Neil Wyatt | 06/02/2016 14:17:19 |
![]() 19226 forum posts 749 photos 86 articles | These little modules off ebay cost about £4, combined with a couple of totem-poled battery-charger transformers they look a great way to bodge a high-current bench PSU.
Naturally I can work out how to get the indicator and current/voltage sense voltage connections onto a panel But does anyone know anything about the RS232 connections? I can't find a datasheet anywhere. |
Muzzer | 06/02/2016 14:41:54 |
![]() 2904 forum posts 448 photos | The other side of the module seems to have a 2-wire connection to the battery - is this a proprietary format for talking to the BMS in some lithium packs? Almost certainly serial if it is - and possibly gets passed through the module to the other port. Might be worth looking at lithium BMS datasheets? Don't see any mention of RS232 in that page - do the other ads specify it thus? At that price, perhaps the easiest way to find out is to buy one. |
Geoff Theasby | 06/02/2016 14:44:46 |
615 forum posts 21 photos | Neil, TinyuRL, http://tinyurl.com/zbrfb9q Or see: The Art of Electronics, 2nd Ed. Horowitz & Hill, page 724 Geoff |
Muzzer | 06/02/2016 14:58:55 |
![]() 2904 forum posts 448 photos | Neil - are you asking how RS232 works or are you wondering about the format of the control data you need to send to this thing? I rather suspect the latter. I expect the format is semi-proprietary but isn't going to be a well-guarded secret. The vendors might tell you (in Chinglish!) if you ask. Dunno if you can find any trace of these devices publicly but these are what you find when you rip open a Lenovo L-Ion pack. |
Neil Wyatt | 06/02/2016 15:35:38 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Muzzer on 06/02/2016 14:58:55:
Neil - are you asking how RS232 works or are you wondering about the format of the control data you need to send to this thing? I rather suspect the latter. Definitely the latter. Past experience shows it can take several hours of trial and error to establish communication with a device with unexpected baud rates or parity. These sorts of things usually use 0/5V signals but RS232 protocols as it makes 2-way communication with uPs very easy. The display board has only four connections to the actual power board, the four brass columns which are each Vin +, Vin-, Vout -, vout+. I see the power board has a fat R050 current sense resistor between in- and out- so... this obviously isn't a control function, I suspect it just reports current and voltage. |
Ajohnw | 06/02/2016 15:37:33 |
3631 forum posts 160 photos | If you ask the seller they will probably link you to a data sheet. I'm loosely reminded of emailing a chinese seller after buying a part of him. He miss understood and replied sorry we will get it right next time we makes some. If you google the entire listing title a number of links come up. Some are video's. Might be some info there. John - |
SillyOldDuffer | 06/02/2016 18:22:34 |
10668 forum posts 2415 photos | As they are so cheap it might be worth buying one in the hope that the underlying chip is marked and its datasheet can be looked up. The functions available through the interface may be more comprehensive than you expect. For example, this TI chip uses an IC2 serial interface to adjust lots of parameters so that the charger can be optimised for particular batteries. Please let us know how you get on. It looks like an interesting module. Cheers, Dave |
Ian P | 06/02/2016 20:35:30 |
![]() 2747 forum posts 123 photos | I think the only way you get any detailed info is to reverse engineer the schematic. I have used quite a few modules similar to the one you show. The descriptions often have errors and you dont know what you get until it arrives! On this one it mentions non synchronous rectification but nowhere does it say AC input or what AC frequency. Not relevant to your bench PSU purpose but some people have assumed that the CV/CC modes meant that it can be used to charge Lithium type batteries, they can do, but they are not really optimised. The modules I use are mostly DC:DC buck or buck-boost. 10A versions are not much more expensive, some have meters but if not there are plenty of cheap digital V and A modules and since they are not on the regulator board are easier to put where you want on your front panel. By totem poled do you mean transformer secondaries in series? also what current do you consider high for a bench PSU? Ian P |
Ian P | 06/02/2016 20:37:39 |
![]() 2747 forum posts 123 photos | Forgot to say, module circuit diagram can often be found by looking at the chip makes application notes, they are usually slavishly followed. Ian P |
Ian P | 06/02/2016 20:37:40 |
![]() 2747 forum posts 123 photos | Duplicate post removed Edited By Ian Phillips on 06/02/2016 20:38:15 |
Paul Lousick | 06/02/2016 22:57:08 |
2276 forum posts 801 photos | This f-bay advertisement has some information about their modules Paul http://www.ebay.com.au/itm/5A-CC-CV-Adjustable-Power-Step-down-Charge-Module-LED-Driver-W-USB-Voltmeter-EB-/261540641867?hash=item3ce5097c4b:g:gokAAOSwDk5TzyJi |
Neil Wyatt | 07/02/2016 10:56:41 |
![]() 19226 forum posts 749 photos 86 articles | A nice low-stress task.... only 4 screws + google required Its a simple DC/DC chopper. A 1-chip converter (XL4005), plus a couple of big Cs, a hefty shottky diode and an inductor. An LM358 works the pretty lights on the bottom and takes care of the voltage/current limiting, I assume.. For my purposes, anything over an amp is 'high current'; 4A will be plenty for anything I'm planning. The display board is effectively separate, just neatly designed so four brass stand offs make the connections. Easily replaced with wire, if required. Another LM358. LS164 is a shift register - used for the displays, I assume. Interesting bit is an STM8S003F3. As suspected a microcontroller, so all I can do is fire random ascii at it and see what happens - and hope I don't trigger a bootloader Think I will just accept as a neat module that will do what I want and not try and add data logging or anything clever
Steve Withnell | 07/02/2016 11:27:22 |
![]() 858 forum posts 215 photos | I'd eMail the seller, I've had a quite a bit of 'modules' type stuff from China and the sellers are usually very helpful, assuming the Chinglish isn't a barrier. You might get a good surprise in just how much they are prepared to share.
Steve
Michael Gilligan | 07/02/2016 16:44:38 |
![]() 23121 forum posts 1360 photos | Neil, The module in this video looks familiar: MichaelG. |
Neil Wyatt | 07/02/2016 16:55:39 |
![]() 19226 forum posts 749 photos 86 articles | Yep, that's the one. Neil |
Neil Wyatt | 07/02/2016 16:58:13 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Steve Withnell on 07/02/2016 11:27:22:
Steve
"This seller is currently away until Feb 16, 2016. If you make a purchase, there may be a delay in processing your order." Chinese New Year - no point asking for at least a week or so! Neil |
John Rudd | 07/02/2016 18:21:24 |
1479 forum posts 1 photos |
Posted by Neil Wyatt on 07/02/2016 16:58:13: Chinese New Year - no point asking for at least a week or so! Neil What a pita..... Why cant they have New Year same time as the rest of the world? |
Neil Wyatt | 07/02/2016 19:29:45 |
![]() 19226 forum posts 749 photos 86 articles | Posted by John Rudd on 07/02/2016 18:21:24:
Posted by Neil Wyatt on 07/02/2016 16:58:13: Chinese New Year - no point asking for at least a week or so! Neil What a pita..... Why cant they have New Year same time as the rest of the world? Gosh. What if we have got it wrong? |
Les Jones 1 | 21/02/2016 12:42:29 |
2292 forum posts 159 photos | Hi Neil, Les. |
Neil Wyatt | 21/02/2016 13:15:19 |
![]() 19226 forum posts 749 photos 86 articles | I'd already got it in my hand when I posted my original query. I still haven't wired it up as I haven't dug out any big enough smoothing capacitors for my transformers yet. I've ordered a couple of multi-turn pots from China to replace the on-board ones. At the price even if the regulator isn't much cop the voltage/current readout is worth having. |
