Ian L2 | 21/02/2016 00:21:58 |
106 forum posts 11 photos | Ok i have a 600w Bosch palm router but its fixed speed, I would like to add something to get variable speed from it, have heard in past that light dimmer switch do job but will it cope with 600W. any other ideas to get variable speed welcome. also soft start would be useful. |
Malcolm Parker-Lisberg | 21/02/2016 02:02:17 |
22 forum posts 8 photos | The low cost dimmers from Hong Kong can hadle 2KW, cost about £1.18, I have a simple modification which adds a little piggy back board to give feedback. It senses the back EMF generated and uses that to compensate for the speed drop under load. .R5, R6, R7 D1, D2 and C3 are the components that are added to the module. The module connections are changed and what was the input becomes the output and vise versa. I will be adding a Youtube video of the process later this week. |
Ian L2 | 21/02/2016 08:17:56 |
106 forum posts 11 photos | Thanks Malcom
If you have some component details & values ect. Did you make your on p.c to mount the components to if you did is the layout something that you could send.
Ian S C | 21/02/2016 09:12:44 |
![]() 7468 forum posts 230 photos | By the dots it looks like a Vero Board job. Ian S C |
Michael Gilligan | 21/02/2016 09:32:45 |
![]() 23121 forum posts 1360 photos | Posted by Malcolm Parker-Lisberg on 21/02/2016 02:02:17:
The low cost dimmers from Hong Kong can hadle 2KW, cost about £1.18, I have a simple modification which adds a little piggy back board to give feedback. It senses the back EMF generated and uses that to compensate for the speed drop under load. .R5, R6, R7 D1, D2 and C3 are the components that are added to the module. The module connections are changed and what was the input becomes the output and vise versa. I will be adding a Youtube video of the process later this week. . Thanks Malcolm That would be a very useful upgrade !! MichaelG. |
John Rudd | 21/02/2016 09:49:12 |
1479 forum posts 1 photos |
Posted by Ian S C on 21/02/2016 09:12:44: By the dots it looks like a Vero Board job. Ian S C It could just be a schematic capture program...... In my opinion, Vero board would be inappropriate for a Mains Powered project.....especially not knowing the op' capabilities.... Ian, I'd recommend you look at this as a kit..... https://www.esr.co.uk/products/frame_motor-control.htm It takes all the guess work out of designing/building/modifying, especially if you are a beginner... Just my 2c worth.... Edited By John Rudd on 21/02/2016 09:53:26 |
john fletcher 1 | 21/02/2016 10:56:32 |
893 forum posts | Hello Malcolm, what the resistor and capacitor values. I'll look out for your YouTube video. John |
Malcolm Parker-Lisberg | 21/02/2016 12:28:34 |
22 forum posts 8 photos | Give me chance to do the Youtube video, all will be revealed. ICircuit was a screen grab, dots are the layout grid. R5 & R6 100K, R7 15K, C3 10nF to 47nF dependent on motor characteristics. D1 & D2 1N4007. All other components as supplied on the dimmer. A toner transfer PCB holds the components for the piggy back board with four leads between the boards. I will post a image here of the PCB layout, see below The ESR board is no better than the Hong Kong dimmers, as it does not have load compensating feedback. Your are playing with leathal voltages, so be safe. Best to do test work with one of those Garden mower type ELCB modules that are designed to shut off the power when you mow the power lead.
Steambuff | 21/02/2016 12:32:36 |
![]() 544 forum posts 8 photos | <Quote> The low cost dimmers from Hong Kong can handle 2KW, cost about £1.18, I have a simple modification which adds a little piggy back board to give feedback. <Quote> Can you post a link to the 'Hong Kong' Dimmer that you based your design on? Dave |
Rik Shaw | 21/02/2016 12:48:42 |
![]() 1494 forum posts 403 photos | My Alba 1A shaper when manufactured was fitted with a 950 rpm motor. Sometime in its life someone has fitted a replacement that runs faster - 1500rpm if I remember correctly. This means that the shaper runs a mite to fast even with the two speed gear change set on "slow". I have been told several times on here in the past that slowing this 230v AC single phase motor was not possible yet John Rudd posts on this thread and links to this: https://www.esr.co.uk/products/frame_motor-control.htm Is it possible that the model R-10 will do the trick for me and slow my shaper? Have I finally discovered the holy grail?
Rik Edited By Rik Shaw on 21/02/2016 12:49:02 |
Les Jones 1 | 21/02/2016 12:55:41 |
2292 forum posts 159 photos | Hi Rik, Les. |
Malcolm Parker-Lisberg | 21/02/2016 13:01:18 |
22 forum posts 8 photos | John Forn the module I am using, search for item number 221904245698 on ebay. It says 4KW, but the heat sink is not big enough for that power. The traic is though, so for larger powers you could change the heatsink.
Malcolm |
John Rudd | 21/02/2016 13:11:54 |
1479 forum posts 1 photos | Posted by Malcolm Parker-Lisberg on 21/02/2016 12:28:34:
Maybe so, but I made no claim that it was better.....merely pointing out that for a beginner, it may be more suitable to build rather than modifying an existing design....
Malcolm Parker-Lisberg | 21/02/2016 13:16:53 |
22 forum posts 8 photos | Why pay over £10 when you can get the same functionality for £1.18 Malcolm |
Rik Shaw | 21/02/2016 13:53:47 |
![]() 1494 forum posts 403 photos | Thanks Les - I never believed in the holy grail anyway |
Ian L2 | 21/02/2016 19:44:22 |
106 forum posts 11 photos | Thanks Malcolm. Controller ordered (in fact ordered 2) |
John Rudd | 21/02/2016 21:18:46 |
1479 forum posts 1 photos | Posted by Rik Shaw on 21/02/2016 12:48:42:
Rik Edited By Rik Shaw on 21/02/2016 12:49:02 The item I linked to was in response to Ian's request for a method of speed control for his router whch I believed to be of the universal motor powered type.... In no way did I indicate that it may be suitable for Rik's use.. |
oldvelo | 21/02/2016 21:46:24 |
297 forum posts 56 photos | Hi IF this is a Universal Motor I.E Brushes and Commutator the it will run on a AC to DC speed Controller. Expensive yes and needs to setup to match the motor.
Eric |
Rik Shaw | 21/02/2016 21:48:33 |
![]() 1494 forum posts 403 photos | John - Not to worry, if confusion has arisen it is due to my lack of knowledge in matters electrical - not your fault at all. Your ongoing advice on here re: electricals is much appreciated by me and others I am sure. Rik |
Michael Cox 1 | 10/03/2016 20:11:18 |
555 forum posts 27 photos | Posted by Malcolm Parker-Lisberg on 21/02/2016 02:02:17:
Hi Malcolm, Has there been any progress with the video. I keep watching your youtube channel but nothing seems to have been added. Mike |
