blowlamp | 03/09/2016 12:39:55 |
![]() 1885 forum posts 111 photos | I linked to this router on the previous page of this thread with no responses, but I do see it as another way forward. Edited By Neil Wyatt on 04/09/2016 20:08:32 |
john swift 1 | 03/09/2016 12:56:12 |
![]() 318 forum posts 183 photos | Hi Martin I guess the previous one line post was easy to over look I think I've only used a hand held router half a dozen times and a device like that would of made it easier to make things fit first time it reminds me of a video of an industrial robot in a car factory using another robot with a better position resolution to glue windscreens in place the question is can you justify buying one John PS at $2000 , I think I'd buy a CNC milling machine first instead of the shaper origin it will be more usefull to me
Edited By john swift 1 on 03/09/2016 13:12:48 Edited By Neil Wyatt on 04/09/2016 20:08:38 |
BW | 04/09/2016 14:05:00 |
249 forum posts 40 photos | Posted by blowlamp on 03/09/2016 12:39:55:
I linked to this router on the previous page of this thread with no responses, but I do see it as another way forward. Martin, That thing is amazing. Would it be possible to safely cut aluminium with it, holding it freehand ? Bill Edited By Neil Wyatt on 04/09/2016 20:08:45 |
blowlamp | 04/09/2016 19:57:42 |
![]() 1885 forum posts 111 photos | Posted by Bill Wood 2 on 04/09/2016 14:05:00:
Bill. It's a fantastic piece of kit, isn't it? I can see it changing the lives of joiners and cabinet-makers for ever! It certainly appears to be capable of making parts many times larger than most CNC routers are able to produce, which I find surprising in itself. I read that it could cut aluminium, but obviously with limitations. I don't see working from a sheet being a problem.
Martin. Edited By Neil Wyatt on 04/09/2016 20:04:55 |
JasonB | 04/09/2016 20:00:53 |
![]() 25215 forum posts 3105 photos 1 articles | Depends on the size of the CNC router, its mostly the size of the sheet material that is the limiting factor Edited By Neil Wyatt on 04/09/2016 20:05:12 |
Neil Wyatt | 04/09/2016 20:04:37 |
![]() 19226 forum posts 749 photos 86 articles | Moved here as its a useful discussion. |
Michael Gilligan | 04/09/2016 20:19:51 |
![]() 23121 forum posts 1360 photos | The concept looks great; but I have a couple of concerns:
MichaelG. |
Ed Duffner | 05/09/2016 01:22:18 |
863 forum posts 104 photos | Posted by JasonB on 04/09/2016 20:00:53:
and how far the operator can reach across the work safely. Ed. |
JasonB | 05/09/2016 07:27:29 |
![]() 25215 forum posts 3105 photos 1 articles | The other couple of things I have not been able to see on some of the videos are 1. How does it know how deep you can go on a single pass, sort of comes back to teh CNC thing where the operator already needs to know depth of cut etc. 2. No mention of climb cutting which can give quite a kick on a handheld router so again operator would need to know some basic router do's and don'ts. 3. if working on an edge and the machine starts to wobble a bit which being more top heavy it is likely to do this will alter the positioning cameras distance from the tape strips so will it then give a wrong position. Does look to have its uses, I think I may tend to use it to cut a template to run the usual router or spindle moulder fence up against more than direct onto the work but depends on job in hand. |
BW | 06/09/2016 01:12:38 |
249 forum posts 40 photos | Would there be any benefit in winding the work past a machine that was held stationary on a post of some sort ? The tool would then cut a profile along that section and there wouldnt be any "grabbing" induced mistakes. I dont know how normal cnc works - is that a normal part of a cnc machines capabilities or do they work following a different sort of logic. Point me to a good introductory web page or book please ?
Bill |
JasonB | 06/09/2016 07:34:21 |
![]() 25215 forum posts 3105 photos 1 articles | You would have to have control of the work being fed into the router for there to be minimal risk of a snatch, think of it like resting a bit of metal plate onto your mill table and just pushing that into the spinning cutter by hand. Woodworking machines that use the principal of hand feeding into a spinning cutter like a spindle moulder or mounted router make use of fences, lead in pins, templates and what is known as limiters do stop the blades taking too large a bite. You also need twice the space to feed say an 8x4 sheet under a stationary cutter as you do to move the cutter over the top of a stationary sheet. |
Neil Wyatt | 07/09/2016 15:06:02 |
![]() 19226 forum posts 749 photos 86 articles | Slightly off topic, I've just got out my big router to take ~1/8" off two doors and tidy up a slab of worktop to go on a fridge. I feel guilt looking at my not insignificant cutter collection (a couple of dozen?) and feel a bit guilty about not using them. I think I've only used three. Not sure I'm ready to subscribe to Routing International or New Router for ideas, but if anyone fancies writing a series on how to make a nice traditional toolbox using a router I'm interested Neil |
JasonB | 07/09/2016 16:26:49 |
![]() 25215 forum posts 3105 photos 1 articles | I could but readers may not want to spend the £500 to get a dovetail jig the same as mine Mill is good for finger joints which would do.
Neil Wyatt | 07/09/2016 18:33:02 |
![]() 19226 forum posts 749 photos 86 articles | Posted by JasonB on 07/09/2016 16:26:49:
I could but readers may not want to spend the £500 to get a dovetail jig the same as mine EEK! |
John Stevenson | 07/09/2016 18:53:14 |
![]() 5068 forum posts 3 photos | I can laser engrave fake dovetails ! . . No? . . Ok I'll get me coat ![]() |
Bazyle | 07/09/2016 20:14:48 |
![]() 6956 forum posts 229 photos | Perhaps making a dovetail jig is an appropriate MEW topic. Even for those curmudgeons who think ME has to be only metal and only steam helping woodworkers by making or repairing tools for them is a potential way to make friends and further the overall reputation of metal men in sheds. |
