | Richard - welcome Advice? - old but true :- Measure twice, cut once. . .. If you don't know just ask. ENJOY. ... it IS a hobby ! Norman |
