Ceramics in the Workshop
Neil Wyatt02/03/2016 11:16:37
19226 forum posts
749 photos
86 articles
No I don't mean a Grayson Perry teapot, but is there anyone who could write about things like making spark plug insulators etc.?
duncan webster02/03/2016 12:59:50
5307 forum posts
83 photos
RS usec to sell it, quite expensive, and that's as much as I know!
Neil Wyatt02/03/2016 13:39:40
19226 forum posts
749 photos
86 articles
Looks excellent stuff, but has anyone got experience of using it - or similar?
Richard Marks02/03/2016 13:57:20
218 forum posts
8 photos
Used a hollow ceramic wirewound resistor core to repair a miniature spark plug, cut using diamond discs in a dremel and shaped using diamond bits,worked well.
Roderick Jenkins02/03/2016 13:58:27
2376 forum posts
800 photos
Posted by Neil Wyatt on 02/03/2016 13:39:40:
Not me - too expensive sad
Rod
Baz02/03/2016 13:59:09
1033 forum posts
Recently made some spark plugs for a small I/C engine, Rudy Kouhoupts Pioneer, I used 1Amp fuses as the insulators, yanked the metal bits off the ends and stuck the whole lot together with high temp Loctite. So far the engine has had over one hours running and plug is still as new. Could also use JB Weld to stick them together. Only problem with using the fuses is the writing on the ceramic but a few seconds in the grit blaster gets it off.
John Haine02/03/2016 15:17:55
5563 forum posts
322 photos
I've never used it, but my father used to work in the high voltage lab of Metropolitan Vickers before WW2, and apparently they used soapstone to make insulators.
As its name implies this has a soft consistency like soap so it can be carved and turned, but when fired at ~1100 C it turns into a hard ceramic. So useful for making small numbers of insulators. I see from that link that it contains talc which has recently been implicated in cancers, so be cautious about the dust. Isee you can buy the stuff at Homecrafts, 9mm thick, might be possible to stick it together for larger thicknesses, or other suppliers, it's quite cheap.
Keith Long02/03/2016 15:40:39
883 forum posts
11 photos
On the face of it, the prices for Macor here seem a lot more user friendly.
John Fielding02/03/2016 16:11:51
235 forum posts
15 photos
The material you are thinking about is known as Steatite. It is a moldable ceramic which is then fired at high temperature.
Roderick Jenkins02/03/2016 16:19:51
2376 forum posts
800 photos
I'm not sure if Soapstone can be fired to give a hard ceramic but Pyrophyllite certainly can - we used to use it for trays for passing thick film circuits on alumina substrates through a belt furnace. In the raw state it is very similar to soapstone.
Rod
pgk pgk02/03/2016 16:20:03
2661 forum posts
294 photos
I have no idea about their electrical insulating properties but chemical setting dental glass ionomer filling material might be a consideration.. or even the light-set stuff in small quantities. Whilst that is usually set with a fancy light tool I have set it in emergency (tool got dropped) just using a very bright lightbulb (through a fibre guide on that occasion).
KWIL02/03/2016 16:54:27
3681 forum posts
70 photos
Many years ago, in a previous existance, used pyrophillite to make specialised rotary type switches, (high temperature safety swtich), great stuff.
duncan webster02/03/2016 17:47:15
5307 forum posts
83 photos
If you dig deeply enough into back issues of ME I'm sure there was an article about using PTFE insulators in small spark plugs. Wouldn't have been my first choice as I would have thought the face exposed to the combustion side would char and then conduct, but it must have worked for the author
Neil Wyatt02/03/2016 18:02:41
19226 forum posts
749 photos
86 articles
Need to be clear, although the suggestions are interesting - I am looking for someone with experience of using ceramics in a home workshop situation to write me a short article sharing their experiences.
JA02/03/2016 19:14:14
1605 forum posts
83 photos
I have made a couple of spark plugs following a Graham Meek's design using small fish spine insulators. In the open the plugs seem to work satisfactorily but I have not used them in anger yet.
You can buy fish spine insulators by the hundred from RS for not very much. They are a standard insulator for high temperature wiring.
JA
John Haine02/03/2016 20:41:28
5563 forum posts
322 photos
Posted by John Fielding on 02/03/2016 16:11:51:
<sigh>... Yes, I read the Wikipedia article too. Not mouldable but carvable.
Ian S C03/03/2016 10:07:13
7468 forum posts
230 photos
There was an article in ME about using Fish Spine insulators along with the little bit of glass tube that you can find inside an incandescent light bulb. I have seen something, somewhere about using Araldite to make insulators for spark plugs.
Ian S C
Ady103/03/2016 10:45:28
6137 forum posts
893 photos
The late great Dan Calkin got Champion to knock his own design up because insulators were such a pain to make, (his own father was a Dentist with a knowledge of ceramics as well)
Modern materials may make the task easier nowadays, but it has always been a challenge, even for the highly skilled
Once commercially produced ones became available in the late 1930s he always used them
It's the sort of area which 3D printing could make a lot easier
Edited By Ady1 on 03/03/2016 10:52:47
