DC motor + speed controller
MW08/03/2016 12:05:38
2052 forum posts
56 photos
Hi,
I'm interested in making a DC motorized control for my lathe lead screw and i know there are lots of designs out there but i dont really know where to start with regards to where to buy a DC motor and what size/speed would be appropriate to drive a handle?
Michael W
John Rudd08/03/2016 12:15:29
1479 forum posts
Ex- car wiper motor and the speed controller featured in MEW?
Michael Cox 108/03/2016 12:18:37
555 forum posts
27 photos
If you put 12 volt dc motor into ebay you will get many hits. Most of the 35 mm diameter motors will have sufficient power to drive the leadscrew of a small minilathe. I have fitted a motorised leadscrew to my lathe, see:
http://mikesworkshop.weebly.com/leadscrew-motor.html
http://mikesworkshop.weebly.com/new-threading-banjo.html
http://mikesworkshop.weebly.com/control-circuits.html
Les Jones 108/03/2016 12:27:41
2292 forum posts
159 photos
I would suggest starting by measuring the maximum torque required to turn the leadscrew at the tightest point in the travel.(Use a spring balance and string wrapped round the handwheel.) I would then choose a motor rated with at least twice that torque rating. You also need to decide what the maximum speed is that you want to turn the leadscrew. When you have found a suitable motor you can start designing the drive electronic to match the motor voltage and current rating. You will also then need to decide how well you want the speed controlled. If you do not require accurate speed control the just a PWM controller will do. If you want accurate speed control you will need a closed loop system with some form of tacho generator or encoder for feedback.
Les.
MW08/03/2016 13:22:41
2052 forum posts
56 photos
Hi everyone, i'll try to address everyone.
Hi john, Yes i do have that article in the well thumbed issue somewhere, I'm sure alot of these designs require a proper PCB board, i dont have the time/equipment/knowledge to make one of these, so i'd either have to get someone else to make it or use breadboards/wires to link up all the components.
Thanks for the Reply mike, i think i'll try the 35mm spindle size then, as in my mind, for a task this small i dont have any concept of power or appropriate speeds so i just needed a starting point or rough guide. I keep looking at your website and i can really tell you have a background in electronics because of how well you've integrated the whole system. I will keep reading it for hints, thankyou.
Les, i was thinking along the route of using pulleys/timing belt with a tensioning idler spindle, a bit more common and easier than an encoder to do. I lost my spring balance a long time ago!
Thankyou,
Michael W
John Haine08/03/2016 13:40:02
5563 forum posts
322 photos
Maplin sell a speed controller...
Not worth building one at this price.
Tim Stevens08/03/2016 14:38:07
1779 forum posts
Rather than measuring the torque required and using that (doubled) to choose a motor, I suggest you look at a reduction by belt drive. This can be round or toothed, and it will allow you to select a motor which has less torque and more speed (ie most motors) than you actually need. A five times speed reduction will give you five times the motor torque, and one fifth of the speed. The drive etc needs to have a fail-safe built in, perhaps relying on a round belt will do, to avoid any possibility of driving the saddle through the headstock. Microswitches are helpful here, and perhaps a fuse to blow just below the stalled current to avoid burn out.
I have done this on the leadscrew (effectively) of a mill, and if you need details of motor etc I will pull it down off the shelf and peer at it for you. Just say.
Regards, tim
Neil Wyatt08/03/2016 14:41:14
19226 forum posts
749 photos
86 articles
If you want to consider a stepper drive one that will allow you to do things like threading with it, wait for the next MEW which will have an article that goes through installation of a kit-build system in detail.
Bob Brown 108/03/2016 14:58:25
1022 forum posts
127 photos
This is what I did on my milling machine using a BLDC geared motor
Bob
john fletcher 108/03/2016 16:17:57
893 forum posts
I bought a DC motor speed controller it easily controls a 300 watt motor from PRC via ebay for £9.30. I couldn't buy the components for that price. I carefully removed the speed potentiometer, bought a new one and was able to mount it remote. Work well, with 6 mosfets and heat sink, pulse width modulation circuit. No feed back of course all in a smart box. John
MW09/03/2016 16:01:31
2052 forum posts
56 photos
I just bought a mish-mash of components on ebay-
Motor 12v 38mm
12v Speed controller curcuit.
2amp 12v DC plug
x2 Pulleys
x2 Belts (same tooth pitch as pulley)
And finally x1 STDP switch (12v)
The fittings for installation can all be made to fit by me, so if you've taken the time to browse through that myriad, thanks and do you think that'll cut it? I always apprieciate the honesty of this forum so your opinion will count, I can always make changes to this list because its all on china post and it'll take forever anyway, there will be plenty of time to change my mind if needed.
Michael W
Ajohnw09/03/2016 16:21:34
3631 forum posts
160 photos
You need to work out what rev range you need. Think in terms of thou's per rev. I just did that for a table feed on my miller. Ideally I need a range from 2.5 to 80rpm acounting for the speeds the cutter will run at. There is a point between the 2 and the 5. Rather wide without a gearbox. This means that a stepper might be a better option. One with a gear head to get the torque up.
John Haine09/03/2016 17:02:39
5563 forum posts
322 photos
One way to think about it is that a lathe normally has only one or two power feed speeds, so perhaps you don't need the range that you'd like on a mill. Perhaps start with the normal max speed on the lathe auto-act, bear in mind that the slowest one is too fast for some things, so go from perhaps 1/3 of the slowest to 2x the fastest, and you should have something a lot more versatile than the mechanical feed.
That speed controller only gives a 10:1 range of PWM ratios so may be a bit limited depending on the above calculation.
The motor looks a bit tiddley to me, I'd go for something beefier. Also I think 2A is light for the PSU - just been reading Mike Stratton's article on power drawbar in the latest MEW, he got a 25 amp 12 V PSU for £17 off eBay. It's always useful to have lots of amps round the workshop.
Final point, some speed controllers don't like having their outputs open circuited when you throw a reversing switch when the motor is running, a centre-off switch might be useful so the motor can stop before the reverse volts are applied.
Edited By John Haine on 09/03/2016 17:23:24
MW09/03/2016 17:54:33
2052 forum posts
56 photos
I need it to be slow enough to get a good finish but also fast enough to move about with ease. The main bonus of it is the ability to get a nice consistent turned finish which is the hallmark of any precision cylinders.
The motor is fairly small, i would say roughly hand sized motor, which is just enough. The idea of me playing around with any sort of power above a 13A socket makes my spine tingle a bit. If i deemed it truly necessary, i wouldnt want to do that without a qualified electrician present. I deliberately sized my own machine motors to fit within 13A for that very reason.
I don't plan on reversing it, although that may seem a bit lame, i don't know how i would switch the tracks to make it reverse to be honest.
Michael W
Ajohnw09/03/2016 18:12:55
3631 forum posts
160 photos
The 2 normal feeds on the lathe always relate to speed John - that's the catch. They are per rev what ever the speed the lathe is running at.
It's a natural for a geared down stepper really as the revs are so slow angel 2 but I really don't fancy writing any software and if some one did it would probably have a display and scrolling buttons etc.
Tony Pratt 125/05/2019 16:43:28
2319 forum posts
13 photos
Posted by Neil Wyatt on 08/03/2016 14:41:14:
Hi,
I can't locate the article that Neil mentions above, can someone please point me in the right direction?
Thanks,
Tony
clivel25/05/2019 17:50:11
344 forum posts
17 photos
Posted by Tony Pratt 1 on 25/05/2019 16:43:28:Hi,
Thanks,
Tony
I think the article he is referring to is in MEW #240, April 2016. Building an electronic leadscrew - Chris Gabel converts his lathe using the electronics kit from Automation Artisans.
Tony Pratt 125/05/2019 17:52:14
2319 forum posts
13 photos
Thanks Clive I will investigate!
Tony
Andy Carruthers25/05/2019 20:13:48
317 forum posts
23 photos
Check out YouTube - Clough42 - developing an electronic lead screw
