rope knurling tool
Michael Garbutt 126/03/2016 20:45:13
51 forum posts
Hi im looking for a rope knurling tool. Can you buy such a tool ?
Paul Mawson26/03/2016 21:34:19
4 forum posts
Have a look on Clicksprings web site for videos.
Michael Garbutt 126/03/2016 21:49:15
51 forum posts
yes that looks to be my only option at the moment. not sure on making the tool though. looks alot of work
Vic27/03/2016 13:20:44
3453 forum posts
23 photos
I have seen them for sale somewhere but they weren't cheap. Lots of stuff on the net about making your own from silver steel suitably hardened and tempered. I think one tutorial I saw used a single point cutter so maybe not too much of a chore to make? Good luck whatever you do.
Vic27/03/2016 13:33:44
3453 forum posts
23 photos
Just found this if it helps. It talks about using a thread tap as a cutting tool.
JasonB27/03/2016 13:47:08
Similar to clicksprings here from an old post on the forum
Ed Duffner27/03/2016 16:35:03
863 forum posts
104 photos
Hi Michael,
What sort of size and geometry were you thinking of? ...and is it for mounting in a lathe, mill or a hand tool as shown in Vic's link? Or do you just require the knurl to mount in an existing tool?
Ed.
Michael Garbutt 127/03/2016 20:35:33
51 forum posts
Not really sure. i just like the look of them and thought i could make some nice thumb screws on the lathe
Michael Garbutt 127/03/2016 20:42:37
51 forum posts
Thought i could use one of these to make one. What do you think
https://www.cousinsuk.com/product/bearing-cutter-90-af-119257?code=119257010#select
Ed Duffner27/03/2016 20:58:38
863 forum posts
104 photos
Somebody with more experience than myself could probably say for sure but I think those are for cutting angular faces.
Knurls are usually formed by pushing the tool into the workpiece as opposed to cutting, although there are cutting type knurls for diamond patterns I believe.
Michael Garbutt 127/03/2016 21:28:23
51 forum posts
Sorry i was referring to using it to make the knuring wheel. As in the click spring video
steamdave27/03/2016 23:30:20
526 forum posts
45 photos
Yet another source of ways to make a rope knurl is on Frank Ford's site
http://www.frets.com/HomeShopTech/Projects/RopeKnurl/ropeknurl.html
Lots of other interesting things there as well.
The Emerald Isle
Circlip28/03/2016 10:05:25
1723 forum posts
Hmm. Seems that Frank Ford is another that advocates using the kitchen oven for tempering. Two of us obviously getting it wrong.
Regards Ian.
Michael Garbutt 128/03/2016 12:30:40
51 forum posts
Ok looks like im gonna be making my own tool to make one. All i need now is an indexer oh and a milling machine.
where did i put that credit card
Tim Stevens28/03/2016 15:42:32
1779 forum posts
The Cousins cutter you linked is intended for cutting the minute 'shelf' that a precious stone sits on in its setting. That is why they list a wide range of sizes, as they need to be the right size for the stone. You could use on as a milling cutter to cut your angled grooves, but the cutter may not last very long, as they are made to cut silver, gold, and platinum. None of these is remotely as hard as tool steel even when it is soft. And I'm sure that any guarantee claim would be thrown out as that is not the purpose of the tool. Sorry.
Regards, Tim
Michael Garbutt 129/03/2016 20:36:34
51 forum posts
I would only expect it to last the time of cutting the knurling wheel. So i guess its a case of suck it and see. if not ill have a go at making the tool to make the wheel as well. first time for everything
speelwerk30/03/2016 00:26:57
464 forum posts
I think this is http://www.zeus-tooling.de/en/products/knurling-wheels/special-knurling-wheels.html what you are looking for, no doubt it will be expensive. Niko.
Edited By speelwerk on 30/03/2016 00:35:07
Edited By speelwerk on 30/03/2016 00:35:20
Alan Wood 406/09/2016 10:41:45
257 forum posts
14 photos
Hi Michael
A bit late but found your forum note on rope knurls.
AccuTrak in the States make them and their UK agent is
ATM Machine Tools
Unit 4 Molly Millar's Bridge, Wokingham RG41 2WY
+44(0)118 977 0099
They are very expensive ~ GBP200 each.
I have been making various 'old style' Morse keys and have used the knurl on the screws.
I made a knurl using ClickSpring's video and it worked but it was not fine enough for instrument type terminals.
Kind regards
Alan
Martin Kyte06/09/2016 11:15:59
3445 forum posts
62 photos
When I made my synchronome (well it's nearly finished) I made a knurl by free hobbing a silver steel disc with a (4BA?) tap. The tap was held in the lathe chuck and the end supported in a female centre. The subsequent screw heads did look nice if I say so myself. It's easier than you would think and in brass with small fine knurl you only need the one wheel.
regards Martin
Ian S C07/09/2016 14:04:28
7468 forum posts
230 photos
There was something about making one using a tap as a hob in either ME, or MEW.
Ian S C
