David Robinson | 20/08/2016 21:50:12 |
10 forum posts 5 photos | Yesterday I was milling out the T-slots in my new Vertex rotary table to 12mm, the same as my mill table (who would want 11mm T-slots anyway?). I wanted to chamfer the edges of the slots but I don't have a chamfering cutter. After trying a few countersink cutters that wouldn't cut, I found a 90deg spotting drill that worked well when used like an end mill. Having decided I should invest in a 'proper' chamfer mill, I've now only been able to find them in solid carbide. Other than that there only seem to be the expensive and quite large carbide insert tools, and cheap sets of what look like countersink cutters with slim shanks. Chamfering must be a common enough operation, so the question is, what do others use? David |
John Baron | 20/08/2016 22:00:40 |
![]() 520 forum posts 194 photos | Hi David, Depending on how big you want to make the chamfer, I use woodwork router cutters. A 45 degree cutter should work nicely.
Daniel | 20/08/2016 22:08:32 |
![]() 338 forum posts 48 photos | I use an HSS dovetail cutter. Daniel
John Reese | 21/08/2016 03:30:28 |
![]() 1071 forum posts | I have used a multi flute countersink. |
Thor 🇳🇴 | 21/08/2016 06:22:58 |
![]() 1766 forum posts 46 photos | Like John, I use a multi flute HSS countersink. Has worked for me. Thor |
JasonB | 21/08/2016 07:35:00 |
![]() 25215 forum posts 3105 photos 1 articles | I use one of the Little Hogger sets (3/4" shank) that Chronos do which includes a 45deg cutter. The set is no more expensive than a "Angle shank" cutter as they are known for chamfering as similar size one with say 1" dia head in HSS would set you back about £50 from the likes of MSC. On small stuff a spotting drill will do as you have found. Edited By JasonB on 21/08/2016 07:35:24 |
Chris Evans 6 | 21/08/2016 09:14:26 |
![]() 2156 forum posts | Having access to a cutter grinder I make my own from worn out slot drills and the odd one from 4 flute end mill. |
Andrew Johnston | 21/08/2016 13:49:02 |
![]() 7061 forum posts 719 photos | I don't think chamfering is that common? I normally just break edges with a needle file. If I really need to chamfer an edge I use a chamfer mill: If it looks new, that because it is, I've hardly used it. Andrew |
Neil Wyatt | 21/08/2016 15:23:30 |
![]() 19226 forum posts 749 photos 86 articles | Anyone who got the 'Mango Handle' free gift should have discovered the delight of breaking edges with a proper deburring tool It's worth buying a variety pack of tips (brass, steel CI, plastic, Ally) standard tips suit the handle. Neil |
Vic | 21/08/2016 16:01:43 |
3453 forum posts 23 photos |
Posted by Andrew Johnston on 21/08/2016 13:49:02: I don't think chamfering is that common? I normally just break edges with a needle file. If I really need to chamfer an edge I use a chamfer mill: If it looks new, that because it is, I've hardly used it. Andrew It's called a Drill Mill. I have one as well. You can use it for spot drilling as well as chamfering. Forgot to add, you can get Drill Mills here but I got mine on eBay. Edited By Vic on 21/08/2016 16:07:59 |
GoCreate | 21/08/2016 16:54:34 |
![]() 387 forum posts 119 photos | Hi David I just use part of the radius of a ball nose end mil/slot drill of which I have several sizes. I just eyeball the cutter position to get what looks like a 45 deg chamfer of the required width. Although mostly I would just file it.
Nigel |
David Robinson | 21/08/2016 20:23:39 |
10 forum posts 5 photos | I think I will go for a multi-flute HSS countersink for now and see how often I use it. I do like the look of the Little Hogger set though... Thanks to all for your advice, it is great to have all that experience on tap. David |
