Clive Haynes | 27/05/2016 15:05:01 |
![]() 57 forum posts 9 photos | Hi, does anyone know a way to thin neatcut? I have two warco machines with coolant pumps and althought being told at the time of purchase that these will work with neatcut, they don't and I do not want to use suds.The only other way I suppose is to buy pumps for the job. Clive |
Roderick Jenkins | 27/05/2016 17:31:13 |
![]() 2376 forum posts 800 photos | I dilute neatcut 50/50 with paraffin. Don't know if that is thin enough for a pump, I only use a squeezy bottle. HTH, Rod |
Clive Hartland | 27/05/2016 17:34:42 |
![]() 2929 forum posts 41 photos | Maybe you need to prime the pumps? Clive |
Clive Haynes | 27/05/2016 17:45:58 |
![]() 57 forum posts 9 photos | My workshop is in a room off the house and I was concerned about using paraffin as a dilutant because of the smell. The lathe runs at a trickle which is okayish but the mill has never worked at all, perhaps that needs priming. Do you just pour fluid down the outlet nozzle? Clive |
John P | 27/05/2016 21:04:48 |
451 forum posts 268 photos |
Hi Clive Assuming that the system is clean and there are no blockages the I use 15 mm copper pipe and soldered fittings for all of the plumbing Looking at the photo of the Warco pump the outlet fitting is really too small Seen here in the album Workshop and machines this photo the outlet is
Nick_G | 27/05/2016 21:24:49 |
![]() 1808 forum posts 744 photos | . What is wrong with using 'suds'.? Although I seem to recall that Warco did not advocate the use on their machines for some reason, only neat oil. No idea if they still have that policy. I find that if a good quality soluble is used the water evaporates away and leaves a nice thin film of protective oil on the machine.
Nick |
Clive Haynes | 27/05/2016 22:39:10 |
![]() 57 forum posts 9 photos | Hi John, many thanks for your informative reply. Both machines are about one year old,the lathe is GH1236 with the coolant pump housed in the cabinet stand under the tail stock which I assume is the same as Warco sell as a stand alone unit. The mill however is a HV model and has the coolant tank in the base with the pump bolted to the top of the base casting. I have filled the tank with the recommend quantity of neat cut but have never had anything out of the nozzle. I must add that the motor runs okay. Hi Nick, Warco or should I say Roger assured me that neat cut will work but was hesitant as these units were designed for suds. When I was an apprentice there was no choice as far as I am aware and I just recall how suds aged and sometimes smelt which was a nasty job for the toolroom labourers to clean. Clive .
Edited By Clive Haynes on 27/05/2016 22:50:12 Edited By Clive Haynes on 27/05/2016 22:51:42 |
Clive Foster | 27/05/2016 23:30:02 |
3630 forum posts 128 photos | Look into synthetics. I use Rocol Ultracut at 30 - 40 to 1 dilution. Expensive stuff but at that dilution the gallon bottle goes a long way. On current rate of consumption expecting something approaching 20 years per gallon doesn't look terribly unreasonable. Like most home shop folks coolant or mist only gets used when essential. I expect to get approaching 20 years out of mine. Niffs much, much less than suds and doesn't go bad. Clive. |
John P | 27/05/2016 23:41:25 |
Hi Clive John |
Neil Lickfold | 28/05/2016 06:10:02 |
1025 forum posts 204 photos | Clive, the best and longest lasting machines I have worked on, never used soluble oil on the machines.They used straight cutting oils, that were thin like a honing oil. The machines that used soluble oils had wear in them as to the almost new condition of the cutting oil machines. I'm a convert of using oils and not water based coolants now . Neil |
JasonB | 28/05/2016 07:28:10 |
![]() 25215 forum posts 3105 photos 1 articles | Which Neatcut are you using, they do several different viscosities, maybe you have a thick one. |
David Colwill | 28/05/2016 08:34:14 |
782 forum posts 40 photos | Castrol Alusol A is a semi synthetic soluble oil. It used to be called Hysol excel. It doesn't smell and seems to be good for most applications. PM me and I will send you a sample. Regards. David.
Nick_G | 28/05/2016 09:38:12 |
![]() 1808 forum posts 744 photos | . I like using soluble oil from the pump whenever possible. But I also use neat oil quite a bit. The problem I have with soluble is not the smell, but no matter how careful I am I seem to get more splattered upon me than I do on the intended work and cutting tool.
Nick |
Raymond Anderson | 28/05/2016 09:56:37 |
![]() 785 forum posts 152 photos | David, Me being a "Castrol fan" Have used many of the Castrol range, all excellent. I now stick to Castrol HYSOL XF, superb with my soft Scottish water. I have never had any Castrol cutting fluid go "bad " For anyone that has had that Monday morning smell from their coolant, get the tablets that you drop into the tank,, nice mint smell, although I have never needed to use them. Cheers. |
ROBERT BLACKSHAW | 28/05/2016 10:02:01 |
46 forum posts 13 photos | Neatcut 50/50 with paraffin will it reduce the smell and ok on aluminium to stop build up on the tool. Use to use spit years ago when countersinking aluminium on a few holes, better than paraffin. |
Andrew Johnston | 28/05/2016 10:59:55 |
![]() 7061 forum posts 719 photos | Posted by Raymond Anderson on 28/05/2016 09:56:37:
David, Me being a "Castrol fan" Have used many of the Castrol range, all excellent. I now stick to Castrol HYSOL XF, superb with my soft Scottish water. I have never had any Castrol cutting fluid go "bad " I rarely use coolant, as I mostly machine with carbide. However, I do use it for HSS tooling (repetition lathe and horizontal mill), grinding and for CNC milling to wash away the swarf. In the past I used Biokool14 from Hallett Oils, but as that got more difficult to obtain I switched to Hysol XF, as above. I'm in a very hard water area, and if I remember correctly Hysol XF copes with that. My coolant sits in the tanks for months, and years, and I have never had a problem with bad smells. All I do is top up with water on a regular basis and check the concentration with a refractometer every now and again. Soluble oils going off may have been a problem in the past, but it isn't an issue with modern coolants. Andrew |
Clive Haynes | 28/05/2016 12:32:56 |
![]() 57 forum posts 9 photos | Hi Jason, The neatcut that I'm using is from warco but I don't know the viscosity as there is no info on the can. I was hoping to be able to find a lower viscosity. I have looked at the neat oil coolant system on the warco site and it is £160, out of stock and I only want the pump, a heavy soil submersible pump would probably work and they are only £40+. There are no kinks or restrictions in any of the pipes but I will try with the nozzle removed. Many thanks everyone. Clive |
Raymond Anderson | 28/05/2016 13:06:06 |
![]() 785 forum posts 152 photos | Hi Andrew, ANY Castrol product is top notch. I too have never had any Castrol oil go "off" All me gear boxes filled with Castrol, slideways lubricated with Castrol Magnglide and of course the Hysol XF for cutting. At one time a lot of the soluble coolants didnt like soft water [used to foam like hell ] unless you put in an additive. Better formulations now. |
John P | 28/05/2016 21:55:32 |
Hi Clive |
mike T | 28/05/2016 22:34:09 |
221 forum posts 1 photos | Everyone seems to agree that Castrol Hysol XF is the way to go. I can find it for sale in huge commercial quantities, but where can you buy it in sensible small quantities of a litre or two? Mike |
