Micro angle grinder?
Bill Mull17/08/2016 21:39:38
33 forum posts
Hi all,
I know this could be a bit agricultural,but I have a need on a job for a smaller than usual angle grinder. One with a disc diameter of around 70mm .Has anyone come across such a thing, something fairly cheap would do fine .
Thanks
peak417/08/2016 21:58:50
2207 forum posts
210 photos
If you can get in with a straight rather than angle grinder, and have an air supply, try doing a search for air cutoff saw, such as this one from Machine Mart, though there are many cheaper ones available off ebay.
Edited By peak4 on 17/08/2016 21:59:06
Edited By peak4 on 17/08/2016 21:59:22
not done it yet17/08/2016 22:01:12
7517 forum posts
20 photos
A 4'' with a worn down disc? Dremels are at the other end of the spectrum? How about a grinder on a flxible power drive, similar but larger than those supplied with dremels. Similar to those used that clean up and polish engine ports/heads, etc? An air tool is most likely the easiest option, if not so quiet, for your purpose?
For what purpose, btw. Might help to know?
Roderick Jenkins17/08/2016 22:22:05
2376 forum posts
800 photos
Proxxon do one . Not cheap though.
Rod
MW17/08/2016 22:27:58
2052 forum posts
56 photos
Posted by Roderick Jenkins on 17/08/2016 22:22:05:
Rod
I would second that my experience of proxxon has been quite positive. I don't own this particular model but have purchased a multi tool drill and a compound table in the past. Build quality was quite exceptional, this looks so similar to the multi tool that i would expect the same experience.
Michael W
peak417/08/2016 22:34:15
2207 forum posts
210 photos
Alternatively, thinking outside the box slightly, you can get carbide tipped blades for oscillating multitools
V8Eng17/08/2016 22:45:46
1826 forum posts
**LINK** I saw these in Machine Mart a couple of months ago.
Edited By V8Eng on 17/08/2016 22:47:28
JasonB18/08/2016 07:37:14
What are you using it for ? Cutting, grinding, flapwheel, sander.
Air tools would be cheapest option if you have air, they do straight and angled ones. Or if the work is not too large and can be taken to the tool and you are not cutting then some of the RoLoc type fittings in a pillar drill work well, I use them quite a bit.
Edited By JasonB on 18/08/2016 07:38:23
Muzzer18/08/2016 09:10:04
2904 forum posts
448 photos
Try looking for a "angle die grinder" such as this, or possibly just a "die grinder" if you don't really need the angle head. They are available as air or electric.
Edited By Muzzer on 18/08/2016 09:12:32
Neil Wyatt18/08/2016 09:50:53
19226 forum posts
749 photos
86 articles
I have a similar model to this, essentailly a 3/4 size angle grinder:
www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=SM20#.V7V2Va1oBxU
It's nothing like a an angle grinder as it runs vastly more smoothly and is a pelasure to use rather than a burden. It is ideal for things like cutting rusted bolts in restricted places.
Bill Mull19/08/2016 02:04:18
33 forum posts
Thanks for all the suggestions,that 2" PCL air operated grinder from machine mart looks really neat and compact.
It might be just what I m looking for.
Neil, the Dremel unit is cool i ll take a look the next time I m at a tool shop.
I ll be mainly using it for cutting in tight spaces, its mainly maintenance/repair work I do so a compact unit would  make the awkward jobs a bit easier.
Neil Wyatt19/08/2016 12:51:05
19226 forum posts
749 photos
86 articles
Posted by Liam Mulcahy on 19/08/2016 02:04:18:
It might be just what I m looking for.Â
That's actually the model I have, they just have given it a slightly different name, but not number. It is cute
Jonathan Mead19/08/2016 21:57:02
30 forum posts
12 photos
Bosch do a 10.8V cordless angle grinder which has a 76mm dia disc. It is quite expensive at around £90 plus a battery.
Neil Wyatt21/08/2016 13:07:18
19226 forum posts
749 photos
86 articles
Posted by Jonathan Mead on 19/08/2016 21:57:02:
Bosch own Dremel, the two products may have a lot in common!
