What did medieval/renaissance lathes look like?
MW02/08/2016 13:39:23
2052 forum posts
56 photos
This is probably a question for both people who know their materials and also those who have an interest in history.
We know that in earlier times, pre-industrial, that lathes did exist and the evidence is in the items made with them, particularly wood and soft stones, maybe even some bronze, copper, silver and gold items too. Ever since you've needed a round wheel or pottery you can almost assume they knew what a lathe could do.
What is thin on the ground though is the evidence for the machines themselves or perhaps even the interest in them. I wonder, such as materials which became relatively common in the industrial age, such as cast iron and fine iron, were once considered uncommon, not because the iron wasn't there but the equipment to work it was rare, due to it's higher melting temperature.
Before lathes could be driven by a watermill or steam plant, the instrument itself was almost considered a two person machine, one to carve and the other to drive. Some mills could be driven by animals so maybe a similar arrangement was made with a beast of burden.
I wonder, in a modern sense, we worry about things such as rigidity of the machine, didn't they atleast eventually, come to the same conclusion, that a good lathe needed a solid rigid base from a material that wasn't uncommon and could be worked, why was stone never considered as a material for a rigid base? (for me at least, it ticks all of those boxes.)
So it took a long time to get there but there are these considerations before the question is immediately dismissed as odd and irrelevant. It could create some interesting discussion!
Michael W
Edited By Michael Walters on 02/08/2016 13:46:44
Mike Poole02/08/2016 13:57:15
3676 forum posts
82 photos
try googling concrete lathe, many machines have been built of concrete. I think medieval machines were mostly wood. have a read of Tools For The Job by LTC Rolt. I found it a good read but it is not universally appreciated.
V8Eng02/08/2016 14:18:22
1826 forum posts
I do not know about specific metal working lathes, there is certainly evidence that the Vikings used Pole Lathes, so it would make sense to me that the device is much older.
On a later note: I think the Science Museum has a "Rose Engine Lathe" from the 18th Century.
Edited By V8Eng on 02/08/2016 14:35:26
Martin Kyte02/08/2016 14:28:52
3445 forum posts
62 photos
Have a look at
Almost certainly the early lathes would have been based on turning between centres with reciprocating motion rather than continuous rotation.
regards Martin
Bob Stevenson02/08/2016 14:29:37
579 forum posts
7 photos
The best guide to early lathes is the 'pole lathe' which is till alive and well an can be seen frequently at country fairs and the like. Essentially, the pole lathe is two thick planks arranged vertically with headstock and tail stock clamped or screwed between these planks at the required positions. The pole lathe was used commercially until very recently for making chair legs and similar items and bears a great resemblance to early prints and drawings of metal working equivalents.
Early metal turning lathes were almost certainly made of wrought iron by the local blacksmiths who made such an important (but often disregarded) contribution to our technical heritage. These lathes (which are in several museums) were also in use until surprisingly recently powered by treadle and flywheel, and followed the 'two plank' outline of the wooden pole lathe. Surprisingly accurate work could be achieved on these early lathes and several 'offshoots' are still in use in various industrial applications such as the use of 'turns' in the bespoke Swiss watch trade.
The concrete lathes mentioned above are very interesting but my understanding is that these were invented for war use and for very large turning operations, and not something that has great provenance or age. Although the Romans had concrete it's really creative uses came into their own during WWII when all kindsof stuff got made including machine tool structure, artillery cradles and boat hulls etc
JohnF02/08/2016 15:03:44
1243 forum posts
202 photos
Hi not "engineering" but interesting for this post I think - a good watch anyway IMO John
I don't recall exactly where but once read an article relating to Watts engine and the cylinder was it said bored by one John Wilkinson Ironmaster and "it did not err more than the thickness of a worn shilling"  now that's precision !
Also as a matter of interest there is a monument to John Wilkinson in Lindale Cumbria he was known as Iron Mad Wilkinson.
Edited By JohnF on 02/08/2016 15:16:58
JA02/08/2016 15:12:12
1605 forum posts
83 photos
Further to Bob's reply the pole lathe is very much in use. My cousin is into green wood carpentry and uses one. The lathe is very simple and I guess that they were the universal lathe in the Middle Ages.
I guess the first machine tool to be developed for large machining was for boring cannon barrels. Before the advent of the eighteenth century boring machine, as developed at Colebrookdale, this must have been a very difficult operation. I assume the cannon was cast with a core in place for the bore which was then bored out to give a fit, a very poor fit, for the wad and cannon ball.
JA
Edited By JA on 02/08/2016 15:13:41
Tim Stevens02/08/2016 15:59:36
1779 forum posts
Regarding stone as a base material, I think it took some time for rigidity to become an important feature. Ready supply and portability were in the favour of wood - and the two planks edgeways on made the headstock and tailstock easy to fit and adjust.
And when Iron Mad Wilkinson (whose memorial is an obelisk of cast iron) built his boring machine he used wood for the bed and framework, although the driving wheel (a water-wheel) was supported in brick or stonework.
Regards, Tim
MW02/08/2016 23:24:04
2052 forum posts
56 photos
Well "my life!" As some might say, it's certainly given me alot to look at, theres something quite enchanting about watching the bow lathe turner work on the king piece in marrakeck, it's so simple yet the results are marvelous, his chisel certainly looked mighty keen though!
The reciprocal motion isn't something i considered, and my entire mindset about lathes revolved entirely around the continuous motion concept, the evidence that Romans had considered this and especially the ever famed leonardo had drawn a treadle lathe is simply startling,
it's pretty much the simplest form of a modern lathe i can imagine, meaning, if i had to make a lathe out of what i could find in my garage, that's what i'd be going for. One larger foot pedaled wheel turning a smaller one mounted on a bench between two centres and a rest.
Having said that, it did note on the history website provided by Martin Kyte that it would turn far too slowly for turning work. In an attempt to justify leonardo's drawing, I would say knowing that he had a penchant for coming up with unique designs (that he could sell to provide a living for himself) i would argue he wouldn't be naive enough to not realize that, he never intended for it to be a simple turning machine.
I once picked up an old victorian book on "ornamental" turning in my town bookshop, the illustrations showed spiralled columns turned from ivory, and it listed an extensive list of devices for accurately creating very fine pitch spirals, it shows how during this age the limits of turning were pushed.
Now, leonardo living several hundred years earlier, would've been in a position to market a special machine designed to turn much slower so that intricate groves could be more closely controlled than a faster turning machine. I could never verify this, but unless he was just using artistic license, i find it hard to imagine he would not realise that an extremely large drive wheel would not turn the machine too slowly for normal usage.
Michael W
pgk pgk03/08/2016 07:27:59
2661 forum posts
294 photos
It's hard to believe that ever since someone came up with the idea of roasting a joint on a spit that the concept of cutting something while turning wasn't about. Whikepedia suggests the archimedean screw may predate the chap by 350 yrs in Assyria and one can guess that even older civilisations had a handle on the concept of turning with the potters wheel...firstly coiling a pot then smoothing it with a powerfed version. So i'd speculate that depending on definitions the first lathes were vertical and about 2-3000 yrs BC??
Bazyle03/08/2016 09:02:22
6956 forum posts
229 photos
Mechanical invention is mostly driven by a need. Early civilisations had water wheels and windmills but had little need to harness the power when slaves were available to turn grindstones. Same with lathes. Who really needs round sticks when you don't even sit on chairs.
We see a lot of round bed Drummonds around from 190x but, outside of museums, would anyone recognise a random lathe from the 19th century appearing on ebay. You do get the occasional garage trader idiot advertising a clearly 1920's model as 'antique 1860' .
Michael Gilligan03/08/2016 09:22:08
23121 forum posts
1360 photos
Posted by Bazyle on 03/08/2016 09:02:22:
Mechanical invention is mostly driven by a need. ...
Interestingly; some of the early lathes were used for the manufacture of decorative items.
http://www.british-history.ac.uk/rchme/york/vol1/pp141-144
Maybe demonstrating a blurring of the distinction between need and desire.
Ian S C03/08/2016 11:11:03
7468 forum posts
230 photos
Stone columns were another thing that were turned in a form of lathe, possibly going back to the ancient Egypt. Often turned, then fluted, so some sort of indexing .
Ian S C
JA03/08/2016 11:16:48
1605 forum posts
83 photos
Posted by Michael Gilligan on 03/08/2016 09:22:08:
I always thought that, 300 or so years ago, the British were practical, go-ahead and industrial so lathes were used to make things people wanted like accurate clocks and later bits for engines and machines. However France lacked an entrepreneurial middle class so French craftsmen used fancy lathes to produce decorative junk for the aristocracy.
JA
MW03/08/2016 11:24:13
2052 forum posts
56 photos
Yes, if you look at alot of the ancient monuments, and think of the inventions needed to make them also, Then you pretty much drive a coach and horses through the idea of "biological needs" being the primary driver of invention, clearly the pyramids in giza were never needed as such but the egyptians went to great lengths to design pyramids and tombs for themselves.
This kind of creativity can be witnessed in every society of people no matter how old. Even (and i don't say this in a derogatory sense because there isn't alot of proof they were dumb) the neanderthals had their own culture, due to interbreeding this has made their extinction causes unclear.
It is probably impossible to put a date on when people began being creative and develop culture because it seems to be inherent in our nature. Most skeletons haven't been found any older than around 200,000 years, but i suspect we will find older ones yet. The geological impact on the state of the remains can render them unrecognizable.
Michael G made a rather good point about the distinction between need and want (the separation of the two in the popular mindset was probably caused by the early labour party with their "social ills" campaign and perhaps even earlier with the christian concept of greed and gluttony) It's quite clear that we can create the need or desire for absolutely anything we wish and our bodies will adapt to that.
I have said before that i wager that the most interesting digs and discoveries are to be made right beneath our feet, the problem is we're still using the ground above! But if it's a good place to live today, it probably was a long time ago too.
Michael W
Ed Duffner03/08/2016 12:32:33
863 forum posts
104 photos
Here's a little light bedtime reading about lathes. With reference to an early tree lathe in chapter 1.
Ed.
